Play in pinion flange
Discussion in '1st Gen. Tacomas (1995-2004)' started by Actionjackson, Jan 11, 2022.
  1. Jan 11, 2022 at 5:29 PM
    Actionjackson
    Actionjackson [OP] Well-Known Member
    Jack
    MA
    2004 Tacoma
    Howdy Folks
    Just greasing my u joints and when doing the last one at the rear differential, and noticed a surprising amount of play in the pinion flange (up and down play - not in and out) So the bearing in there is worn. Any one know much play is acceptable - before ring and pinion damage?
    Also does any one have experience changing just the outer pinion bearing or do both inner and outer need to be changed at the same time?
    Thanks to all who reply.
  2. Jan 11, 2022 at 5:34 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Any indication of gear lube leaking out? Did you check the level of the Duffy fluid level?
    If you got plenty of gear oil, then it stands to indicate the pinion seal is still doing it's job.
    Can you tighten the pinion nut and remove some of the play?
  3. Jan 12, 2022 at 10:06 AM
    Actionjackson
    Jack
    MA
    2004 Tacoma
    So I checked the fluid level - it was fine and recently changed. Since the rear end has no leaks and and any other issues, I think tightening the pinion nut as suggested above, according to this video; https://www.youtube.com/watch?v=JNFjcx8m7Hk which shows the exact same situation I have. Besides incorrectly over tightening the nut, any down sides to removing the play by doing this?
