Play in rear dif
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gyrkin, Jan 2, 2018.
  1. Jan 2, 2018 at 4:54 PM
    Gyrkin
    Gyrkin [OP] Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    I was replacing a u-joint and noticed some play in the differential. Is this normal?
  2. Jan 3, 2018 at 9:56 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Nope. Pinion bearing is probably toast. Time for a rebuild or a low mileage unit. Are you getting a vibration under deacceleration or coasting down hill? Any noise?
  3. Jan 3, 2018 at 1:29 PM
    Gyrkin
    Wyoming
    Well before I replaced the u-joint I sure was! Since replacing it, it's pretty smooth.
    Do pinion bearings usually get progressively worse before failing completely? And what happens if it does fail? In other words, how urgent of a repair is it?
  4. Jan 3, 2018 at 1:43 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Nice soundtrack to your video. If you're not getting any vibes you should be find on road for a little while while you figure out what your plan is for replacing / fixing it.
  5. Jan 3, 2018 at 3:24 PM
    License2Ill
    Ian
    Not exactly sure. I personally wouldn't run that way long. The rebuild might get more expensive?
    FirstTimeFirstGen and Dalandser like this.
  6. Jan 3, 2018 at 5:20 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Yeah it would be prudent to take care of it quickly for sure.
    License2Ill likes this.
  7. Jan 3, 2018 at 5:24 PM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Suggest taking care of it quickly bearing job is cheaper than new gears.
  8. Jan 4, 2018 at 6:04 AM
    Russianman92
    Russianman92 Well-Known Member
    Dunwoody GA
    1995 White Tacoma 3RZ 4x4 5 speed
    bilstein shocks/struts Add-a-leaf Mostly stock. Running 31x10.5 r15
    Replace promptly as this play is creating minor misalignment between the Pinion and Ring which will cause premature wear VERY quickly. The pinion is pre-loaded to have a certain clearance and shim value. Replacing that bearing isn't too difficult as long as you follow torque specs and have the tools. I've done quite a few. But at that point as you have to slide the axle shafts out you may as well replace all the bearings including the axle bearings.
    https://www.tacomaworld.com/threads/replacing-rear-pinion-bearing-on-a-1st-gen-tacoma.436587/
    Second post in the above thread he mentions what he went through, however, assuming you caught it soon enough you most likely will be able to get away with replacing the bearings and seals. He was talking about worst case scenario.
    See attached:
  9. Jan 4, 2018 at 2:17 PM
    Gyrkin
    Wyoming
    Thanks for all the help. Looks like it's a bit out of my league. I took it by a local shop today. He said it definitely needs new bearings. He can't get to it until the week after next, but said I should probably be fine until then.
    Russianman92, Xbeaus and Dalandser like this.
  10. Jan 4, 2018 at 2:38 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Are they going to do a Master rebuild kit on it?
  11. Jan 4, 2018 at 2:44 PM
    Gyrkin
    Wyoming
    Yea. He said he was going to order the kit today. Said it might need more parts, but won't know for sure until he gets into it.
  12. Jan 4, 2018 at 5:04 PM
    License2Ill
    Ian
    Will he let you pull the 3rd? That's 3-4 hours of labor right there...
  13. Jan 5, 2018 at 8:57 AM
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Get a new third from a junkyard, way cheaper than having a shop rebuild a diff for you. They typically go for $50-$75 around here.
  14. Jan 5, 2018 at 9:08 AM
    amalik
    amalik Well-Known Member
    Denver
    I thought a bad pinion bearing would cause a leak out of the rear pinion seal? I have a 3rd gen 4runner, so not sure if the rear diff is the same setup as the 1st gen tacoma (engine is the same though :p)
  15. Jan 5, 2018 at 9:46 AM
    Gyrkin
    Wyoming
    The closest junk yard is almost 100 miles away, and last time I checked they didn't have any Tacomas.
  16. Jan 5, 2018 at 9:47 AM
    Gyrkin
    Wyoming
    He wouldn't have a problem with that, but I'm going to let him do the whole job. I will be out of town for five days, and I'm just going to leave it with him.
  17. Jan 5, 2018 at 9:55 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Of course you'd be able to tell if it was leaking so it might not be that bad at this point in time :cool: E-lockers on 4runners are the same third, they have an 8" open diff other than that which isn't found on Tacomas. Good thing you saw what was happening OP!
  18. May 22, 2018 at 5:36 PM
    Kiloyard
    Kiloyard Road Warrior
    Phoenix, AZ
    1999 3.4L SR5 4X4 410K miles
    Toytec Boss/Eibach Coils & Deaver J59's
    Thread Revive! I was checking my U Joints today and noticed some back-and forth play in my drive shaft, none of the up-down-side-to-side play like in OP's video. I'm guessing this is normal, since there is likely some clearances for the gear teeth before they engage in the opposite direction - please let me know if this is not normal.
    My drivetrain makes a loud clunk sometimes when I let off the accelerator and I'm trying to track it down. The other possible culprit is the center (carrier) bearing. It has less than 1/4" of play according to my eyenometer. No noticeable vibrations at any RPM range.
