Play in Steering Rack Bushings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JSenuk, Jan 25, 2015.
  1. Jan 25, 2015 at 12:45 PM
    JSenuk
    JSenuk [OP] Active Member
    Sherwood Park AB
    2011 Black DCLB small lift with 285s
    2.5" lift, 285 terra grapplers, black mamba wheels, hood scoop light bar
    My truck has wandered since I bought it. I just assumed it was because of the 10 ply 285s the previous owner put on. But lately Ive noticed a pretty noticeable clunk through the steering wheel and the wandering to be getting worse. Finally had someone wiggle the steering as I checked everything out. There is definite movement in the steering rack bushings. Not tons but I don't know if I should see any. How soft are the factory ones? There is also a metal on metal clank when the steering is cycled. Sounds like its coming from in the steering rack itself. Anybody have experience with these steering rack issues? I really hope I don't need a whole new rack. Thanks
  2. Jan 26, 2015 at 7:00 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    Bad bushings are common...rack should not move when you cycle the steering wheel. Replace them with Poly bushings for longer life and better all round use.
