Play in the rear end
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BradyT88, Jun 1, 2012.
  1. Jun 1, 2012 at 3:55 PM
    BradyT88
    BradyT88 [OP] Well-Known Member
  2. Jun 1, 2012 at 3:58 PM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    As much as she'll let you.... ;)
  3. Jun 1, 2012 at 4:00 PM
    BradyT88
    Nice:cool:
  4. Jun 1, 2012 at 4:03 PM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    Sorry op, this one is just too easy
  5. Jun 1, 2012 at 4:03 PM
    capetaco12
    capetaco12 .<>./
    Cleveland Ledge, MA
    Sold: 33's,armor,crawler,dents, ect. 2020 Gladiator
    OME lift CBI sliders, front bumper homemade rear bumper 33x12.50 m/t Gears Aussie locker inchworm crawlbox Homemade flat belly
  6. Jun 1, 2012 at 4:05 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    I'm not too familiar with how much play is normal on the Taco, but I've seen plenty of other cars with that much play and it's normal.
    The problem with play in the driveline is that it's very difficult to pin point exactly what's loose, and if it's only one thing. Could be many things worn down after a while.
  7. Jun 1, 2012 at 4:10 PM
    tacoma.nut
    tacoma.nut Well-Known Member
    Beeb
    Washington
    2011 TRDsport,LB,4by4
    geez....wording..lol...
  8. Jun 1, 2012 at 5:34 PM
    BradyT88
    Gotta keep things fun;) haha
    Yeah the noise started when it had less than 15000 miles on it and that ring gear and pinion had less than 1000 on it. I'm not so concerned with the play as I am with this noise. Turn your volume up and listen. This noise is coming through my rear sliding window while driving.
    http://www.youtube.com/watch?v=RtmWvUPvS74&feature=youtu.be
  9. Jun 1, 2012 at 5:41 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    Wow that almost sounds like bearings?
  10. Jun 1, 2012 at 5:57 PM
    BradyT88
    I know... but what bearings? The noise is gone with the rear drive line removed and driving in front wheel drive, which could mean carrier bearing I guess.
  11. Jun 1, 2012 at 6:18 PM
    The Traveler
    SoCal
    Still under warranty??
  12. Jun 1, 2012 at 6:53 PM
    BradyT88
    The factory warranty is up but I do have a warranty on it. They covered the ring gear and pinion the first time, but I have no proof that the noise was there prior to the 33's and they will likely just blame it on the oversize tires this time, plus they only cover stock parts and if the ring gear and pinion need to be replaced I will just pay to go to 4.88's this time. I'm not sure if they cover bearings. Whatever bearing is may be if it is one.
    I believe the u-joints are fine. I greased them up and played with them when I had the driveshaft off and there is 0 play in them and they all move as they should. As for the carrier bearing, I believe it moves as it should. Not sure how else to diagnose it. Did a make shift drop on it but that did nothing for the noise.
  13. Jun 1, 2012 at 7:15 PM
    The Traveler
    SoCal
    :popcorn:
    Sorry....:D but yes you're right the dealer will most likely not work on it because they'll say the oversized tires caused extra strain on the drivetrain components. I'd go with the 4.88's too...good choice since you'll have to re-do the gears anyway.
  14. Jun 1, 2012 at 7:23 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    If your gonna stay at 33's i'd go 4.56's at 4.88 you'll be hella over geared
  15. Jun 1, 2012 at 7:25 PM
    BradyT88
    Haha:D
    Although I do have a connection at the dealership here, maybe if I just borrow somebody's stock wheels, they can just tell the warranty company that I have stock tires, although that would mean I would have to stick with 3.73's.
  16. Jun 1, 2012 at 8:28 PM
    BradyT88
    So if anybody is still lurking, want to help me run down the options?
    So lets say the noise is somewhere in the axle housing/differential or whatever it goes by, what all could it be? I can think of 2 obvious choices:
    1. Ring gear and pinion
    --bad angle: I find this unlikely unless something could come loose, I am pretty sure that there was 0 noise from it for aleast the first 1000 miles
    --damaged: maybe a metal shaving from the initial break in period somehow got into it and damaged it
    2. Bearings, I don't know how many there are though
    I know there are the wheel bearings out near the tires. I have grabbed both wheels and jerked them around from all angles and there is no play there, but does that mean they are fine or could they still be making the noise? Also would the noise be strain dependent like it is? when I shift into neutral the noise pretty much goes away, it was also gone when I was driving around without a rear driveline. I thinnk there is also a bearing on the pinion, could be that.
    After those 2 I don't really know... What do you guys think? Any help is very appreciated:D
  17. Jun 1, 2012 at 8:36 PM
    BulletToothTony
    How many miles are on your truck?
  18. Jun 1, 2012 at 8:37 PM
    BradyT88
    About 17,000. Somewhere just shy of 15,000 when I believe the noise started.
  19. Jun 1, 2012 at 8:39 PM
    BulletToothTony
    Wait you have an 05 with 17,000 miles on it????
  20. Jun 1, 2012 at 8:47 PM
    BradyT88
    Had 11,800 on it when I bought it back in Oct. haha. and it has had something like 20 oil changes all done at the dealership, plus a shit ton of mods and such. Yay for old guys with no where to go!! haha
