Playboy Advisor advice: what do you think?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Truckn4life, Jan 25, 2011.
  1. Jan 25, 2011 at 4:38 PM
    Truckn4life
    Truckn4life [OP] Well-Known Member
    Dan
    Iowa City
    09 Black 4x4 Reg Cab SR5
    So I read in the new Feb issue of Playboy the following advice. Just wondered what you though?
    The ?: "Should you let your car warm up for 5-10min in cold weather?" GG in Kansas City,MO
    Playboy Advisor answer: "The Best way to warm up a cold car is to drive it. Modern cars dont need to idle more than that and youre just wasting gas and contributing to air pollution. The vehicles of old had to be warmed up for a number of reasons, one of which was so the lubricants had time to circulate. But chemical additives now allow lubes to maintain their viscosity (flow rate) even when cold. Electronic fuel injectors also allow more fuel to reach a cold engine. On a related note, to fight pollution many cities have made it illegal to idle more than a few minutes; one study found that idiling for 10 seconds uses as much fuel as restarting a car."
    Do you agree?
    I guess I tend to let my car idle more in the 10min range. Mostly b/c I want my car warm when I go to drive. Also the car drives better more quickly. I try to be as eco-minded as possible and am now bothered by my habit. If i just put on an extra layer to take off and idle for say a min. Will i save the planet?
    sorry if you got your hopes up for some swingers drama question! :)
  2. Jan 25, 2011 at 4:39 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Wow. Despite that this topic has been beaten to shit, then beaten a little bit more, YES. Best way to warm up a modern vehicle is to drive it.
    And as far as being "Ecco minded", your wasting alot of fuel by letting it warm up. The longer it takes to warm up, the longer the engine is dumping more fuel into the motor. I found my truck goes into closed loop about 30 seconds after I start to drive it.
  3. Jan 25, 2011 at 4:39 PM
    Lost_Humanity
    Lost_Humanity Bad decisions make great stories.
    Seattle
    It's a Toyota.
    Bumper Dent Mod
    You read the articles in Playboy?
    About car stuff?
  4. Jan 25, 2011 at 4:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    X2. I had no idea they had articles in it. I thought that was a myth....
  5. Jan 25, 2011 at 4:45 PM
    Truckn4life
    Dan
    Iowa City
    lol
    lot of great articles! plus all the chicks look the same after a while. i couldnt even tell you if last months issue had a blonde or brunette chick
  6. Jan 25, 2011 at 4:46 PM
    Lost_Humanity
    Seattle
    It's a Toyota.
    Bumper Dent Mod
    I was fairly certain the only text in Playboy was the models' stats.
    If I want to "read," I get a Penthouse.
  7. Jan 25, 2011 at 4:49 PM
    joes06tacoma
    Joe
    Central Coast, CA
    ^ LOL.....everything's fake in Playboy....the tans, the boobs, and I would assume the car advice too:D
  8. Jan 25, 2011 at 4:56 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Know how I know you're gay?
    JJ
  9. Jan 25, 2011 at 5:31 PM
    Pusher52
    Pusher52 Active Member
    Pusher
    Louisiana
    11 TRD Sport 4x4
    I would agree that most cars are fine to start driving after a minute or so, but some, like my recent '10 M3 did not like to be driven right away, even during the hot summer. It wasn't just mine either, talked to many owners who experienced the same hucklebuck when driving right away. It probably really depends on the make and mod of the vehicle. Kill the horse.
  10. Jan 25, 2011 at 6:06 PM
    ruskastud
    ruskastud Well-Known Member
    Lenexa, KS
    '10 Tacoma Double Cab 4x4 TRD Off-Road
    AVS Hood Shield & In Channel Ventvisors, Console Vault, Disable Seat Belt Chime, WeatherTech DigiFit Floor Liners, Lighted 4x4 Switch, Ultra-Gauge, Rear Spring TSB
    The places i'm looking shouldn't have hair..............
    :headbang:
  11. Jan 25, 2011 at 6:17 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    WTF does this have to do with 2nd gens and also playboy only has pictures no articles proven fact
