playstation 3 problem
Discussion in 'Video Games' started by tacomaman06, Jan 16, 2011.
Thread Status:
Not open for further replies.
  1. Jan 16, 2011 at 2:12 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    alright.......i have a samsung 40 inch lcd....with only one hdmi port. i also have direct tv. i hooped up my ps3 with the component cables that came with it and it was fine, but i bought a hdmi splitter to get full hd for everything. here is how i have it hooked up.....
    hdmi cable from direct tv receiver to the "in" on the splitter.....one hdmi cable from "out" on splitter to the tv, and one "out" to the ps3. when i turn on the ps3...i get nothing...no menu screen or anything. i even tried turning off the receiver for the satellite, still nothing. also tried resetting the ps3 as the manual states....nothing there either. ya'll got any advice for my non-techie ass?:D this is getting kinda ridiculous...cause i spent $100 on the splitter and nothing is working on the ps3 end. tv/satellite work fine tho.
  2. Jan 16, 2011 at 2:14 PM
    113tac
    113tac Well-Known Member
    Stephen
    Northern Virginia
    2017 Magnetic Gray Tacoma
    Mostly Stock for now, 265 75 16 Falken AT3W, Tinted fronts...
    from what you described you have it plug in wrong.... i think you have too many out ports and not enough in ports.
    i think the one you have would be to connect the direct tv to two tv's not ps3 and directtv to one tv but i could be wrong
  3. Jan 16, 2011 at 2:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah, the splitter i got has one in port and 2 out ports.
  4. Jan 16, 2011 at 2:17 PM
    113tac
    Stephen
    Northern Virginia
    does the ps3 work if you plug it in straight to the tv with the hdmi?
  5. Jan 16, 2011 at 2:17 PM
    Cutter29
    Cutter29 Well-Known Member
    Utah
    15 Tundra TRD PRO
    with ps3 off, push and hold power button till it beeps. this will adjust it to your tv. i've had this problem before but not using splitter. this usually fixes it.
    *Edit* just reread you post. sounds like wrong cable in.
  6. Jan 16, 2011 at 2:18 PM
    SuthrnTaco07
    SuthrnTaco07 Well-Known Member
    Kyle
    Huntsville, AL
    2020 Cement Tundra Limited
    None
    Try this...
    Turn off the PS3.. when you turn it on.. hold the on button until it beeps the second time.. When it beeps the second time it should reset your video out settings and then you'll be good to go if you have the correct splitter...
    Well if it's your splitter then you'll have to get one with 2 "In" and 1 "Out"
  7. Jan 16, 2011 at 2:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i tried that, and still nothing happened. the ps3 came on, but nothing showed up on the tv.
  8. Jan 16, 2011 at 2:20 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ^^^^.....nothing happened. hell......may be the damn splitter.
  9. Jan 16, 2011 at 2:20 PM
    98tacoma27
    Ben
    Not Beech Creek
    Wrong splitter. You need one with two "ins" and one out. The type you have would be for two tv's. You are basically sending hd signal to the tv and to the PS3
  10. Jan 16, 2011 at 2:21 PM
    113tac
    Stephen
    Northern Virginia
    yeah haha its probably the splitter, hopefully you can exchange it for one with two in's
  11. Jan 16, 2011 at 2:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    dammit it. so....no way to make this splitter work? does walmart carry the correct one i need?
  12. Jan 16, 2011 at 2:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    bad thing is.....i cant find the effin box or nothing for this stupid splitter. dude on the geek squad at best buy told me this is all i needed.
  13. Jan 16, 2011 at 2:24 PM
    113tac
    Stephen
    Northern Virginia
    damn, thats unlucky, good luck with finding it
  14. Jan 16, 2011 at 2:29 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    with it off.......hold on for 10 seconds.....or visa versa.......it will adjust
  15. Jan 16, 2011 at 2:30 PM
    crf69
    Ohio
    ummm yeah
    i have to do this when goin from crt to hdtv
  16. Jan 16, 2011 at 2:32 PM
    98tacoma27
    Ben
    Not Beech Creek
    What model did you buy Will?
  17. Jan 16, 2011 at 2:33 PM
    98tacoma27
    Ben
    Not Beech Creek
    You need a switch, not a splitter.
  18. Jan 16, 2011 at 2:35 PM
    98tacoma27
    Ben
    Not Beech Creek
  19. Jan 16, 2011 at 2:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  20. Jan 16, 2011 at 2:40 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
Thread Status:
