Please delete
Discussion in '3rd Gen Tacomas For Sale (2016-2023)' started by Tacos2016, Jul 8, 2019.
  1. Jul 8, 2019 at 10:30 AM
    Tacos2016
    Tacos2016 [OP] Well-Known Member
    Derick
    Bristol,Tn
    2016 Tacoma TRD Sport Quicksand
    N-Fab 3inch nerf bars, window tint 20% all windows and front strip, weather tech floor mats, door sill protectors, door cups/ tailgate protector film , tailgate tacoma raised inserts, bed mat, plasti dipped grill/decals, Lasfit LED head/fog lights, LED interior, 3/2 readylift, Method NV rims 0 offset/ 4.75 backspacing /17x8.5 , Falken wildpeak AT3W 285/70/17, KB Voodoo remote start, Leer camper top.
    Thinking about selling so I can upgrade to a Tundra crewmax.
    2016 Toyota Tacoma TRD Sport 4x4 DC SB with sunroof,heated seats, backup & blind spot sensors. The truck has everything except JBL.
    Currently has 19,500 miles but will go up.
    Located in Bristol,TN
    $33,000 OBO
    -N-Fab 3inch nerf bars
    -Window tint 20% all windows and front strip
    -Weather tech floor mats
    -Clazzio Black Leather seat covers (dark gray cloth underneath)
    -OEM trd pro shifter
    -Center console organizer tray
    -Door sill protectors
    -door cups/ tailgate protector film
    -Tailgate tacoma raised inserts flat black
    -OEM bed mat
    -Plasti dipped decals
    -China pro grill
    -Lasfit LED low beam/fog lights
    -LED interior/ license plate
    -Front 3'' readylift spacers
    -Rear Blistein 5160 shocks (installed at 17,500 miles)
    -Headstrong 2'' 3 leaf AAL (installed at 17,500 miles)
    -Method NV rims (set of 4) 0 offset/ 4.75 backspacing /17x8.5
    -Falken wildpeak AT3W 265/70/17 Less than 5k on them (set of 5 spare never used)
    -Leer camper shell (color matched originally white)
    -Thule roof rack
    I have parts I've yet to install
    -Front suspension Blistein 6112 new in box
    -SPC light racing UCA with new replacement ball joints ( bought used on TW with 15k on them)
    -Ecgs bushing, seal, and removal tool (new)
    -KB Voodoo remote start (bought used on TW)
    Parts I took off
    -OEM tonneau cover (took off within a year buying my truck)
    -Factory grill plasti dipped
    -Front air dam
    -2'' readylift rear block
    83AD788B-59DD-4053-B3EA-86D65DA3BEF9.jpg 1AF35C01-319E-4AEF-82F7-635400F5FE82.jpg D048739E-BE2C-46CD-A581-F6828C4FBE6D.jpg 8261AF37-2836-44E5-BE38-3F348BD08F08.jpg 4CDACD8C-636F-4B56-BF52-F1D0278B8479.jpg DD1C482F-DDDB-4BA5-A3D3-6314CC36C730.jpg 5D1F493B-390B-446D-B3D0-555B4CEF15BD.jpg 83AD788B-59DD-4053-B3EA-86D65DA3BEF9.jpg
    Mack411 likes this.
  2. Jul 12, 2019 at 6:46 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Nice truck! GLWS
    RON_TRD Sport likes this.
  3. Jul 15, 2019 at 2:14 PM
    Overland&UpMoutains
    Overland&UpMoutains Fully Built Overland Rig for Sale
    Parker
    Deleware
    2018 TRD Pro MT Blue
    Armor: Custom Fabricated Front Bumper (Victory 4x4 Blitz w/ full width tubing added after) Victory 4x4 Strike Steel Rock Sliders Coastal Overland Rear Bumper w/ Dual Swing Out Steel and reinforced Hitch Receiver RCI Full Aluminum Skid’s Wheels/Tires/Suspension 34” BFG KO2 (Full size spare on swing out) 17” KMC Impact (black) Fox 2.5” Front Coilovers w/ DSC Adjuster Upgraded Springs: 650 lb Eibach 14" Long 3.0" ID Coil Springs Total Chaos Upper Control Arm Fox 2.5" Remote Reservoir Shock Kit for Rear w/ DSC Adjuster ICON RXT Leaf Spring (Option 3/Heavy Setting) Wheeler Superbump Front + Rear Bumpstops ICON U-Bolt Flip Kit Body Mount Relocation ECGS 8” Clamshell Bushing (Eliminates Needle Bearing) **For Refrence: Suspension set up is equivalent to Stage 4a Acutune** Performance/Off-Road Stuff/Recovery Nitro 4.88 Regear installed by ECGS Dobson 4x4 Snorkel Differential Breather 10k lb winch (Smittybuilt) Extended rear brake lines Hi-Lift Jack w/ weatherproof cover included (mounted to roof rack, can also be mounted to swing out) Air Compressor and Air Hoses included 4 ton jack stand included Tree saver winch strap included D-Ring Shackle x 2 included Spare Parts Include: 1 Wheel Bearing, 1 Tie Rod End Interior Accessories Custom Rear Seat Delete Platform Dashtop Multi-Mount (DMM), Will include 3 RAM mounts, one radio mount and two phone mounts iPad Mount, attached to passenger seat bracket, used for navigation Headrest Velcro Pouch Kit (Blue Ridge Overland) Overhead Storage Attic (Blue Ridge Overland) Trash Can (Lusso Gear Spill-Proof Car Trash Can, 2.5 Gallon Hanging behind Passenger seat) Fire Extinguisher Mount Exterior Accessories/Storage Prinsu Cab Rack Rugged Case (47” weatherproof rifle case mounted on Prinsu roof rack) Custom Roof Rack on Camper (designed to fit traction boards perfectly with space on either side for bikes or storage cases) Tailgate Storage, custom design using deck hatch that utilizes the interior space of the tailgate where I store recovery gear. Overland/Camping: Camper Custom (see details below) Bed light Bed lighting Domestic Fan Swing Up Rear/Side Panels with Locks Roof Rack 200 watt solar panel LED Third Brake Light Rear View Camera (connects to video rear view mirror in cab) Hurricane Hinges (not in the first few pictured as it was recently installed, you can see them in the later pictures but they are now painted black not silver to match the camper, totally waterproof no leaks!) Bed Buildout/Living System Baseboard/Mounting Plate (1/2” Birch, Bed Liner Coating) Trunk Cabinet Shelf Cabinet (fits 2 Sidio crates plus top storage box w/ organizing dividers) Elevate Fridge Cabinet w/ under storage for stove/cooking gear Custom 8020 build - strong enough to sit/stand on Water: 10 Gallon Water tank with pump, two spouts, one in back seat one in the bed 5 lb Propane Tank w/ mount attached to Swing Out (likely included, final tbd) Drop down table (attached to swing out) Rear Seat Delete (custom) Lighting: Rigid Adapt 30” Light Bar Rigid Ditch Lights Quad LED Headlights Meso Dual Red/White Interior Lights (Map + Dome) Camper interior lighting Electric Dual Battery System RedArc BCDC 25a Controller 90 Ah AGM Secondary/House Battery 200 watt solar panel 2 Blue Sea Fuse Boxes to manage accessories (one under hood, one in bed) Extra fuses included Comms: Midland Micromobile GMRS WeBoost w/ extended antenna on a RAM pivoting mount Other Fumoto Oil Change Valve Bike Rack (Tire Mounted)
  4. Aug 5, 2019 at 10:04 PM
    Mack411
    Mack411 Well-Known Member
    2017 Quicksand Tacoma Trd-OR
    Want to sell the clazzio and remote start separately? Located in kingsport Tn.
