please explain how exhaust really works
Discussion in 'Performance and Tuning' started by TacomaMtnMan, Jul 14, 2010.
  1. Jul 14, 2010 at 6:34 PM
    TacomaMtnMan
    TacomaMtnMan [OP] those who seek fear shall be followed by fear
    Chuck
    Broomfield
    Fox Shox lifted DC 4x4
    3" lift using Fox Shocks Coilover, Total Chaos UCA's. Running: Duratrac 285/70/17 Rear suspension just a 1" block for now. Will have custom rear springs no block. Fox w/ Resi.
    Hey guys,
    I have been checking on youtube and dont really trust the info on wikipedia...
    I am curious to know and understand how exactly does exhaust work? I am sure most of us know the basics. I am more interested to know how to get more performance from exhaust, not just replacing from the cat-back, but the entire system from the headers...
    I guess I am more curious on why I should do this, does every part of a factory exhaust cause some kind of back-pressure?
    Including headers, cats, muffler, tubing...
    Why does a true-dual out better than dual from the muffler?
    Thanks for the info!
    ~ Chuck
  2. Jul 14, 2010 at 6:41 PM
    HomerTaco
    HomerTaco All up in your GRILL Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
  3. Jul 14, 2010 at 6:46 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I'm not a engineer but basically with a CBE/HBE system you are lessening the back pressure. Meaning that it will allow more air to flow through the engine. In other words it opens things up. It doesn't really do much without having more air drawn into the engine through say a cold air intake.
    IMO a dual system is a little much for our trucks w/o forced induction. I don't think with a cold air intake you can draw in enough air to make lessening the back pressure that much worth it. The dual system is more for looks. Like I said this is my opinion.
  4. Jul 14, 2010 at 6:47 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    Well. this will be a long one...
    Headers are designed to help scavenge the combustion chamber (clean out the spent gases from the combustion chamber so that you have fresh O2 from the air, to mix with the fuel). Theoretically you want each tube length to be the same and for the collector to be as efficient as possible. If you were to picture the volume of one compression stroke to be one tennis ball going down the header tube, you would want the tennis ball to get in line and arrive at the collector at the moment just after the prior cylinder (in firing order) and just before the next.
    Now there is also a desire to have back pressure (resistance) in the system too. When you design an engine for all out power like a drag car or race boat - you want the engine to be winding (reving) nearly as fast as it can in the highest part of it's power curve - internal combustion engines have their highest power and torque at the higher revs ~75-90% of top engine speed.
    Interesting to note - electric motors are the opposite - their highest torque is at lowest RPM - great for jumping the line.
    Back to IC motors...
    On a truck you may want low end torque (rock crawling) or higher end power (desert pre running). With that in mind, designers try to optimize the torque/power curve to suit the application. The first thing an engine designer thinks about is what engine speed am I designing for? Then he builds an engine from there.
    In our case (all though I do not have headers, so if you would like, call me full of shit :)), headers clean up the opium tube length and are sweet. I don't know if they hurt the lower end (they could) and as long as you are not using your truck to pull stumps out of the ground at very low speeds, are a nice addition to your rig.
    One other thing to note is that our trucks have o2 sensors (lambda sensors) that dynamically detect the fuel air ratio and then corrects the fuel being injected to reduce the likelihood of unspent gas going out your tail pipe. To my knowledge (which is admittedly limited) most of the header systems have you buy a device to bypass this system - aka o2 'simulators'. If I was doing a header set up, I would like to see one with a bosses for the o2 sensors. It may still be an issue since we do have a limited variable timing set up to that would need to be looked at to really dial in a motor.
    Feel free to flame as to my knowledge for this particular set up is limited. But regarding waste gases - I am an expert! ;) :eek:
    Oh yeah, my Thermodynamics and Internal Combustion Engine instructors should be glad he didn't read this answer.
    PS - Back-pressure is not a bad thing - especially on a truck that works!
  5. Jul 14, 2010 at 6:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    http://www.tacomaworld.com/forum/technical-chat/19967-how-air-goes-thru-your-engine-basic.html
    Have you ever noticed that if you make a quick "puff" at a candle from a short distance, that the air, even though you are not blowing anymore, still makes it to the candle and blows it out? That's because air has "mass", and when in motion, it must be acted upon to stop it. Have you ever noticed that as a kid when blowing bubbles, if you try to blow a bubble to keep it aloft, it seemed that sometimes the bubble would be passed by the air, only to wiggle around, and then "follow" the air you just blew? These little things also apply in an engine.
    As the air is going through the intake, and through the throttle body, there is a bit of turbulence created by the throttle plate. As it continues on to the intake runners, the air is straightened out into a nice laminar flow, as the intake valves open, and the piston is rapidly moveing downward, the air rushes in to fill the combustion chamber, flowing down the sides of the cylinder wall, hitting the top of the piston and moving up the other side and thru the middle, and swirling. as the intake valves close very fast, its like a door slamming shut. The air that was following in to the combustion chamber is now suddenly stopped. This sends a "shock wave" backwards through the intake runners, and if timed properly, this "shockwave" or "Pulse" is now helping to "push" more air into another cylinder.
    Meanwhile, as the air in the first cylinder is being ignited, and producing power on the downward stroke, the piston now begins its upward stroke. The exhaust stroke.This is where scavenging comes into play. Scavenging is when the exhaust valves open and the exhaust exits the cylinder leaving a vacuum behind it. At that point the piston moves the exhaust out rapidly in a "puff". This puff, once again has mass. There is a high pressure area leading the way in front of the exhaust pulse, and when the exhaust valve closes, it happens abruptly, creating a low pressure area behind the exhaust pulse. This pulse travels down the exhaust, and past another cylinder. The low pressure of the pulse "pulls" the exhaust gasses from the next cylinder, when doing this, it creates a vacuum in the combustion chamber helping to "pull" more air into the cylinder as the intake valve is starting to open while the exhaust valve is still open, this is called overlap.
    All these pulses need to keep up their velocity to remain efficient. They do this by staying hot, and by the size of the exhaust pipes. Newer vehicles with variable valve timing (VVT) keep these pulses timed throughout the rpm range. There is a "Goldie Locks" effect taking place. Too large of a pipe, and the pulses slow, exhaust cools too fast, and the engine looses efficiency. Too small of a pipe, and the exhaust is sped up beyond how the timming of the valves was designed, the exhaust temps rise, and the engine looses efficiency. Any change in the system, be it a larger exhaust, or whatever, has an effect on it. Sometimes positive, as the auto makers have to abide by emissions standards, but many times negative, as some aftermarket manufactures just want it to "sound cool".
    When installing a Turbo, or Supercharger, the scavenging effect is not as important, as the higher pressure "pushes" everything through the system, in which case, a larger free flowing exhaust would be the most beneficial.
    I have oversimplified this just a bit, as I don't have time to go into EVERY thing, or break down the physics involved, but thought it would be a good read for those thinking about changeing their exhaust system and wondering how the new exhaust may affect performance. [​IMG]
  6. Jul 14, 2010 at 6:53 PM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
  7. Jul 14, 2010 at 7:02 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Love Goin' Down a List of threads, Seein' A Technical Question, and Chris4x4 The Last Post.
    Good Reading as Always, Thanks for More Education.
  8. Jul 14, 2010 at 7:09 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    what about a crossover pipe,and how this affects scavenging?
  9. Jul 14, 2010 at 7:13 PM
    HomerTaco
    Craig
    Bucks County Pa.
    I've learned something.....:D
  10. Jul 14, 2010 at 7:25 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On "V" configured engines, and running a Dual exhaust, the cross over pipe is used to use the low pressure of one exhaust pulse from one bank, to speed up the pulse from the other bank.
  11. Jul 14, 2010 at 7:34 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    Also... There is yet another option.... The MAC Prochamber.
    It looks like a box, or a muffler where the 2 header leads enter one end and then exit the other in the location of the H or X pipe.
    It is essentially a combination of all three basic designs , incorporating the crossover flow of an X pipe the open buffer of an H pipe and the passive pulse control of a ported baffle channel pipe. MAC is the ONLY maker to have this design.
    Basically it combines the exhaust into a single box, where the 2 inlets extend into the box a few inches to prevent reversion and open dumping exhaust into the box. The outlets are flush with the back of the box and there is a baffle between the sides with ported slots directing the flow of the inlets to cross to the other side. The Box holds backpressure at a steady rate, which eliminates scavenging.
    There are many who believe the Prochamber will give increased performance values. Everyone using them will tell you they make a deeper yet quieter tone to the exhaust note.
  12. Jul 14, 2010 at 8:52 PM
    HBMurphy
    Paul
    So California Coast
    None
  13. Jul 15, 2010 at 8:18 AM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    i like talking about exhaust... ;)
  14. Jul 16, 2010 at 12:34 AM
    TacomaMtnMan
    Chuck
    Broomfield
    I appreciate it guys! a ton of great information here and now I feel better. :)
    What is everyone's experience with the exhaust you are running on your personal trucks?
  15. Jul 16, 2010 at 7:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im running the TRD, and am quite happy with it. It doesnt give the best gains, but I like the sound. If looking for the best gains, a header, and full exhaust would give the most, but your still only looking at about 10 to 15 hp.
  16. Jul 26, 2010 at 8:15 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Exhaust used to be very restrictive in OEM setups.
    The cars had large engines and the manifolds, mufflers, and piping were cheep and made for quiet.
    Hot rodders started opening up exhaust systems and made huge gains espically with intake improvements as well.
    The OEMs caught on and in efforts to improve performance and milage started putting better systems on over the years.
    They work pretty damm good nowadays so a lot less improvement per dollar spent on exhaust systems is the norm.
    All thing considered sound is what I am after on my Tacoma.
    I don't think my TRD catback adds any power or milage improvement, just my enjoyment.
  17. Jul 28, 2010 at 10:13 PM
    RDA
    RDA New Member
    David
    Monrovia, CA
    09 TRD Sport, 6 sp. 4x4
    CAI, Short Shift, Cat-back (all TRD, all dealer installed)
    Really interesting material guys; thanks for posting. Helps explain why when I had Longo install the TRD CAI, I felt a gain, but 8 months later, when they put the TRD exhaust on, the engine seemed to gain a substantial amount of power particularly at high rpm when merging onto freeways. Yeah, all I have is the butt-dyno, but I've owned enough cars to know when I feel a substantial increase in power. The engine seems to run smoother, too. For those who don't want something too loud, the TRD exhaust is just about perfect. No droning at highway speeds like I've heard with other setups.
  18. Aug 22, 2010 at 8:34 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Chicago
    '10 TRD Sport Magnetic Gray
    Wet Okoles, Weathertechs, AFE Pro Dry, Wicked Flow 13", URD MAF, MagLite Mount, 16x8 Procomp 8069, 265/75/16 GY Duratracs, Rear Leaf TSB,AAL, OME 9000s, 884s, S2000 stubby antenna, Leer XR100
    In regards to headers, is there a difference in gains/loses when in comes to long and short tube headers?
    i've seen some info on this but nothing real concrete
  19. Aug 22, 2010 at 8:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Shortys generally give gains in the low to mid range, while the long tubes give the gains up top.
  20. Aug 22, 2010 at 8:40 PM
    RugbyTaco
    RugbyTaco Rhum.
    Paul
    Chicago
    Shortys it is then, thanx
