Please explain to me ground clearance
Discussion in 'Suspension' started by TG8, Sep 19, 2011.
  1. Sep 19, 2011 at 5:32 PM
    TG8
    TG8 [OP] Well-Known Member
    Trey
    Laredo, Texas
    2011 Tacoma Trd Sport 4x4
    STOCK STOCK STOCK SUCK STOCK STOCK WeatherTech Floor Mats All-Weather throughout the truck Smittybilt Bull bar with Hella 500 Series Halogen Driving Lamp (2)
    This makes absolute no sense to me if you get a 3 in lift and get more ground clearance vs getting a 4' in RCD DB lift or Fab or Pro comp and get less with the higher lift please explain to me:/
  2. Sep 19, 2011 at 5:33 PM
    jandrews
    '09 FourDubDee TRD OR
    This should be fun to watch. Let's see how long it takes someone to get to the right answer.
    :popcorn:
  3. Sep 19, 2011 at 5:34 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Neither lift gains you ground clearance , that comes with bigger tires
  4. Sep 19, 2011 at 5:35 PM
    DrewH
    DrewH Well-Known Member
    Tires are what give you clearance, lifts give you room for bigger tires.
  5. Sep 19, 2011 at 5:37 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
  6. Sep 19, 2011 at 5:37 PM
    OZ-T
    Peter North
    British Columbia
    repost , Canadian
  7. Sep 19, 2011 at 5:38 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    If theyre talking about differential clearance then yes, DB lifts don't get as much clearance as a 3" lift if both were to have the same tires
    3" and below lifts raise the entire truck, including the front differential, (which is why you don't see 3" lifts with straight CV axles) while DB lifts lower the front diff to keep the CVs in line.
    However, lifting a truck lets you clear larger tires, which is actually where a lot of the "lift" happens- you can fit way larger tires with a 6" lift then you can a 3"
    EDIT:
    Did it really take me that long to type that? i need a nap
  8. Sep 19, 2011 at 5:39 PM
    DrewH
    You are too fast for me...:cool:
  9. Sep 19, 2011 at 5:41 PM
    jandrews
    Pretty much the winner.
    Depending on how "ground clearance" is measured, there are a lot of answers here.
    And suspension travel is the same, meaning the higher lift has rendered the truck more prone to rollover due to the higher center of gravity.
    So running clearance may be increased, but I would argue actual offroad capability is LESS than a 3" lift.
  10. Sep 19, 2011 at 5:41 PM
    OZ-T
    Peter North
    British Columbia
    :woot:
  11. Sep 19, 2011 at 5:48 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Hey OZ-T...Is it true that canadian ground clearance generally higher due to being farther north of the equator?
  12. Sep 19, 2011 at 5:49 PM
    OZ-T
    Peter North
    British Columbia
    Yes , but that doesn't factor in the snow .
  13. Sep 19, 2011 at 5:51 PM
    jandrews
    Also just by virtue of being Canadian...9.8 inches American is something like 13.2 Canadian...
  14. Sep 19, 2011 at 5:52 PM
    OZ-T
    Peter North
    British Columbia
    we use metric inches
  15. Sep 19, 2011 at 6:15 PM
    TG8
    Trey
    Laredo, Texas
    Wow okay Thanks TW PEOPLE!!
  16. Sep 19, 2011 at 8:09 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Any suspension lift increases approach angle, departure angle, and breakover angle.
  17. Sep 19, 2011 at 9:30 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Feh.
    The problem is in trying to reduce all the variations of clearance to a single number.
    LOOK under your truck. Is everything the same height? Of course not.
    You need a "minimum" ground clearance, and a "maximum" ground clearance number.
    Minimum would be the number where you start rubbing something (rear differential) when you're driving in deep wheel ruts.
    Maximum would be the tallest rock you can drive over with careful driving without "putting a wheel on it."
    Given the same size tire, a "drop bracket" lift will probably have a lower "maximum clearance" than a 3" lift created with extended length struts, because the height under the drop bracket will be lower than the highest point on the rear axle, while for a 3" strut lift, the opposite is likely true.
    Tire size is the only thing that affects minimum clearance.
    But there are so many other ways to hit, and rub rough objects on the ground.
    Any suspension lift will get the frame, and the front and rear bumpers further off the ground, increasing the variation in terrain you can traverse without dragging some part of the truck on the offending terrain.
    A 3" lifted tacoma with 33" tires, traction aids such as lockers, and sliders to protect the rocker panels is quite capable on quite a variety of trails.
    Also, once you start wanting to attack trails that are "too difficult" for a 3" truck with 33" tires, you're really starting to cross over into the realm of trails where body damage becomes a seriously likely possibility. Just my observation, but it tends to appear to me that most guys running drop-bracket lifts seem to like to keep a clean, undamaged looking truck.
    Finally, drop bracket lifts don't increase suspension travel, but do increase overall rig height and center of gravity. Rollover is always a risk offroad, so keeping CG as low as possible is desirable.
    The best advice is not to make any off-road modification to your truck until you've driven somewhere that it would have been useful. Sliders are a possible exception - but the counter argument says: drive to the place/trail/obstacle, assess, then take the bypass or turn around rather than risk damage. Come back next time with the appropriate armor.
  18. Sep 19, 2011 at 9:37 PM
    OZ-T
    Peter North
    British Columbia
    Well said Steve
  19. Sep 20, 2011 at 1:07 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Portal Axles.
    Fuck your logic.
  20. Sep 20, 2011 at 2:53 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My 2010 min. ground clearance (cement floor to bottom of rear differential) was 9.25 inches when new, with the 265/70-16 (31") stock tires. The exhaust crossover by the transfer case was also the same.
    When I installed the 32" Hankook Dynapros (265/75-16) my ground clearance increased to 9.75" (1/2 of the difference in tire diameter).
