Please explain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by saweetlou, Feb 16, 2021.
  1. Feb 16, 2021 at 4:47 PM
    saweetlou
    saweetlou [OP] Well-Known Member
    Guelph Ontario
    TRD Dbl cab long bed
    3in spacer
    I attempted to do some doughnuts in the snow last night, I press and held the traction button but it still kicked in after i picked up speed, I also turned off the side stability thing and no difference(2013 Taco sport)
  2. Feb 16, 2021 at 4:49 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    TC auto engages again after a certain speed is reached.
  3. Feb 17, 2021 at 2:53 AM
    saweetlou
    Guelph Ontario
    3in spacer
    How is it that people are able to do full on drifting.
  4. Feb 17, 2021 at 3:04 AM
    Mr.Hustler
    Mr.Hustler Well-Known Member
    2018 Magnetic Grey Metallic TRD Off Road 4x4 [AT]
    It's a secret
    If you have an auto-transmission, try setting your gear selector on D-1 along with disabling the traction-control.
  5. Feb 17, 2021 at 3:09 AM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Someone needs to make a TC delete button for our trucks. Even when you hold the button it still moderates your gas and braking. As soon as I let off the gas when kicking sideways it will apply brakes and straighten out.
    saweetlou[OP] likes this.
  6. Feb 17, 2021 at 3:17 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    30 MPH
    Thgr8alex likes this.
  7. Feb 17, 2021 at 3:27 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    Ask Darwin...
    JGO and DrFunker like this.
  8. Feb 17, 2021 at 3:31 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Did you disengage it all the way?
    In mine I have to come to a complete stop be out of gear (manual) push in the clutch and the brake and hold down the trac button after a few seconds the track light will come on with the LSD light then keep holding a few more seconds the LSD light goes out and then I can be stupid without nannies to get everything to actually turn off for real.
    I don't know what guy is talking about the transfer case coming in automatically. :crazy:
    It's a part time 4x4 there is no center diff the truck is not capable of AWD automatic transfer case coming in shenanigans, if you don't turn the dial the transfercase (electric shifted manual shift case) won't change from 2WD high position, if it tried you would have metal particulate all down the road behind you.
    You can shift into 4WD under a certain speed but it's recommended you be going slow and straight.
    Thatbassguy likes this.
  9. Feb 17, 2021 at 3:36 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    At a complete stop and either in park or N, hold down the TC button for about 5 secs.
  10. Feb 17, 2021 at 3:53 AM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    ^^^^this^^^^
    It's almost like we need a sticky thread explaining how to turn off traction control. Or, maybe Toyota could start providing a book of some sort explaining how to operate the vehicle. Like, some sort of manual for owners.
    Unless the OP followed the proper procedure and it still kicked back in on it's own? :notsure:
    @saweetlou did you come to a complete stop and then hold down the trac-off button?
