please guys. i need wheel help!!!
Discussion in 'Wheels & Tires' started by Jacobrobertson200, Aug 19, 2012.
  1. Aug 19, 2012 at 4:50 PM
    Jacobrobertson200
    Jacobrobertson200 [OP] Member
    Jacob
    Louisiana
    2000 Tacoma 4x4.
    im looking to put ballistic jesters or some rockstars. i have a 2000 4x4 tacoma. will these wheels fit. all i can find is 01-04 wheels. i cant find info on this. my last post had 93 views and no help. PLEASE PLEASE help.
  2. Aug 19, 2012 at 4:51 PM
    DrewH
    DrewH Well-Known Member
    If you post it in the wheels and tires section you might have better luck. PM a mod and they can move it.
  3. Aug 19, 2012 at 4:55 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    1. Specs of the wheels in question?
    2. Tire size you want to run?
    3. Suspension specs?
    And I agree with Drew, please post in the wheels and tires forum if you want wheels and tires help, because that's where the people that know things about wheels and tires hang out.
  4. Aug 19, 2012 at 5:19 PM
    Jacobrobertson200
    Jacob
    Louisiana
    2000 Tacoma 4x4.
    ok thanks for your help. also they are going to be 18x9 -12 off set. 33's with 3" leveling kit with 1" block in rear and 3" body lift. im just worried about the front hub on the front wheels
  5. Aug 19, 2012 at 5:21 PM
    Large
    Large Red
    3" BL? Here comes :crapstorm:
  6. Aug 19, 2012 at 5:21 PM
    TexasTacoma37
    33's come in all shapes and sizes...what is the actual tire size.
    And you're going to run a 3" spacer lift and a 3" body lift? Why? You can clear 285/65/18's with just the 3" lift and some trimming.
    Also i wouldn't recommend either type of lift you mentioned, but that's beside the fact.
  7. Aug 19, 2012 at 5:32 PM
    Jacobrobertson200
    Jacob
    Louisiana
    2000 Tacoma 4x4.
    its just the look i like. im just worried about the hubs clearing. what wheels would i need to order. i cant find them for 2000 tacoma. just 01-04s and chevys
  8. Aug 19, 2012 at 5:46 PM
    Davidd
    Davidd Well-Known Member
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    My buddy on here has some he has been trying to sell. I had to use them for my alignment because of the offset of my actual wheels but the worked on mine. However my truck is a 2002
  9. Aug 19, 2012 at 6:05 PM
    Jacobrobertson200
    Jacob
    Louisiana
    2000 Tacoma 4x4.
    Can you send me his number. What kinda wheels are they.
  10. Aug 19, 2012 at 6:56 PM
    Davidd
    David
    San Jose, CA
    02 PreRunner
    Truck Built by DMZ
    Jughead is his user name. PM him. I am sure he can send you the model specs on the wheels. But I do know they were rock stars
  11. Aug 19, 2012 at 7:04 PM
    TexasTacoma37
    I'll ask for a third time what the actual tire size is that you want to run.
  12. Aug 19, 2012 at 9:26 PM
    Jacobrobertson200
    Jacob
    Louisiana
    2000 Tacoma 4x4.
    33x12.5-18. I'm not worried bout the tires rubbing!! I just want to know if hubs will clear!
  13. Aug 19, 2012 at 9:29 PM
    Jacobrobertson200
    Jacob
    Louisiana
    2000 Tacoma 4x4.
    Thanks davidd
  14. Aug 19, 2012 at 9:30 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    hubs will clear? clear your calipers?
    the tires are what you need to worry about, not the wheel as much per se, hence why keith is asking about your tires.
    the year of the truck doesnt matter as long as theyre 6 lug and the same lug dimensions.
    my wheels were run on an 04 4runner, then a 2010 tacoma before I put them on my truck
  15. Aug 20, 2012 at 7:51 AM
    TexasTacoma37
    What do you mean by "hubs will clear". And why aren't you worried about rubbing? You should be.
