Please help! 265/75r16 tires rubbing...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by davidortiz61913, Aug 19, 2023.
  1. Aug 25, 2023 at 6:46 PM
    #41
    davidortiz61913
    davidortiz61913 [OP] Member
    David
    San Diego
    2021 Voodoo Blue Tacoma TRD Off-Road
    One thing I did do is measure the distance between the top of the tire and the wheel arch. I’m at 5” on the passenger side and 4.5” on the driver side…. Thoughts?
  2. Aug 25, 2023 at 6:57 PM
    #42
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
    Front or rear?
    Measurements should come from hub center to wheel well bottom. My rear 3" lift 2nd gen Access Cab has 25" from hub center to wheel well bottom. Taco lean is what you have with .5 difference in measurements.
  3. Aug 25, 2023 at 7:07 PM
    #43
    davidortiz61913
    David
    San Diego
    Alright so I’m looking at 20” on passenger and 19.5” on driver
  4. Aug 25, 2023 at 7:08 PM
    #44
    davidortiz61913
    David
    San Diego
    Those were front measurements. I’m not having problems in the rear
  5. Aug 26, 2023 at 3:03 AM
    #45
    Tiedie
    David
    WFOY
    Stock measurements no lift is what you have there. My opinion you need to lift a little up front with coil springs maybe 2"-3" all this money your throwing at your issue and it's not solving anything.
    If you're running hard on washboard and rubbing coil springs probably worn out.
    Fix that and you should be fine,but while you're in there you need to do the ECGS bushing too.
    I spent something like 3k for my complete Dobinsons suspension and ECGS bushing installed. Which gave me 3" all the way around and absolutely no rubbing.
    Good luck.
  6. Aug 30, 2023 at 9:47 AM
    #46
    babylon5
    babylon5 Well-Known Member
    David
    2015 Tacoma Double Cab TRD Sport
    Is the 265/70/17 size for the 3rd gen sport?? Diameter 31.6
    I have a 2nd gen Sport and they are 265/65/17 Diameter 30.5 and never a hint of rubbing but they are 1 inch smaller in diameter..
  7. Aug 30, 2023 at 10:03 AM
    #47
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    make sure nothing is bent.
    Shawgf2000 and Junkhead like this.
  8. Aug 30, 2023 at 11:42 AM
    #48
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    No, 3rd gen stock sport are 265/65/17 too.
    Junkhead likes this.
  9. Aug 30, 2023 at 12:30 PM
    #49
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I don't see how shocks or springs could be blamed for the rubbing because it's the job of the bump stop to limit up travel. Springs and shocks might reduce the chance of a bottom out, but they are not the ultimate limiter.
    I have 33's and have not noticed any rubbing even when flexing out the truck off-road, but I think it's possible that high speed driving over rough terrain could result in additional up-travel.
    I went to the garage and took these measurements on the front driver side:
    top of tire to the top of the wheel well: 7.25"
    LCA to bump stop seat: 3.875"
    And, just for reference, center of hub to edge of fender flare: 22.5" (~2" lift)
    The IFS motion ratio is about 2-1, thus the wheel will travel up 3.875" * 2 = 7.75" when the rubber bump stop is completely flattened. This leads me to believe that rubbing will occur at the ultimate limit of up-travel (7.25" < 7.75").
    Stock tires have a radius of about 1.25" smaller, so my top of tire to the top of the wheel well would be about 8.5" and thus not rub (8.5" > 7.75").
    The OP's tires have a radius of about 0.75" smaller, so on my truck would have top of tire to the top of the wheel well distance of about 8" and so shouldn't rub either, but it's pretty damn close and there is error in all of these measurements.
    Chew and Junkhead like this.
  10. Aug 30, 2023 at 12:41 PM
    #50
    gudujarlson
    Minnesota
  11. Aug 30, 2023 at 12:53 PM
    #51
    gudujarlson
    Minnesota
    After watching the above video again, I noticed he gives a more accurate motion ratio of 1.85 - 1. This makes a significant difference in my calculations.
    Max wheel up-travel: 3.875 * 1.85 = 7.17"
    33.1: 7.25 > 7.17 so no rub
    31.6: 8 > 7.17 so no rub
    30.6: 8.5 > 7.17 so no rub
    And for added kicks and giggles:
    35: 6.3 < 7.17 so yes rub
    Approximate diameters are for 255/85r16, 265/75r16, 265/70r16, 35x12.5 respectively.
    This agrees with my assumptions to date. Until you get to 35” you don’t need to worry about bump stop spacers, upper wheel well tubbing, or body lifts.
    OP, something fishy is going on. Have you measured the diameter of your tires? Have you checked to see if your LCAs, bump stops, etc. are bent, cracked, or otherwise damaged?
    This all assumes that the IFS and frame do not bend when bottoming out, which we know is not true but don't have any easy way of measuring or estimating. We just have to assume Toyota designed the truck in a way to make it a non-factor except in the very extreme cases.
    Junkhead, Crash415 and Chew like this.
