Please Help!!! 275/70R17 on stock 17 rims
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clankey, Feb 27, 2010.
  1. Feb 27, 2010 at 3:01 PM
    clankey
    clankey [OP] Well-Known Member
    St. John's, NL
    2010 Double Cab TRD Sport
    Roof Rack, Soft Tonneau, Running Boards, DDM HID's, Skid Plate, 3" lift, 275/70R17 BFG AT TA's
    ok I am almost done but still need a little help. Is anyone running 275/70R17 BFG AT TA on a 3inch lift ( i have a 20100 Double cab TRD) with stock rims? I have everything ordered but now I am nervous that I am going to have clearance issues. I spoke to the guys at Tuff Country and they said it would have proper clearance but I am seeing some posts that it will not.
    IF you have pics of this setup I would really appreciate seeing them and hearing your advice.
    Again 275/70R17 BFG AT TA on stock 17's
    Thanks again EVERYONE!!
    Clankey
  2. Feb 27, 2010 at 3:22 PM
    jodiddly33
    jodiddly33 Well-Known Member
    Jonah
    DFW
    2010 Golf TDI
    You MIGHT need spacers or ucas but I'll let someone more knowledgable give you a for sure answer :)
  3. Feb 27, 2010 at 4:02 PM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I've been told by others that in order to do a 32" diameter tire you need a about an inch of lift. If you got the rear spring assembly TSB done by the dealer and you call Downsouth Motorsports and have them fix you up with a set of 5100 Bilstein shocks you'd be all set. You'd also have a noticable improvement in ride quality.
