Please help a newb with rims sizing
Discussion in 'Wheels & Tires' started by KingMoo, Sep 5, 2011.
  1. Sep 5, 2011 at 8:18 PM
    KingMoo
    KingMoo [OP] Well-Known Member
    Calgary
    Tacoma TRD Sport
    -LIFT: 5100 bilsteins all around (set at 0.85 in front) eibach coils 2" AAL -D-RINGS -BED COVER rollaway
    I just ordered some Wrangler Duratracs (LT265/75R16 BLACK Load Range C) but I have no clue how to size rims for a tire. I checked a calculator but I'm still unsure.
    Can you pleas help me pick the right rims? I'm currently looking at some Mickey Thompson Classic II Black Wheel
    16X8 , 8 on 6.5 Bolt Pattern
    BackSpace = 4in
    Max Load = 3100lbs
    Finish = Black
    Hubcentric = NoOffset = -13
    link
  2. Sep 5, 2011 at 8:22 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    those should work. WHEELS (not rims ;) ) for sizing just depends on the diameter (matching __/__r16 tires with 16" wheels), IIRC. backspacing and all that affects weather or not it will clear brake calipers and whatnot
  3. Sep 5, 2011 at 8:27 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Those should work.
  4. Sep 6, 2011 at 8:03 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    anyone running with these wheels? I just talked with a parts guy and he thinks this style of wheel has issues with the caliper.
  5. Sep 6, 2011 at 11:18 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Those will not work, they are not the correct lug pattern. you need 6 on 5.5
  6. Sep 6, 2011 at 11:39 AM
    KingMoo
    Calgary
    Tacoma TRD Sport
    called Mickey Tompson and they said 16"s definalty won't work and 17"s would have to be fit checked
    time to find a new wheel. anyone know a close cousin to the Classic ii?
