Please Help, Bad MPG
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sport66, Oct 27, 2015.
  1. Oct 27, 2015 at 10:07 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    First thing, determine your truck's odometer error. Fill up to first click. Zero one of your trip odometers and run 50 miles per mile markers or GPS (drive 25 and turn around for 50 miles back to the same pump). If trip shows doesn't show 50, you have some error. 49 is under reporting by 2%, 51 is over reporting by 2%. 47 or 53 is 6% (3/50). Lets' say your trip show 48 miles, but mile marker/GPS shows 50. So for the future, add 4% to the miles shown to get true miles. If trip is over 50 miles, subtract 4%.
    If over 50 subtract the percentage for true miles. Fill up again to first click AT THE SAME PUMP. You now have accurate miles and fairly accurate gallons, do the math. (my truck will take up to 2.5 gallons from first click, but I don't do it unless I'm on a road trip and going to burn at least 3 gallons or more right away, because of the charcoal filter). Pumps can and do vary on "click-off", both pump to pump at the same station, and even depending on how many vehicles are filling up at the same time.
    Don't know your oem tire size, but you probably have 7-9% odometer error with those tires compared to most oem Tacoma tire sizes.
    You really can't go by your fuel gauge, the pump at the station is much more accurate. If you had 3 Tacoma's, all showing exactly 1/2 full, there could be 3-4 gallons difference in what is actually in the tanks of the 3 trucks.
    sport66[OP] and hack4875 like this.
  2. Oct 27, 2015 at 10:07 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    265/70/16 is stock tire size.
    Torspd likes this.
  3. Oct 27, 2015 at 10:09 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    OP, you don't have to run the tank dry to get MPG. Fill it up, reset your trip odo, drive til the next time you need/want to get gas, use # of gallons from that fill up and miles on trip odo to calculate mpg. Also, has your speedo been recalibrated for those tires?
  4. Oct 27, 2015 at 10:10 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yup. Your stock tires are larger than OEM. Which will make it seem like you are getting worse gas mileage. Since it is showing less miles driven than you actually are going. Thus "less" MPG.
    That being aside from a higher coefficient of friction from wider tires, more weight, higher stance, and possibly low tires.
    Make sure yoir tires have plenty of air pressure. That will really help.
    sport66[OP] likes this.
  5. Oct 27, 2015 at 10:14 AM
    Kbel
    Kbel Well-Known Member
    Kevin
    Fort Worth
    2018 MGM DCLB
    You do not have to run it dry. Run it to 1/4 to 1/8 of a tank or so. Gas up and write down gallons put in/used and miles driven. You will also know how much gas is left in your tank. Since it is new to you...well you never know what the last owner did-I'll leave it at that. I was skeptical on my new truck until I put in enough gas to verify quantities with the photo I posted above. I drive 3k per month so it did not take long.
  6. Oct 27, 2015 at 10:19 AM
    sport66
    sport66 [OP] Member
    johnny
    09 sport
    Do I disconnect both or jus one and drive how far
  7. Oct 27, 2015 at 10:22 AM
    Kbel
    Kevin
    Fort Worth
    2018 MGM DCLB
    Good call^^^on speedo calibration. Compare with GPS or phone app. See if close. Might as well verify that as well.
  8. Oct 27, 2015 at 10:25 AM
    T4RFTMFW
    Negative terminal can be pulled, most leave it off for an hour. Then just reconnect it and drive normally.
  9. Oct 27, 2015 at 10:34 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    A lot going on here. OP's truck is a Sport. 265-65-17 stock size tire. His 18" tires are roughly %10 bigger than stock, divide milage by %10 and add that to original milage for roughly true miles driven. Divide the roughly true milage by gallons added for mpg. Heavier wheels, heavier tires, slightly lifted is not going to be stellar for mpg's.
    Torspd likes this.
  10. Oct 27, 2015 at 10:40 AM
    mred20
    mred20 Well-Known Member
    Garner, NC
    2015 Gray Tacoma Limited
    My stock dclb Limited has 265/60/r18 tires and I have checked once and am getting 16.4 mpg. I did check the speed with a gps and it's off by 2 mph.....if it shows 60, I am really doing 58.
  11. Oct 27, 2015 at 10:50 AM
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    What does MPG stand for
    :p
    (I get 8 feet per gallon)
  12. Oct 28, 2015 at 6:06 AM
    edm3rd
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    MPG = Miles Per Gallon
  13. Oct 28, 2015 at 6:10 AM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    I have a stock 09 sport and I consistently get 20 mpg.
    Just for reference.
  14. Oct 28, 2015 at 9:52 AM
    Oregon TRD
    Ross
    2005 Mall Krawler
    IWFJ
    I Was Fucking Joking
    T4RFTMFW likes this.
  15. Oct 28, 2015 at 2:28 PM
    #35
    sport66
    sport66 [OP] Member
    johnny
    09 sport
    Lol,,that's why I didn't answer...figured your stupid, but you can't be that stupid..lol
  16. Oct 28, 2015 at 2:29 PM
    #36
    sport66
    sport66 [OP] Member
    johnny
    09 sport
  17. Oct 28, 2015 at 2:32 PM
    #37
    Oregon TRD
    Ross
    2005 Mall Krawler
    And if you look at the bottom of my post , that should be a damn clue too!!!!!:D
    FPG....hence my 35" tires, lift etc.....I don't get MPG's, I get FPG's
    Fuck I hate explaining jokes!
  18. Oct 28, 2015 at 2:33 PM
    #38
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    How many miles on the spark plugs?
    Capt Jrod likes this.
  19. Oct 28, 2015 at 3:08 PM
    #39
    esse10
    esse10 Well-Known Member
    Texas
    05prerunner SR5 DBLCAB
    Like these guys said, DO THE MATH. Fill the tank at a specific pump and let the pump stop on it's own when full, drive a few miles (25-30) then go back to the exact same pump and fill the tank again exactly as before. ya done, do the MATH.
  20. Oct 28, 2015 at 3:19 PM
    #40
    Iasco
    Iasco Well-Known Member
    I'm avg. 18 mpg
    Stock tire size. One inch lift w/ level.
