Please help before I roll this truck off of a cliff.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by btgann02, Sep 19, 2024.
  1. Sep 19, 2024 at 11:53 AM
    btgann02
    btgann02 [OP] Airborne Mekanic
    Billy
    2007 Blue Tacome TURD Off Road
    Teeny lift and wheels
    Howdy, I have a 2007 Taco 6 Cyl TRD off-road. Just recently found the time and funds to do some much needed work to it. Just replaced the AC Compressor, belt, both Idler Pulleys, as well as the AC Clutch Relay.
    The Refrigerant levels are solid, and the system is blowing air; but it will not cool the air, the ac light is blinking still and the clutch will not engage. Any recommendation will be much appreciated, I'm at my wits end with this truck.
  2. Sep 19, 2024 at 12:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It has been reported that with an aftermarket AC Compressor you will need to move the original rpm sensor from the old AC Compressor to the new aftermarket compressor.
    mtip, Torspd, Too Stroked and 3 others like this.
  3. Sep 19, 2024 at 12:57 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Does the compressor engage for a few seconds and then disengage when the light starts flashing or does it not engage at all?
    btgann02[OP], Jimmyh and TnShooter like this.
  4. Sep 19, 2024 at 1:45 PM
    btgann02
    Billy
    Yes, the clutch will engage but the light will blink.
  5. Sep 19, 2024 at 1:51 PM
    btgann02
    Billy
    Jimmy do you have a part number for the OE sensor or a link to toyotas website with it?
  6. Sep 19, 2024 at 2:18 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    If the clutch is engaging, what are your line pressures on both high and low sides?
  7. Sep 19, 2024 at 2:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    So the A/C Amplifier isn't seeing the correct signal from the compressor Lock Sensor.
    Did you keep the one from your old compressor?
    Have to fix the lock sensor problem before we can check pressures.
    Jimmyh likes this.
