Please Help! Chainsaw bogs and dies when revs
Discussion in 'Garage / Workshop' started by Airun, Oct 2, 2010.
  1. Oct 2, 2010 at 7:13 PM
    Airun
    Airun [OP] Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    I used my Stihl ms260 last weekend and worked great. The saw is 5 years old and been trouble free, still on original spark plug and been using Stihl synthetic 2 cycle oil. Went to cut wood tonight and it was hard to start and seemed to idle fine (perhaps faster than normal) but when I went to rev it to cut the motor would bog and die. I did run last years gas last wknd, but dumped it and made fresh today. Borrowed a new plug fro my dads saw and tried it with same result. Air filter is clean. Seems lime maybe a jetting problem? I'm gonna pick up new plug tomorrow. Any thoughts, ideas, suggestions or similar experiences? Thanks
  2. Oct 2, 2010 at 7:15 PM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    sounds silly but is the choke still on?
  3. Oct 2, 2010 at 7:16 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Are you sure you mixed the fuel/oil right?
  4. Oct 2, 2010 at 7:19 PM
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    I had the same trouble with my 2 cycle weed eater. My dad used to be a small engine mechanic and gave me a suggestion. He said I should take the muffler apart and see if it was clogged up with carbon. There is probably a little screen in there that has carbon buildup on it. If that is the case you can burn it off with a torch. Or you can just remove the screen. That was my problem and this worked for me, so good luck!
  5. Oct 2, 2010 at 7:42 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    The screen is a spark arrestor. Manditory in California because of wild fires, now I beleive they are everywhere, good idea to clean it, also check the brake on the blade, I know basic but start easy, I just went through this, my saw would run fine then as soon as I hit the gas, blah... nothing. I took old gas out, added some sta-bil gas treatment to new gas finally got it to run normal. I think the problem is ethanol in gas, espesially gas that sits for a while. I read somewhere they want you to drain gas after every use. Pain in the ass. SO i use gas additive in all my 2 stroke gas mixture, either sta-bil, lucas, hell even sea foam says it will keep 2 stroke gas good for a long time. Poin is get it running add the snake oil, and dont let it gum up . Hope this helps. Kevin
  6. Oct 3, 2010 at 1:30 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Both good suggestions, 2 strokes can be real finicky at times, sounds like maybe running a little lean, did you pull the newer plug & look at it to see how its burning ? If it looks "too clean" , I'd try adjusting the air/fuel mix screw, your statement about it "idling a bit faster than normal" leads me to think its running lean, good luck !!
  7. Oct 3, 2010 at 11:44 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Gas loses most of is oomph after three months. Stabilizer will keep the varnish away, but won't stop the gas from evaporating. No matter how tight the seal on the tank is, replace the gas every three months and use stabilizer. The stihl oil from the dealer will have stabilizer already in it, they will usually tune it for you for free (only if you bought it there)
    I assume you checked/cleaned your air filter.
  8. Oct 3, 2010 at 11:48 AM
    Johnny M50
    Johnny M50 Well-Known Member
    N NJ
    09 Tacoma, V6 Sport 4x4,debadged, Super White
    K&N "warm" air intake
    In my Stihl's I found that I had to use mid or hitest gas mix, even the manual says that. Hopefully your using fresh fuel mix too, the stabilizers do work wonders,I use SeaFoam in the outboards, garden tractors, and motorcycle. Seems my fuel problems have damn near been eradicated.
  9. Oct 3, 2010 at 11:54 AM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i had the "clunk" (fuel pickup) get clogged on my Dolmar. check to make sure the "clunk" isnt plugged and the hose has no leaks... also, doublecheck all the fuel lines for leaks.
  10. Oct 3, 2010 at 12:26 PM
    Airun
    Aaron
    Show Me State
    Thanks for the help guys. I've tried all those things except running gas treatments through. The gas I ran last weekend probably gummed up the carb and I'm gonna have to take it somewhere to get it cleaned and rebuilt. Still having problem after new plug, but acts like its running too rich. Lots of black goo spewing out exhaust. I've tried adjusting low speed screw and to no avail.
    Removing the carb looks like a major PITA.
  11. Oct 3, 2010 at 5:44 PM
    RCBS
    RCBS Well-Known Member
    Harden your bark, there are storms on the horizon.
    Change fuel filter. Carb settings should not be changed if it ran fine when you put it up. Change out fuel, disassemble carb and clean jets with a small drill bit or torch tip cleaner. New plug prolly wouldn't hurt either. Reassemble, fresh fuel...should be good to go.
  12. Oct 3, 2010 at 6:00 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    Too much oil, And needs new spark plug. How dull is the chain
  13. Oct 3, 2010 at 6:07 PM
    johnny12345
    johnny12345 Well-Known Member
    vancouver island, canada
    09 tacoma SR5
    don't mess with the jets/air fuel mixture too much. you can adjust the idle a little but I would'nt mess with the highs and lows. sounds like you got shitty fuel. What did you mix your gas at?? What did the plug look like when you took it it out?
    Check for holes in the rubber hose/boot that goes from the carb to the cylinder? Is the chain spinning at an idle? Does the clutch look normal? all springs in tact, everything look fine?
  14. Oct 3, 2010 at 6:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    this. x2
  15. Oct 3, 2010 at 6:11 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i was having a starting/running prob with my troybilt weedeater a few weeks back. i cleaned the foam filter behind the breather/before the carb and also sprayed some pb blaster small engine tune up stuff into the carb and let it sit for a couple hours. apparently, as hot as it had gotten in my garage....the gas that was still in the carb had kinda gelled up, but the pb blaster stuff melted it down real good. fires right up now.
  16. Oct 4, 2010 at 6:52 AM
    Airun
    Aaron
    Show Me State
    Thanks for all your input guys, if nothing else I learned alot. I finally figured it out. When I split the plastic air filter canister for cleaning, apparently the spring on the plastic shaft that holds the choke shutter open became dislodged so the vacuum from the carb was pulling it closed, thus the reason it seemed like it was running very rich. It only took my dumb ass 5 hours of pissed off labor and nearly tearing the saw apart to figure this out. Once I placed it back in the groove and fired it up, Viola! Running like new again. Its always the little simple things that trip me up. Cut a couple ricks of oak last night with brand new chain and performed like a champ.
    Thanks again TW members for all the helpful advice!
