Please help. Check engine light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Bwainwright03, Nov 22, 2021.
  1. Nov 22, 2021 at 4:55 PM
    Bwainwright03
    Bwainwright03 [OP] Member
    Brandon
    2012 Toyota Tacoma 4.0L V6 2WD
    Stock and trying to keep it that way.
    Any help would be much appreciated. Check engine / trac off light both came on. Throwing code P2441 (secondary air injection system switching valve stuck closed bank 1) Please send me any info on what to check or how to diagnose? Let me know kids✌❤️
  2. Nov 22, 2021 at 5:06 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    It's a very common problem in 2012 trucks, you might want to check with your dealer and see if you truck is cover under Special Service Campaign 20TC01 because the parts for the system are kinda expensive.
  3. Nov 22, 2021 at 9:22 PM
    Bwainwright03
    Brandon
    Thanks for the info. Will call dealer tomorrow to investigate✌
  4. Oct 12, 2022 at 11:36 AM
    hewitt-tech
    hewitt-tech Dont Replace SAIS, Bypass It!
    Lexington, SC
    Secondary Air Injection System Bypass Kit
    If it is not covered under warranty I caution replacing the failure prone components. I strongly warn again using aftermarket part as well. Either of these options will only lead to future failure and more expense.
    The Secondary Air Injection is failure prone and you can spend all day reading horror stories of owners trying to address. That said, all those who run into this issue after the warranty/recall highly recommend the Bypass Kit. If you have any questions do not hesitate to reach out, DM or give us a call.
    What Does the Secondary Air Injection System Do?
    https://www.tacomaworld.com/threads/what-does-the-secondary-air-injection-system-do.780847/
    What Do My Secondary Air Injection Error Codes Mean?
    https://www.tacomaworld.com/threads/what-do-my-secondary-air-injection-error-codes-mean.780848/
    How to Fix Secondary Air Injection System?
    https://www.tacomaworld.com/threads/how-do-you-fix-the-secondary-air-injection-system.780849/
    outdoorgb likes this.
