Please Help !! Did tune up and now it bogs
Discussion in '4 Cylinder' started by mebedave, Jul 18, 2010.
  1. Jul 18, 2010 at 12:16 PM
    mebedave
    mebedave [OP] Member
    Dave
    Kansas
    basic truck
    I hope someone can help me I lost!!!!!!!!!!!!!!!!!
    I have a 1996 Tacoma 2wd reg cab 2.4L 5spd. 135,000 miles
    I did a tune up today and now it has a bog when you step on gas.
    New Dealer spark plugs K16R-U gap .40n (are these the right plugs ?)
    New autolite wires
    New BWD cap and rotor
    Took TB all the way off and cleaned reinstalled with new gasket (It was REAL dirty)
    Things I Have tried to remedy the problem so far:
    I put old wire cap and rotor back on still bogs
    I pulled each plug back out check gaps .40 good
    I think I will put the old plugs back in and try it again
    I Think I got all hoses wire connections back on I’ll check for 5th time
    I used starter fluid on all vacuum hoses checking for leaks, all is good
    I had the battery discounted overnight and all day today
    Please help
    I FIXED IT, or I should say it fixed itself. Took it for a long drive and now it's good.
  2. Jul 19, 2010 at 8:48 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Use carb cleaner to check for leaks. Starting fluid(ether) will find leaky sparks too and explode:(
  3. Jul 19, 2010 at 8:51 AM
    Blackened Taco
    Blackened Taco Well-Known Member
    Tony
    Virginia
    2005 AC 4WD TRD Sport Tacoma Speedway Blue
    3 inch suspension lift, 16 inch TRD FJ Cruiser black alloys, 33 X 12.5/16 Swamper Trxus M/T, Line-Xed Toyota skid plate, TRD exhaust, TRD cold air intake, Full tint to match factory tint, In channel wind deflectors, Custom wired hidden XM, Black shorty antenna, Black background headlights, Sockmonkey TRD decals, Kenwood 5120 HU with navigation, Boston Acoustic SL60 front compnonent speakers, SL65 rear speakers, Grillcraft lower mesh grille, Black badging, AromorTech Offroad rear bumper and rear shackle flip kit Access tonnosprt cover, 12 volt power adapter wired in under the dash for standard plug in items. Recently added Devil Horn Toyota Logo, Thanks Andres.
    Put your factory parts back on it (new parts) and get rid of that aftermarket junk. Toyotas hate after market iginition components, put the original stuff back in.
  4. Jul 22, 2010 at 6:15 PM
    larryde09
    larryde09 Well-Known Member
    Larry
    Rochester, NY
    (Traded-in) 06 2.7L 5-spd SR5 4x4
    K&N Intake, Magnaflow Cat-back Exhaust, Altezza Tail Lights, Pop&Lock Tailgate Lock, Extang Trifecta Tonneau Cover, PIAA foglights with stock switch, DrawTite Hitch, OBX Shift Knob, Hood Protector, Vent Visors, DIY step bars/sliders/running boards, DIY Bed Lights, DIY Running Board/Ground Lights, DIY Tailgate Electrical Box (12V socket, voltage and current gauges), DIY Internal Lighting (coming soon), Aftermarket switches in stock dash blanks, Sony Head Unit, Illuminated 4x4 switch mod
    For future reference, maybe it was a computer reset issue?! Maybe the plugs were super old or the air flow was so bad that the computer was retarding the ignition or the mixture was rich, etc. Unplugging the battery for a few minutes forces the computer to reset and it "relearns" the air flow and spark characteristics.
    It's possible that the computer was running on the old tune and was in the process of relearning the new one....or, the computer did reset and it was bogging during its learning process.
    Just my thoughts...it could have been as simple as a dirty or loose connector (e.g. throttle body) that "magically" made a good connection after some driving.
  5. Jul 23, 2010 at 2:45 AM
    mebedave
    Dave
    Kansas
    basic truck
    Yes.... I think your right
    Thanks
  6. Jul 23, 2010 at 2:59 AM
    mebedave
    Dave
    Kansas
    basic truck
    I took the aftermarket stuff back and put the 14 year old wires,cap and rotors back on. Sense my local dealer does not have tune parts in stock for my rare 1996 2wd 2.4L tacoma I'll need to order them
    Thats Lewis Toyota of Topeka Kansas
