PLEASE HELP - driveline vibes after ECGS bushing install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by SpeySquatch, Apr 9, 2018.
  1. Apr 9, 2018 at 8:05 AM
    SpeySquatch
    SpeySquatch [OP] Function over Form
    2016 TRD OR DCSB
    Calling all driveline PROS
    Hey Fellas. Got a driveline question. I have done all the work I think you will need to answer.
    I have been having this weird driveline vibe from 38-44MPH and I have a feeling my rear axle shims are not steep enough. The vibes are happening at about 1200rpms the most when cruising, more-so on deceleration even when foot isn't on the gas or break. Also, I disconnected the battery to work on some electrical, when i got it hooked back up and drove there truck the vibe was gone for about 10 miles, then came back WTF?
    Truck Details:
    • 2016 4Dr TRD OR
    • 2" OME Lift Medium weight
    • 3/8" carrier bearing spacer (OME)
    • Full rear dakar pack (no leaf removal)
    • ECGS BUSHING INSTALLED!
    • Drives amazing except for 38-44mph
    • Driveline has been professionally inspected and balanced
    • Shims on correct way with skinny tapered end forward
    Please let me know if I need steeper shims or what? I have gone all the way from 1/16" spacer to 1/2" spacer in the CB with no luck.
    I used Spicer parts calculator to figure this out. I measured the angles with a phone app and used same side of phone to measure angles without phone buttons interfering.
    http://spicerparts.com/calculators/driveline-operating-angle-calculator
    Someone please give me some insight because I cannot figure this out for the life of me.
    Thank you for any and all help!
  2. Apr 9, 2018 at 8:30 AM
    ajmogen
    ajmogen Well-Known Member
    Aaron
    Wisconsin
    OR MT TACO T4R YARIS MT Corolla Hatchback MT
    Maybe it's your tires. Did you check your tire balance?
    tacomabro69 likes this.
  3. Apr 9, 2018 at 8:31 AM
    SpeySquatch
    2016 TRD OR DCSB
    Yes, tires are good. I have even messed around with PSI.
    The vibe is very parabolic and harmonic in nature
  4. Apr 9, 2018 at 8:46 AM
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Are you sure that you actually need messing with CB drop kit? I've read conflicting reports about it, and with only 2" it's a hit and miss. There was something about diff angle in relation with first driveshaft (cb) needing to be parallel... Damn it, I wish I had those schematics
  5. Apr 9, 2018 at 8:47 AM
    SpeySquatch
    2016 TRD OR DCSB
    So you think take the spacer out? I tried this and it seemed the same
    Please find the visual if you can
  6. Apr 9, 2018 at 9:05 AM
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    Since you tried removing it already, and it doesnt work for in your situation, that sucks
    I'll look for it anyway, since I'm getting my 2" lift together, I might need it...
  7. Apr 9, 2018 at 9:31 AM
    Bastek
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
  8. Apr 9, 2018 at 9:51 AM
    cruxx
    cruxx Well-Known Member
    Huy
    2017 TRD Sport
    Diff drop and/or carrier bearier drop
  9. Apr 9, 2018 at 10:01 AM
    SpeySquatch
    2016 TRD OR DCSB
    Have both. Still vibes at small speed range 36-43mph
  10. Apr 9, 2018 at 10:12 AM
    SpeySquatch
    2016 TRD OR DCSB
    Thanks I appreciate it. The truck drives amazing except for these vibes at 1000-1400RPMS between 36-43mph. Biggest Pain in the A**
  11. Apr 9, 2018 at 10:27 AM
    cfagan14
    cfagan14 GaTacoma
    Atlanta
    2017 DCLB 4X4 TRD OR Quicksand
    Get a one piece drive shaft. Seems to be the cure for the 2nd gen guys.
    lynyrd3 likes this.
  12. Apr 9, 2018 at 10:31 AM
    SpeySquatch
    2016 TRD OR DCSB
    Yah...but what about strain on the transfer case? This seems to be an issue as well and more $$$
  13. Apr 9, 2018 at 10:34 AM
    cfagan14
    cfagan14 GaTacoma
    Atlanta
    Doesn’t seem to be an issue for the 2nd gen guys after the swap.Just helped my buddy swap out his drive shaft and solved all his vib issues. And welcome to lifting Tacoma’s. New drive shaft is like 500 from Tom Woods.
  14. Apr 9, 2018 at 10:36 AM
    here4cake
    here4cake Well-Known Member
    OP, as you suspect, it's a question of your pinion angle, and can be solved with appropriate axle shims. When you accelerate, the pinion moves up by about 2*, and moves down when you get off the gas - this is why your vibrations are worse when cruising and decelerating.
  15. Apr 9, 2018 at 11:07 AM
    SpeySquatch
    2016 TRD OR DCSB
  16. Apr 9, 2018 at 11:57 AM
    CZ5ANM Taco
    CZ5ANM Taco Well-Known Member
    BC, Canada
    2016 DCSB Manual 35x11.5s
    Front Suspension King Ext Fronts 700# Icon UCA delta joints JD fab spindle gussets All Pro cam tabs DuroBumps Warfab steering sleeves Rear Suspension Old Man Emu leafs -Radflo Ext travel rears Timbrens ubolt flip kit SCS stealth 6 Wheels 35x11.5 Maxxis Razr [ 34.5 x 9.75 on 8.5 rim not on truck] Heavy Stuff Relentless front bumper Smitty 3rd Gen winch Big County Customs skid plates Arc One industries rear HC bumper RCI sliders Misc Arb dual compressor Arb rear locker Pelfreybilt fuse panel tray Cali raised ditch light mounts Cali raised bed stiffeners 5th Gen 4runner LED fog lights Racks Retraxone XR tonneau Yakima load bars Sherpa Roof Rack Camping Smittybilt Tent Dometic CFX50 fridge
    In my local Toyota group, plus on here I see most guys running 3-4 degree rear shim. As well removing the carrier bearing drop with this combo should work better.
  17. Apr 9, 2018 at 11:58 AM
    SpeySquatch
    2016 TRD OR DCSB
    Awesome, thank you
  18. Apr 9, 2018 at 12:20 PM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    I know you said you checked the tires OP, but check the wheels and how they mount. Could be a bad mounting, runout/deformation on one of the wheels, anything. Even if all the ammo points towards driveline.
    Side note why aren't more people replacing the 2pc with a 1pc prop shaft? It's like a few hundred bucks and solves the carrier bearing/2pc the "right" way.
    I got 4 wheels brand new out of box from Fuel that had the lug holes drilled slightly off center and I went crazy trying to find my vibration from that. My tires and wheels balanced perfect but once driving on them it sucked.
  19. Apr 9, 2018 at 12:23 PM
    SpeySquatch
    2016 TRD OR DCSB
    But I have stock TRDOR wheels. You are saying check how the tires mount to the wheel? Man I wish you guys could feel the vibes, it definitely feels driveline related because there is NO steering wheel shake, just harmonic vibes
  20. Apr 9, 2018 at 12:24 PM
    bradshawnh
    Boston, MA
    Read my edited post above about the driveshaft. The 1pc driveshaft is the more expensive but fool-proof way to get rid of the CB issues and vibes without shims/spacers/etc.
    If you are on stock wheels, then likely this isn't an issue. I meant like where the wheels mount to the hub. If it's dirty or uneven you can introduce vibration there.
