Please Help! Engine Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by tylershane17, May 24, 2013.
  1. May 25, 2013 at 7:38 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Hook jumper up to another vehicle that's in good working order, and run it. If it runs fine, then its your alternator. If not, Fuel pump.
  2. May 25, 2013 at 7:54 AM
    tylershane17
    tylershane17 [OP] Back to Back World War Champions
    Tyler
    Northwest Alabama
    2007 TRD OFF ROAD DCSB
    Brushguard, Lift.
    Well looks like its gonna be fuel pump then.
  3. May 25, 2013 at 8:44 AM
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
  4. May 25, 2013 at 11:17 AM
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    Do I drop the tank or take the bed off to change the fuel pump?
  5. May 25, 2013 at 11:50 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    Have you ever taken a fuel pressure reading? That is something you should do before replacing parts.
  6. May 25, 2013 at 12:01 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm gonna guess EGR Solenoid. [​IMG]
  7. May 25, 2013 at 12:58 PM
    Fenwick1993
    Fenwick1993 Hillbilly
    Not Fenwick
    Chesapeake, VA
    96 Tacoma 5Lug, 2015 PreRunner
    Stonewall is the fattest 5 lug slug ever
  8. May 25, 2013 at 1:02 PM
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    I'm working on getting a fuel pressure gauge right now. And idk why it's not letting you watch the video.
  9. May 25, 2013 at 3:13 PM
    BamaToy1997
    Bill
    Navarre, FL
    Yes, a fuel pressure gauge would be the way to go. It will tell us if the problem is fuel related, or spark related. Now that we know you have good, solid voltage we can go from there. I just don't like trying to help diagnose something when the baseline voltage is questionable. Have you actually had it checked for codes? Not all codes will set a CEL.
  10. May 25, 2013 at 4:26 PM
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    I'm also working on getting a code reader. Should have both this evening and we'll find out what it's saying. Also if the timing chain is out of time could that be it? The truck has 170,000 miles on it and I have no idea if the owner before me changed it. I'm just thinking of some possibilities.
  11. May 25, 2013 at 5:29 PM
    BamaToy1997
    Bill
    Navarre, FL
    If you mean timing belt, yes, it does wear over time. (your profile indicates a 3.4) They do have weird engine operations when the wear, but I think as bad as you are describing, you have something else going on.
  12. May 25, 2013 at 5:35 PM
    dand
    dand Blood and tears
    Dan
    Newport News VA
    2021 DCSB TRD Sport Army Green
    I guess, clean or replace MAF. That sounds like what my 3.4 was doing, and that solved it.
  13. May 25, 2013 at 6:44 PM
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    Alright guys I replaced the TPS and that seemed to solve the problem. But now the cruise will not set and the light is just flashing. Also I have to bypass my gear shift button with the button beside it idk why it wont go into gear with that. Suggestions?
  14. May 25, 2013 at 6:55 PM
    tylershane17
    Tyler
    Northwest Alabama
    Brushguard, Lift.
    Well guys I had put the STOP fuse back in the wrong place and that fixed the cruise control and shifting problem so I have a 100% running truck now. Thanks guys!
