Please help! I can't decide!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jasen7, Jul 10, 2011.
  1. Jul 10, 2011 at 1:11 PM
    jasen7
    jasen7 [OP] Well-Known Member
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    Hey everyone! I am having a bit of a problem. I own a 2007 access cab 4x4 2.7 5 speed. I am getting ready to pull he trigger on buying the 5100's and AAL for a mild lift. The problem is, I can't decide on what tire size to go with. Most of my driving will be on the street but on the weekends it does see the back roads and some trails. Right now it has the stock, junk, 245 Dunlop's on it. I am having a hard time deciding between sticking with the 245/75/16's or going up a size to the 267/70/16's
    Will the 265's be to much for the 2.7 with stock gearing? I already know what tread pattern I want and where I am getting my tires. By the way, I am going with Treadwright again incase anyone was wondering. According to thier sizes, the 245's are a 30.7'' tire and the 265's are a 31'' tire. Also, what load range should I look at? Should I go with a ''P'' or should I jump up to a C,D,or E ?
  2. Jul 10, 2011 at 1:12 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    You can fit 265/75/16. Lots of folks with 4 cyls are running that size with no issues.
    245s would look ridiculous with a lift IMO.
  3. Jul 10, 2011 at 1:13 PM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Id go with 265/75/16 if I were you.
  4. Jul 10, 2011 at 1:16 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
  5. Jul 10, 2011 at 1:39 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Go 265/75-16s. Also, Treadwrights run a tiny bit big: a 265/75-16 in a Treadwright is a bit bigger than any 'new' 265/75-16. I advise against running an 'E' tire unless you feel you absolutely need the thicker tire. You'll be fine with a 'C' or 'D'.
  6. Jul 10, 2011 at 3:02 PM
    jasen7
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    Would a 265/75/16 load range ''P'' be alright to run on my truck?
  7. Jul 10, 2011 at 3:09 PM
    TexasTacoma37
    Yep, passenger tires are rated above the payload capactity of the Tacoma so you are good to go.
  8. Jul 10, 2011 at 3:18 PM
    Blacktacoma23
    Blacktacoma23 If your tires don't rub you can fit bigger tires
    CO
    2011 Mall Crawler/84'
    6" BDS DB, 37", Dirt King, Total chaos UCA's w/ Heims, Fox c/o's, 4-banger fenders, 37" Nittos, 4.88 w/ rear ARB, AP Expos, 17x9 Method beadlocks, cab mount relocation, "Insain fab" tub, 5% tint, 10" Rockford Fosgates, Magnaflow 18" custom catback exhaust, AFE intake, Trail Gear bumper, Crown brake lines F/R
  9. Jul 10, 2011 at 3:31 PM
    jasen7
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    Thanks guys! 265's it is!
  10. Jul 10, 2011 at 5:12 PM
    senor taco
    Monterey Bay, Ca
    What kind of tires do you plan on running?
  11. Jul 10, 2011 at 5:14 PM
    TexasTacoma37
  12. Jul 10, 2011 at 6:49 PM
    jasen7
    Jasen
    Jersey Shore Pa.
    2007 Tacoma 2.7l
    I am going with Treawright tires. Not sure if I am going to go with the Guard Dog M/T's again or the Warden A/T's:confused:
