Please help id source of knock….
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Dec 9, 2023.
  1. Dec 9, 2023 at 10:48 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    1st vid is just in park.
    2nd is shifting with the higher idle being park & neutral
    Other possible symptoms/clues/random stuff
    - Engine must be warmed up & it is more pronounced after at least one under longer higher load (20mins, highway) trip. Then if smaller trips are done, it continues.
    - Sometimes noise is more pronounced than others. Can’t really figure out under what circumstances.
    - Faint hum in background
    - Seemingly random blowing of more exhaust smoke than usual. Other times, even with noise, no excessive smoke.
    Smog check is all clear….
    - Rough idle
    - Timing advance at idle anywhere from 5-16-ish. Timing is set at 5.
    - Pulled the #1 plug. Looks ok. I think. Will post pic.
    - Idle can be rather high after driving - 950. Other times more like 780.
    Idle in drive, 550-600
    - I did the timing belt/water pump/pulleys about 2 months ago
    - Oh, & something that I don’t think I’ve heard before is a dripping or popping noise from inside the oil pan. Maybe this is normal & I’ve just never noticed it? I did install an oil pressure gauge. Seems ok, although I haven’t fully educated myself on it yet. After warm up it’s at about 12.
    - Engine vacuum test via the brake booster connection holds steady at 24.
    - I think I hear a very faint rattle at times on acceleration, right side.
    -& I do hear the noise in the vids from under the hood, left side, just too much background noise to make a good vid….
    https://youtube.com/shorts/ktiTCFzpj64?si=XOfZnf4C79dep8gE
    https://youtu.be/Sn4P-kyBdpc?feature=shared
  2. Dec 9, 2023 at 4:18 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    I couldn’t hear anything specific/noticeable in both vids
    But that plug looks like on the lean side
    No CE lite ?
  3. Dec 10, 2023 at 4:46 AM
    Kristi with a K
    Western MA
    Do you mean you couldn’t hear the knock? I know it was more faint in the 2nd vid & different in that it came & went, however to me, it’s continuous & pronounced in the 1st one.
    & no cel….
  4. Dec 10, 2023 at 6:11 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I couldn't hear the knock either. I had my sound turned up all the way on my macbook.
    Kristi with a K[OP] likes this.
  5. Dec 10, 2023 at 6:27 PM
    michael roberts
    michael roberts Well-Known Member
    san diego
    07,4x4, white, AC.
    powder coated hood support.
    You can hear it in the first video, first impressions are that it sounds more like an exhaust leak, but I'm no expert.
  6. Dec 13, 2023 at 11:56 AM
    Kristi with a K
    Western MA
    Flex plate has been suggested. I took the cover plate off & couldn’t see anything. I’m going to go back in with a borescope….
