Please help me diagnosis this sound.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dgoode9, Sep 18, 2022.
  1. Sep 20, 2022 at 10:11 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Balance shouldn't be needed after a Universal joint replacement. They are screwing you. Take somewhere else or do it yourself.
    wilcam47 and Dm93 like this.
  2. Sep 20, 2022 at 10:11 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Agreed, there shouldn't be a need to rebalance the driveshaft providing everything is clocked the same as it came apart when it is reassembled.
    Would it be a good idea to rebalance? Probably but I've done countless ujoints at the shop and never had an issue after.
  3. Sep 20, 2022 at 10:15 AM
    MSgt O
    MSgt O Well-Known Member
    2013 Tacoma
    If youre in Michigan, Ill swap them for you! and your CVs look GOOD...no slung grease..I think they think you;ll fall for the ol this is bad and thats bad and its going to cost you one MILLION dollars....take it somewhere else. Ask to to have the U joints changed, and then if your squeak disappears, which by the sound of your video, changing pitch as you accelerate, Id bet my next paycheck or 3 its dry ass U joints squeaking....EDIT...just saying, Columbus is 6 hours from me, and the weathers beautiful in Northern Michigan right now....
    wilcam47, Dgoode9[OP] and Dm93 like this.
  4. Sep 20, 2022 at 11:06 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    replace all 3 REAR U joints and carrier bearing ~ 120-150 in parts.
    That sound is 100% not the CV.
    wilcam47 and nudavinci64 like this.
  5. Sep 20, 2022 at 11:13 AM
    balls47
    balls47 Well-Known Member
    Western Colorado
    99 TRD OR, 2014 DCLB TRD Sport
    I agree totally !
  6. Sep 20, 2022 at 11:15 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    99.9% its the U-Joints and/or Carrier carrier for sure. I just went through that. My first thought was carrier bearing but I figured a good time to do the U-Joints and def was needed. You don't need to rebalance the shaft if you mark exactly where it was bolted up. Before removing from the truck mark where it all lines up so you can put it in the same way. Each connection point on the drive shaft is as well.
    Dgoode9[OP] and wilcam47 like this.
  7. Sep 20, 2022 at 11:17 AM
    nudavinci64
    Robert
    If you are getting CV issues that is another issue entirely. Fix u joints and/or carrier and then retest. If you have a lot of slop in the carrier (it shouldn't move all that much) replace but a good piece of mind if you need to U-Joints.
    Dgoode9[QUOTED][OP] likes this.
  8. Sep 20, 2022 at 11:31 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Tech may have grabbed the drivers side CV and seen the sloop and that is normal due to needle bearing that side only (see ECGS bushing posts) but assumed it was junk.
  9. Sep 21, 2022 at 9:30 AM
    Dgoode9
    Dgoode9 [OP] Well-Known Member
    Columbus, OH
    2009 TRD Sport
    Update.
    U joints and carrier bearing - $906
  10. Sep 21, 2022 at 10:21 AM
    MSgt O
    2013 Tacoma
    did it stop the squeaking?
  11. Sep 21, 2022 at 11:54 AM
    Dgoode9
    Columbus, OH
    2009 TRD Sport
    Still at the shop at the moment. I’m really tooling around with the idea of trading it in for a 4Runner..
    Zalab8 and MSgt O[QUOTED] like this.
  12. Sep 25, 2022 at 10:03 AM
    Big Red 2nd Gen
    Big Red 2nd Gen Well-Known Member
    Dan
    Red 2008 TRD Access Cab 6 Speed
    TRD Cold Air Intake, Fat Bob's Vated Bilstein fronts set at 3 inches, stock rear leafs with ICON progressive multi leaf "add a leaf", MBRP Stainless dual exhaust, Sport Hood with scoop, Pedal Commander, Pro Comp 16x8 wheels with 265/75R16 KO2's, toneau cover.
    Definitely u joints, the hollow driveshaft magnifies / resonates the noise. If they are greaseable pump them full of grease and see if the noise goes away, either way you will have to replace them so it's easier to just replace them.
  13. Sep 25, 2022 at 11:16 AM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
    Sounds a little like George jetsons ship
  14. Sep 25, 2022 at 11:35 AM
    Rock Kickass
    Rock Kickass Well-Known Member
    It’s 100% u-joints, you can tell because the squeaking is faster than the wheels are turning. Get a laser thermometer and temp check both after a short drive and you’ll see which one (you should replace both while you’re at it). Although I guess it could also be your pinion bearing, you can check that with the laser too. Make sure your diff is full
    Leomania likes this.
  15. Sep 25, 2022 at 12:04 PM
    #35
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    Not for nothing but I paid less for a new complete oem driveshaft.
    You only need to mark where the 2 axles go together at the carrier. Marking the trans or diff yoke makes no difference.
  16. Sep 25, 2022 at 6:55 PM
    #36
    MSgt O
    2013 Tacoma
    Im curious since he brought it up, anyone trade their Taco for a 4Runner and are you happy with it?
  17. Sep 28, 2022 at 12:25 AM
    #37
    dj_or_dj
    dj_or_dj Member
    2013 White Tacoma Double cab 4x4 long bed
    Stock for now.
    Broooooo $2600??? This is a Toyota not a Porsche.
    Please tell me you didn’t let them do it.
    I had a similar experience with a Cayenne Turbo S I owned. The drive shaft was $3200 from the dealer plus another $2,000 to install. WTF?!?!
    Autozone had it for $600 bucks and done deal.
    Buy the parts, get a service manual and learn how to fix it. The dealerships are making CRAZY money on basic maintenance because we let them. Stop paying these outrageous prices, they do it because they can.
    If you lived close I would do it for you, and teach you how to do it for $400. Just buy the parts. Lol. It’s definitely worth a weekend
  18. Sep 28, 2022 at 12:29 AM
    #38
    dj_or_dj
    dj_or_dj Member
    Stock for now.
  19. Sep 28, 2022 at 12:34 AM
    #39
    dj_or_dj
    dj_or_dj Member
    Stock for now.
  20. Sep 28, 2022 at 12:50 AM
    #40
    dj_or_dj
    dj_or_dj Member
    Stock for now.
