Please help me identify this noise?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazze2005, Jun 17, 2010.
  1. Jun 17, 2010 at 9:04 PM
    blazze2005
    blazze2005 [OP] Well-Known Member
    South Jersey
    05 Tacoma Pre-Runner Sport
    Fuel Off-Road Octane Wheels,Yokohama Geolander ATS 265/65/17.Grillcraft,Borla Exhaust,Truxedo Lo Pro Tonneau Cover,Pop n Lock Tailgate Security,Custom Wet Okle TRD Seat Covers,Catch-All Matts,Gatorback Belt,Shorty Antenna,Toyota Bed Matt,Sirius Radio,Vent Sades,20% Lumar Window Tint
    Ive been hearing a noise when I'm rolling backwards in reverse. It's a clink sound like a metal to metal clink.
    It does it after I shift into drive also...
    Could this be my universal joint going bad?
    I'll try and post up a short video clip and try and capture the sound i'm talking about
    Thanks for any help...
  2. Jun 17, 2010 at 9:07 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    mine does this too! i thought it was just my little bungies rubbin against each other in the bed, but does it sound like 2 chains hitting eachother??
  3. Jun 17, 2010 at 9:14 PM
    blazze2005
    South Jersey
    yup that's the sound!
    And looks like no way to grease them on my Pre-Runner:confused:
    Anybody know the cost of replacing the front and rear U-joints?
  4. Jun 17, 2010 at 9:24 PM
    Nightfury
    Nightfury Well-Known Member
    Evan
    Bismarck, North Dakota
    Factory running boards, Toyota (DeeZee built) toolbox, Code Alarm 5152 remote starter, Bronze TRD rims, more to come....
    This is a common noise on a lot of newer model Toyota vehicles. If this is a noise you typically only hear when first stopping in reverse or drive while changing moving direction (forward or reverse) it's very likely the disc brake pads shifting in the saddles. Tearing apart the front brakes and putting a little SilGlide (or similar product) at the points the pads contact the saddles and shims should eliminate this noise.
    It is a clicking noise, which usually goes away after the first or second stop, normally when your truck has sat and the brake parts are cold. If that doesn't describe the noise, then I'll need more details.
  5. Jun 17, 2010 at 9:26 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    you are talking about the sound that is like 2 chains hitting right?
  6. Jun 18, 2010 at 1:07 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Not a U-joint. a U-joint would make a pretty nice thud almost like a knock. I would say if its when rolling and between shifts then check your brake pads you should see some shiny on the calipers where they have been shifting if it has been doing it for a good while.
    Also if it sounds metallic check for any loose parts on the truck like a loose skid plate or some thing of the sort.
  7. Jun 18, 2010 at 7:42 PM
    bigmooze
    bigmooze Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    Check your brake pads for sticking inside the calipers. Makes a metallic clinking noise.
  8. Jun 18, 2010 at 7:54 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    How about a popping clank sound? I get that when I reverse to the right. It's really frustrating. My passengers get scared of it when they hear it for the first time.
  9. Jun 18, 2010 at 10:43 PM
    2.7taco
    Texas
    Sounds like the suspension settling, unless you have a 4x4. If you have a 4x4 check your CV axles.
    Worst case scenario you have some loose lug nuts on one of your wheels.:eek:
  10. Jun 18, 2010 at 11:06 PM
    in2nite
    in2nite Well-Known Member
    James
    SoCal.
    blk 07 prerunner
    Engage Offroad L/T front and rear, Kings and 50t pack, Hella 4000's, Pro Comp Wheels and tires
    check to make sure your carrier bearing bolts are tight before u start taking the u-joint apart.
