Please help my squeaky truck :(
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sigi, Mar 22, 2011.
  1. Mar 22, 2011 at 8:55 PM
    Sigi
    Sigi [OP] Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    So my 2006 4x4 taco squeaks really bad. Everytime i put it on drive and start going it squeaks really bad it sounds like a chirping sound. The faster i go the faster it chirps. Even if i leave it on drive and let it move with out the pressing on the gas it still does it.. I already greased all my u joint and still squeaks.. Please help!!!!
  2. Mar 22, 2011 at 9:04 PM
    TexAggie
    TexAggie Well-Known Member
    Eric
    Houston, TX
    OME Lift
    Might check out your leaf springs. Usually that is what causes it. It is an easy fix.
  3. Mar 22, 2011 at 9:08 PM
    Sigi
    Sigi
    Sfv ca
    Thats what i thought but would it still make the squeaky noise if its on drive moving with my foot of the pedal on smooth pavement??? All i have to do is put it on drive and let go of the brake and it starts doing it..
  4. Mar 22, 2011 at 9:09 PM
    Kingfrog
    Kingfrog Well-Known Member
    08 TRD Rugged Trail Edition
    Undercover,Pop n Lock, Hardwired GPS, Garage door opener , Scanguage II, wireless back up camera, X994 Basslink, ...Prefer stock and non invasive functional mods
    Wheel bearing?
  5. Mar 22, 2011 at 9:10 PM
    TexAggie
    Eric
    Houston, TX
    OME Lift
    I don't know. Have you located where its coming from? Thats the first thing I would do.
  6. Mar 22, 2011 at 9:12 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Just throwing this out there.. Serpentine belt? How many miles do you have?
  7. Mar 22, 2011 at 9:14 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    x2 on the serpentine belt. Try spraying something on the belt and see if the noise stops. If it does, replace the belt.
  8. Mar 22, 2011 at 9:16 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" TuRD PRO replica wheels
    when was the last time you greased your u-joints?
    EDIT
    NEVERMIND
    I R DUMB and didn't read the whole post
  9. Mar 22, 2011 at 9:19 PM
    Sigi
    Sigi
    Sfv ca
    My truck has 60k and i believe it started doing it after driving it on the rain for days. not sure thought.. which belt is that???
  10. Mar 22, 2011 at 9:22 PM
    Sigi
    Sigi
    Sfv ca
    I greased them yesterday and 3 months ago too. I believe only 4 of them have the fittings for the grease gun
  11. Mar 22, 2011 at 9:24 PM
    Sigi
    Sigi
    Sfv ca
    I dont know from where exactly cause i have not had anyone around to help me check..:(
  12. Mar 22, 2011 at 9:25 PM
    tinker_troy
    T R O Y
    WY/SD
    ok.... you said the chirping gets faster as you go faster... does it drop down when the transmission shifts?
  13. Mar 22, 2011 at 9:27 PM
    NelsonTacoma
    Tucson, AZ
    There's only one belt. It's on the front of the engine & spins the fan.
    I should have asked earlier but does it only happen while in motion? If so it's not the belt.
  14. Mar 22, 2011 at 9:29 PM
    Sigi
    Sigi
    Sfv ca
    Yes it does get faster the faster i go and yes i belive it drops down more as it goes into 2,3,4 gear
  15. Mar 22, 2011 at 9:30 PM
    Sigi
    Sigi
    Sfv ca
    yes only when in motion.. thanks
  16. Mar 22, 2011 at 9:31 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    make sure all the bolts on your leaf packs are tightened down. my truck was squeaking like a muda fuka for this reason.
  17. Mar 22, 2011 at 9:32 PM
    tinker_troy
    T R O Y
    WY/SD
    OK, then I would go with belt or belt related something (idler pulley, tensioner pulley...).
  18. Mar 22, 2011 at 9:34 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    Center support bearing ?
  19. Mar 22, 2011 at 9:41 PM
    Sigi
    Sigi
    Sfv ca
    ok cool ill do it tomorrow.. Cause when i stand on my bed and jump up and down it sqeaks badly.
  20. Mar 22, 2011 at 9:51 PM
    toyotatacomaTRD
    From what I have read, I am wondering if you have more than one squeak going on... I would start with the leafs and go from there..
