Please Help! Newbie Lift Question!
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacostaco, May 10, 2013.
  1. May 10, 2013 at 4:03 PM
    tacostaco
    tacostaco [OP] Member
    Tampa, FL.
    Hello - I recently purchased a '96 4x4 Tacoma and want to lift the truck enough to clear 12.5x33's. I have looked all over this site, as well as others, and have gotten quite an array of opinions. The truck is on the road more often than not, so I don't need anything radical. I would like to know whatever is truly the best way to go to clear the 12.5x33's without rubbing during turns (I do realize there may have to be minor trimming in the fenderwell). These are the three options I'm comparing as they have been the most recommended:
    - 4-Wheel Parts/ ProComp recommends a 2.5 inch leveling kit
    - member suggested Bilstein 5100's with Eibach springs
    - member suggested Bilstein 5100's with OME coils
    I hope this will be my final search so I can move forward - any input is greatly appreciated!
    Thank you,
    Frank
  2. May 10, 2013 at 7:37 PM
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    pcbuilder14 has 33's may ask him I think he is runnin an AAL and 5100
  3. May 10, 2013 at 7:45 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    The OME lift is a great lift! Will provide 3" of lift that will clear your 33s
  4. May 10, 2013 at 7:46 PM
    ColtsTRD
    Scott
    AZ
    Don't forget the UCAs to correct your alignment :)
  5. May 10, 2013 at 8:22 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    You'll have to beat or grind the pinch weld and those 33s will always rub on the frame at full lock unless you have proper wheel backspacing. (Plus 3" or so of whatever lift you choose)
  6. May 11, 2013 at 2:40 PM
    tacostaco
    Tampa, FL.
    Thank you for all of your replies. The last couple of trucks I've owned (not Tacomas) had rubbing issues near the outside of the front fender-wells, even when make a simple turn into my driveway. That's what I'm really trying to eliminate; if it only does it at "full lock" I can live with that. I'll let you know what I end up going with and post pics as well. Thank you again!
    Frank
  7. May 11, 2013 at 11:36 PM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    5100s and eibachs will give you the most you can really get up front, you will need to cut and smash the pinch weld with 12.5s. then in the back it is probably best you replace your presumably stock leaf pack with a new one.
  8. May 12, 2013 at 6:49 AM
    TejasYOTA
    TejasYOTA Countinuous improvement
    Nathan
    Country of TEXAS!
    "WOOKIE" 01 Tacoma DC TRD Limited 4WD
    Check the TTORA Garage Section....
    Bang for the buck - - OME
    But to make sure you pick the right one... check out my Q&A link below.
