please help p0401 code
Discussion in '4 Cylinder' started by gixxer1, Jun 12, 2010.
  1. Jun 12, 2010 at 6:39 AM
    gixxer1
    gixxer1 [OP] Member
    03 reg cab 2.7L 4x4
    03 4x4 2.7L 5spd.......so i was driving the other day and got a check eng. light on p0401.......took it to the dealer and a master tech took a look....he said replace the egr valve and vsv solinoid . so i did this and the light came back on.
    prior to replacing these parts i checked out the egr with a vacuum gauge(applied vacuum and engine wanted to stall, so i figured it was ok)
    removed the vsv and applied vacuum then actuated it with battery voltage , vacuum released- figured that was ok too)
    looked inside egr to exhaust manifold tube and its completely clear!....wtf!
    anybody have this problem?
    thank you
  2. Jun 12, 2010 at 6:03 PM
    swdockter
    swdockter Well-Known Member
    Northwest Burbs, IL
    2" lift, 5100s, AAL, K&N, Deck Plate, 375K and counting
    lmao, I have the same code right now. Hope we can find someone here with the same issues and got them fixed. :D
  3. Jun 13, 2010 at 6:32 PM
    gixxer1
    gixxer1 [OP] Member
    03 reg cab 2.7L 4x4
  4. Jun 13, 2010 at 8:51 PM
    nagelg
    nagelg Well-Known Member
    George
    Northern Wisconsin
    2015 TRD Sport
  5. Jun 14, 2010 at 6:17 AM
    swdockter
    Northwest Burbs, IL
  6. Jun 14, 2010 at 3:25 PM
    nagelg
    George
    Northern Wisconsin
    2015 TRD Sport
    Yer talking to a dummy here bud. I can sure fix a truck that don't have a computer, try me on carburetors, distributers and points and I'm ok. Throw a "code" at me and I'm,,,, WTF??????
    There some pretty smart people on here (Chris 4X4 and a bunch more) who can answer your questions....good luck.
  7. Jun 14, 2010 at 3:30 PM
    98tacoma27
    Ben
    Not Beech Creek
    Replace that, after you double check for loose vacuum lines
  8. Jun 14, 2010 at 3:33 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Ben to the rescue!!!!:D
  9. Jun 14, 2010 at 3:33 PM
    98tacoma27
    Ben
    Not Beech Creek
  10. Jun 14, 2010 at 5:15 PM
    gixxer1
    gixxer1 [OP] Member
    03 reg cab 2.7L 4x4
    Thank you Ben so much!
    I'll mess with it tomorrow.......
    Do you have a vacuum diagram also?
  11. Jun 14, 2010 at 7:02 PM
    98tacoma27
    Ben
    Not Beech Creek
    This has one for the system you are trouble shooting. There should also be one on the hood or radiator support
  12. Jun 18, 2010 at 1:19 PM
    gixxer1
    gixxer1 [OP] Member
    03 reg cab 2.7L 4x4
    the vacuum ports on top of the throttlebody seem to be the problem......
    two are clogged so i blew them out and checked for vacuum with a gauge.......i have vacuum now and i reset light so now i will post eng. light results in a few days.
  13. Jun 21, 2010 at 4:37 PM
    gixxer1
    gixxer1 [OP] Member
    03 reg cab 2.7L 4x4
    no light yet, its been about 75-100 miles......it was the two throttlebody ports 2nd/3rd from butterfly opening on top.
  14. Jun 22, 2010 at 5:05 AM
    98tacoma27
    Ben
    Not Beech Creek
  15. Jun 22, 2010 at 10:27 PM
    005Tacoma
    005Tacoma Well-Known Member
    Thomasville, Georgia
    2005 Toyota Tacoma
    P0401 Exhaust Gas Recirculation Flow Insufficient Detected
  16. Oct 9, 2010 at 5:59 PM
    hktran
    hktran New Member
    KT
    LA
    2002 Prerunner
    i had this same code for over a year, it would come on and off so i never addressed it. now it just stayed on, and i have dmv reg at the end of the month. spent the afternoon diagnosing.
    found there was vacuum off the throttle body(to port P), but nothing after the vacuum modulator(out of port Q).
    i was pretty sure this was the culprit, decided to crack open the modulator to see. sure enough, the rubber membrane was broken/cracked.
  17. May 23, 2011 at 4:20 PM
    Racerboy221
    Racerboy221 Well-Known Member
    Bill
    Litchfield Park, AZ
    Tacoma 2.4, Std cab/bed, 18"wheels,airshocks
    18" Wheels & Tires, Airshocks, CB Radio
    I get the P0402 code from time to time as well. I just reset it using the OBD-II computer I keep under the seat and continue driving. The cost of replacing this item at retail is just stooopid expensive. too!
  18. Jul 10, 2016 at 7:05 AM
    Tacotime 2016
    Tacotime 2016 New Member
    Robert
    2016 taco/2002 taco
    King shocks 33's
  19. Jul 10, 2016 at 7:05 AM
    Tacotime 2016
    Robert
    2016 taco/2002 taco
    King shocks 33's
