PLEASE HELP, Question about fog light wiring
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Isaiasgon, Nov 23, 2011.
  1. Nov 23, 2011 at 2:39 PM
    Isaiasgon
    Isaiasgon [OP] Well-Known Member
    GA
    2013 4x4 TRD Sport V6 DCLB
    I recently installed fog lights behind my grill however they seem to be not as bright. When I have only one fog light plugged in it gets really bright but when i have both of them plugged in you can hardly see them. Does anyone have any idea why this is? I am no electrician and just followed what the manual said.
  2. Nov 23, 2011 at 4:23 PM
    sooner
    sooner Well-Known Member
    TX
    2011-4X4-LONGBED
    6-inch pro-comp lift-,n-fab 6 step nerfbars,extang touneau cover,go rhino grille guard,aftermarket fogs,3.5 driving lights,7-inch off road lights.pro comp skid plate,train horns,reese tow hitch,escort 9500ix,blend mount wireless radar mount.avs bug deflector and window vents,5%window tint.28-led back up lamps,sock monkey 3rd brake light decal,magna flow exhaust.klein train horns.nitro,nitro 4.56 gears,pro-comp traction bars,volant super scoop air intake.
    whet kinda lights?and how did you wire them.
  3. Nov 23, 2011 at 4:32 PM
    YotaMark
    YotaMark Well-Known Member
    Mark
    Mentor, Ohio
    08 Tacoma 4 cyl 5 speed 4X4
    Rear Gate security Mod (although I seldom take my eyes off it) "Harsh Ride" Shocks and Springs TSB performed by "Me" New Cooper Discoverer AT3s 265/75R16s (fit well) Front "Tacoma Mike" light mod! Rugged Ridge floor mats. Bought another set of D rings and installed them in my wheel well. Perfect! Just hit the big 6000 Miles 12/19/11, Installed an alarm system to go with my factory power door locks 1/21/12
    are they wired in parallel, or wired in Series?
  4. Nov 23, 2011 at 4:37 PM
    MARSHBUSTER
    MARSHBUSTER Well-Known Member
    Jim
    Alamogordo NM
    2005 SR5 4X4 Tacoma TRD
    Grill Gaurd/ Winch Bumper, Mile Marker 9000 LBS Winch, Custom Head Ache Rack, Custom Rear Bumper, Marathon Camo Max 4 Seat Covers
    Make sure both lights have good grounds.
  5. Nov 24, 2011 at 8:52 AM
    Isaiasgon
    GA
    I got mine at auto-zone (Pilot Performance Lighting PL-2202C) and the way i wired them was i took the red cable from the battery to the switch, then i got the white and black wire from the lights to the switch leaving the black connected to the side of the truck (for ground). however for some reason when i disconnect one the other is brighter and when i connect both you can barely see them at night
  6. Nov 24, 2011 at 9:16 AM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    There's three wires? Usually only two as far as I know
  7. Nov 24, 2011 at 9:38 AM
    Isaiasgon
    GA
    yea for some reason there is the red wire that goes to the switch and the white and black one that goes from the lights to the switch. the white one goes to the switch and the black one is for grown. but i still dont know why it gets dimmer when i plug in both
  8. Nov 24, 2011 at 9:55 AM
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    What size wire? And how many watt's are the lights
  9. Nov 24, 2011 at 10:01 AM
    Isaiasgon
    GA
    Im not an artist but this is how they are connected :eek:
    I had to draw it out because (not to sound dumb or anything) i have no
    idea what does having them wired in parallel or wired in series mean.
  10. Nov 24, 2011 at 10:02 AM
    Isaiasgon
    GA
    Ill have to check that out but i just used the wires that came stock in the box
  11. Nov 24, 2011 at 10:06 AM
    cummins6speed
    That extra wire on teh switch is probably for illumination.
    Looks like its wired correctly
  12. Nov 24, 2011 at 10:10 AM
    1Bigbird
    1Bigbird Yo! Wat up peeps?
    winter-peg
    2010 TRD D-Cab
    Your drawing is parallel and correct except you forgot a fuse by the battery.
    Parallel adds currents. If each of 3 lights uses 5 amps you need 15 total.
    Series adds divides voltages. If each of 3 lights needs 12 volts you need 36V to power them and in one burns out they all go out.
  13. Nov 24, 2011 at 10:12 AM
    Isaiasgon
    GA
    I wonder why you can barely see the lights at night. I even tried switching the light bulbs to the all white.
  14. Nov 24, 2011 at 10:15 AM
    dud122
    dud122 rabble rabble rabble
    Dan
    Riverdale Park, MD
    2002 Tacoma DC
    OME up front, Dakar in the back, Elite front bumper, Warn winch, Tactical rear bumper with tire swing/jerry cans/hi lift, Revenge Fab. sliders, Tundra brakes, Camburg UCA's, Safari Snorkle, FJ TRD wheels, Truxedo, Bed Rug, Lights, CB, Switches, skids, LED's... OH MY!
    i just wired up some fogs and i did it pretty much the same as you did except i wired the grounds coming from the lights to the ground terminal on the switch then added a wire from that terminal to the truck
  15. Nov 24, 2011 at 10:15 AM
    Isaiasgon
    GA
    Oh ok sweet, they little black box next to the batter on the wire is suppose to be the fuse LOL told you i wasnt an artist :D but do you happen to know what i should do to fix the problem?
  16. Nov 24, 2011 at 10:18 AM
    Isaiasgon
    GA
    by any chance can you draw it out? I understand it better when i see a picture. I might try this to see if it solves the problem i am having with mine being really dimmed out
  17. Nov 24, 2011 at 10:19 AM
    cummins6speed
    Are your grounds actually spliced like that and then one wire goes to the body?
  18. Nov 24, 2011 at 10:20 AM
    platinumb
    platinumb Well-Known Member
    Patrick
    denver
    11 TRD OR DC Supercharged
    supercharger, focal/jl audio sound system, trd cat back
    Is the switch getting hot when they Are on it just might not be able to pass enough current through, with fog lights even the ones that don't come with one it is always a good ideal to use a relay that way you don't have all the power the lights draw passing through a 2.00 rocker switch
  19. Nov 24, 2011 at 10:20 AM
    Isaiasgon
    GA
    yes
  20. Nov 24, 2011 at 11:19 AM
    Isaiasgon
    GA
    i think so, the light on the switch stays on until i turn them off. how would i instal a relay and were?
