*please help* RADFLO 2.5 CO with resi height adjustment
Discussion in '3rd Gen. Tacomas (2016-2023)' started by chrisag83, Aug 8, 2018.
  1. Aug 8, 2018 at 8:00 AM
    chrisag83
    chrisag83 [OP] New Member
    Christopher
    2017 Tacoma SR5 4x4 DCSB sky silver
    front-Bilstein 5100 stock coils, rear stock shocks/leaf w/1.5 inch block, stock wheels w/ Falken wild peak AT3 265/75/16
    Recently installed the Radflo 2.5 w/resi to the front and rear of 2017 Tacoma sr5 dcsb 4x4 with the ome dakar leaf back to the rear. Also put in the Spc UCAs. After everything was installed went to try and adjust the front CO with the radflo 2.5 c spanner wrench was unable to adjust because the elbow hose fitting got in the way.
    Any suggestions on adjusting w/o removing the front CO off the truck.
  2. Aug 8, 2018 at 8:04 AM
    Jason TRD OR
    Jason TRD OR SIBI BUILT LLC
    Sibi Built LLC Placentia, CA
    16 Tacoma TRD Off Road 4X4
    King suspension w/ compression adjusters custom valving and 700# coils. Icon DJ uca. Icon RXT leafs Option #3. Durobumps. Demello rock sliders. Demello 30” Light Bar Baja Hoop bumper with Smittybuilt X2O winch w/ Amber baja design fogs w/ single row Baja Designs S8 amber light bar. Brute force Fab HC rear bumper. Behind Grille Light bar. TRD Pro Skid plate. Pelfrey Mid and Transfer case skid. TC spindle and cam tab gussets. Pop and lock. Method NV wheels 16”. SpiderTrax 1.25” wheel adapters. Yokohama Geolandar M/T (315/75/16). CMC. Radiator core reinforcement. Pro grille. Tailgate inlays. Baja Designs A pillar Ditch lights. Leer 100 XQ shell w/ power locks. In bed mounted spare. Blacked out emblems. Bed Mat. Bed Stiffeners. K&N air filter. Black Headlight Mod w/ LED projectors. Wrap Armor Anti glare hood and bedside decals. American flag decals. Northstar 24F AGM Pro battery. Differential breather relocate to rear tail light. Prinsu Designs Cabrack and Cap rack. OVTUNE Sibi Custom performance 4.88 91 fuel AGM . Nitro Gear 4:88 gears. Mountain hatch tailgate insert. In bed mounted Krazy Beaver shovel with Relentless quick fist bedrail mounts. MESO ultimate turn signals. AJT Designs Quicksand Key Fob. ECGS front needle bearing bushing replacement. Tepui LoPro 2 RTT.
    Get a punch the same size from Home Depot. Cut it off long enough to clear the shock bucket. Use a hammer and punch to turn it w the cut off punch far enough to get to the next hole w the punch. Repeat.
  3. Aug 8, 2018 at 11:04 AM
    chrisag83
    Christopher
    Thanks will give thst a try
