Please help strange electrical problem
Discussion in 'Technical Chat' started by Emcsports, Apr 30, 2024.
  1. Apr 30, 2024 at 5:01 PM
    Emcsports
    Emcsports [OP] Member
    Tacoma has been acting strange lately, 2018 trd sport, when I turn the truck off it goes completely dark, no interior lights will function , except the windows will work, and even with the door open? The gauges are all stuck at idle speed and the temp gauge is pegged in the middle also the fuel gauge does not move ? Checked a bunch of fuses but lost as to what it could be. Anyone have any ideas or suggestions?
  2. Apr 30, 2024 at 5:05 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Scan for codes and see what comes up.
    If everything else works when the vehicles running then i'd guess a wiring or network issue.... this will be a hard one to give you help with over the internet without someone being there to start testing things.
  3. Apr 30, 2024 at 5:10 PM
    Emcsports
    Yes I'm aware it could be a difficult one to diagnose. There aren't any codes showing unfortunately. Probably rodent damage im guessing but where would this problem originate from so I can start looking. What do you mean by network issue ?
  4. Apr 30, 2024 at 5:15 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    If it just happened out of the blue I’d start visually looking everywhere you can for anything loose or chewed. Other than that, the dome lights is a pretty convenient tell. If you can find someone with an electrical manual for the truck you can follow that circuit and probably find the source of all the problems.
    Another thing, which seems less likely, is a loose ground wire. Has any work been done to the truck recently?
    joba27n likes this.
  5. Apr 30, 2024 at 5:21 PM
    Emcsports
    Guess I forgot to mention, when you he truck is running, all the dome lights function perfectly. Power locks function. Just when u push the button it shuts everything off immediately and it won't function until it's keyed on again?
  6. Apr 30, 2024 at 5:54 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I'll poke around on some wiring diagrams here in a bit when I get a chance.
    So everything works correctly when the engine is running and with the switch in the run position?
    Do you have the keyed ignition or push button ignition?
    A list of everything affected may help too.
  7. Apr 30, 2024 at 6:01 PM
    Emcsports
    Push button ignition.
    when it's running I have basically full function as far as I can tell. As soon as the push button ignition is keyed off, the truck goes dark no
    headlights, interior lights, radio, no key fob function for power locks, no hard switch function, but the windows will work even with the doors being opened. Checked a pile of fuses under the dash and hood everything looked good.
    Dm93 likes this.
  8. Apr 30, 2024 at 6:06 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Gotcha, I'll poke around in some diagrams when I get a chance and see if I can come up with at least a place to start.
    There's no aftermarket electrical modifications such as alarm/remote start, wiring, add a fuse, radio, etc correct?
  9. Apr 30, 2024 at 6:24 PM
    Emcsports
    Remote start only. Was thinking this would be a great place to start just unhooking it completely. It's all electrical taped together. Just looks awful.
  10. Apr 30, 2024 at 6:35 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I think I'd start with the ECU-B No3 fuse (10A) in the underhood fuse box.
    Also make sure the short pin is installed correctly.
    Yea I'm not a fan of them, they can cause a host of issues when they fail and most are poorly installed.
    SR-71A and joba27n like this.
  11. Apr 30, 2024 at 6:59 PM
    joba27n
    Nolan
    Alberta
    Different module/ computers talk to each other for various reasons. Example is abs/traction control module will talk to the ecm to reduce power when you're sliding. Thats networking.
    A wiring diagram being sent you will be the most helpful
  12. May 1, 2024 at 5:31 AM
    Emcsports
    Just re checked those fuses and they all loook to be making a solid connection.
  13. May 1, 2024 at 5:45 AM
    Emcsports
    Video
    won't let me post sorry .
  14. May 1, 2024 at 6:09 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    You have to upload your video elsewhere and link to it. Tacoma World doesn't allow direct uploads of videos.
  15. May 1, 2024 at 11:59 AM
    Emcsports
    Any chance it could be the actual start stop switch ? Is that a dash out job ? Noticed when in the truck with no key it doesn't recognize when u press start an say no key or do anything really?
  16. May 1, 2024 at 4:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Srry for not getting back to you last night, TW kinda went nut's with people with electrical issues and I lost track of who I had replied to.
    Might swap that fuse just to be sure and check it for power on both sides, if power is good at that fuse we're gona have to go to the Body ECU and check some things as everything you mentioned that isn't working properly is tied to the Body ECU.
    What were the event's that led up to this issue happening?
    I don't think so, that would only affect the vehicle keying up it shouldn't affect the lights.
    joba27n likes this.
  17. May 10, 2024 at 3:19 PM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Sounds really weird any more details or backstory?
    Original owner?
    Harsh climate??
    Did it always work correctly?
    How soon after the remote start install did it start having issues….and who installed it ?
    Any other recent service/accident prior to it acting up?
