PLEASE HELP!!! SUSPENSION TROUBLE
Discussion in 'Suspension' started by Jacobw6, Feb 2, 2012.
  1. Feb 2, 2012 at 1:21 PM
    Jacobw6
    Jacobw6 [OP] Active Member
    Lake Village, AR
    White lightnin'
    Hellbent 3" lift. Aem bruteforce cold air. Pioneer p2300dvd screen. Aftermarket smoked cab lights. Active suspension system in rear.
    If someone can give me a possible explanation, I have in stalled a leveling kit back in may of 2010. Recently, I have noticed that the front left has started to sag. Not just a little sag, almost an inch difference. I have measure the fenderwell space from the ground up and the front right is almost an inch higher. It may not be a big deal but I cant help but notice the lean while being parked, as well as driving down the road. Any explanations, or possible solutions to fix this???
  2. Feb 2, 2012 at 1:29 PM
    speedydave
    speedydave Got Boost?!?
    Dave
    Hickory, Nc
    Ecoboost
    post some pics of your setup.
  3. Feb 2, 2012 at 1:30 PM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    look up the taco lean on here
  4. Feb 2, 2012 at 1:42 PM
    Pugga
    Massachusetts
    '18 Ford F-250 SCREW
    F-250 Land Yacht Mod
    What did you install for a leveling kit?
  5. Feb 2, 2012 at 1:51 PM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    The drivers side carries more weight...driver, battery, gas tank, etc.
  6. Feb 2, 2012 at 1:58 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    install the taco lean spacer on your side:)
  7. Feb 2, 2012 at 2:02 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    You think the lean is bad now, disconnect the sway bar and see the "true" lean. :devil:
    My front left Icon's spring perch is preloaded by 1/4" to compensate for the lean.
  8. Feb 2, 2012 at 2:08 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    It's also possible when the leveling kit was installed that the stiffer drivers-side stock spring was installed on the passenger side instead.
  9. Feb 2, 2012 at 2:10 PM
    Jacobw6
    Lake Village, AR
    White lightnin'
    i installed the hellbent 2.5" leveling kit myself, and i placed the original shocks on the side, and whats this taco lean kit??
  10. Feb 2, 2012 at 2:10 PM
    Jacobw6
    Lake Village, AR
    White lightnin'
    excuse me i put the shocks back where they belonged
  11. Feb 2, 2012 at 2:11 PM
    Jacobw6
    Lake Village, AR
    White lightnin'
    i also had the differential drop kit installed
  12. Feb 2, 2012 at 2:15 PM
    KPT
    09 Prerunner
    You should not have that bad of a lean if you are using the stock springs, especially since you have a 2011. The taco lean spacers folks are talking about are to compensate for aftermarket kits that have two springs with identical spring rates. The drivers side will then sag compared to the passenger side due to the fact that the gas tank and the driver are on the same side.
    However the stock springs are side specific (drivers side is stiffer), which makes this affect smaller. You certainly shouldn't have an inch difference.
  13. Feb 2, 2012 at 2:20 PM
    Jacobw6
    Lake Village, AR
    White lightnin'
    when I installed the leveling kit i added about 3 grade 8 washers on top of the leveling kit to add .5-1" extra lift (a little trick i discovered), do you think i could take 1-2 washers on the passenger side to even it back out?
  14. Feb 2, 2012 at 2:24 PM
    Pugga
    Massachusetts
    Lose the differential drop, you don't need it with just a leveling kit.
    With stock coils and just a top plate spacer, you shouldn't have that much lean side to side. Was it always like that from the day you installed the lift or has it slowly gotten worse over time?
  15. Feb 2, 2012 at 2:26 PM
    Pugga
    Massachusetts
    That's not a trick, that's called cob-jobbing a lift... I'd get rid of the washers, that's not a good idea in my opinion.
  16. Feb 2, 2012 at 2:29 PM
    KPT
    09 Prerunner
    Wait so how much total lift are you running? And it's all accomplished outside of the coil assembly?
  17. Feb 2, 2012 at 2:31 PM
    Jacobw6
    Lake Village, AR
    White lightnin'
    job-cobbing? dont rain on my parade man!, i haven't had any problems out of it, and i think it has gotten worse over time. the drop kit came with the leveling kit and was install for free, and its to much trouble to take off....but i think the washers taken out of the right side will fix it....i hope
  18. Feb 2, 2012 at 2:33 PM
    Jacobw6
    Lake Village, AR
    White lightnin'
    im running the 2.5" hellbent with 3 grade 8 washers on top, the equivalent of a 4" lift. Put 2" blocks in the rear with an active suspension system. Sits almost if not as hight as a truck with 4 inch suspension lift...THAT is why i had differential drop kit.
  19. Feb 2, 2012 at 2:37 PM
    KPT
    09 Prerunner
    So you are effectively running a 4" top plate spacer? I'm astonished your ball joints haven't broken yet. Or that you haven't bottomed out your shock
  20. Feb 2, 2012 at 2:40 PM
    Jacobw6
    Lake Village, AR
    White lightnin'
    nope, not problems at all, the a-arms are hardly at any kind of angle, rides almost like it did stock. honest truth.
