Please help tire size on my 07 taco
Discussion in 'Wheels & Tires' started by Slazz29, Feb 7, 2019.
  1. Feb 7, 2019 at 5:36 AM
    Slazz29
    Slazz29 [OP] Well-Known Member
    Colten
    1995 Tacoma 2.7 3.5 inch offsets black
    Barnes 4wd diff cover bull bar kc lights toolbox smoked tail lights 3 inch leveling kit ion alloy 3.5 inch offsets 31x10.50r15 gt's
    Ok so I have a 2007 Tacoma 4wd TRD offroad And my current setup is a 2" front leveling kit and the back is stock height but I am running fox 2.0's just in the rear front is stock suspension. My current wheel setup is a ion alloy 15" rim with -38mm offset and 2" wheel spacers. Running 31x10.50x15 mud tires although it looks very well it rubs bad due to the offset. 15's don't fit unless you have that amount of offset to clear the calipers. My question is with my current setup of height what size tire could I fit under it if I move up to a 17" rim? I should be able to get a bigger tire on then I have now because I'm not going as much of an offset. Maybe flush with the flare. I plan on doing some minor wheeling with it so I don't think this amount of offset suitable for trails. So what it comes down to is with 2 inch leveler how big of tire can I fit with a 17" wheel? Minor rubbing is not an issue. Massive rubbing not cool
  2. Feb 8, 2019 at 1:02 PM
    Slazz29
    Colten
    Thanks for all the info....
  3. Feb 8, 2019 at 1:05 PM
    austin2009
    austin2009 Well-Known Member
    Austin
    Boise, Idaho
    Lifted and Locked 09 2.7L 2TR 4x4 5 Speed
    DRIVETRAIN- -4.56 Nitro gears -ARB rear locker -SPC UCA's -Fox 2.5" RR fronts/650lb coils -Bilstein 5100's rear -1.5" AAL -285 BFG KO2’s -16x8 MK6’s ARMOR- -ABR bumper -BAMF LCA skids -Cali Raised sliders RECOVERY- -Smittybilt XRC 9.5k synthetic winch -ARB OBA -Factor 55 Pro Link, Expert STEREO- -Pioneer head unit -Rockford T series speakers -Rockford 500 watt amp -Rockford P2D4 8" sub LIGHTING- -Calirasied ditch lights -Caliraised amber fogs -Hella Black Magic’s -Blue Seas fuse panel
    Personally, I’d run a 275/70/16
  4. Feb 8, 2019 at 1:06 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    If you want to minimize rubbing while having a larger tire I'd go with 16x8 wheels and 255/85R16 tires.
    17" you could do a 17x8 with 255/80R17 tires, just fewer options in this size.
    They're narrower to reduce the rubbing, but a 33" OD to improve your ground clearance and obviously a better tire for grip.
    If you're open to getting a CMC (cab mount chop) you could go 285/75R16 or 285/70R17, just avoid 17x9" wheels to reduce the rubbing.
