Please Help - Transmission issues or is it just me???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyrac1978, Mar 6, 2010.
  1. Mar 6, 2010 at 10:46 AM
    kyrac1978
    kyrac1978 [OP] Member
    Jeff
    Dunnellon, FL
    2005 TRD Tacoma 4.0L
    I have a 2005 Toyota Tacoma Access Cab, 4.0L, Automatic transmission. The last few months (it's seem to have gotten worse as well) I have noticed that when the gas engages and disengages the truck makes a noise and seems to jump some. Is this the transmission? If so, what type of warranty does this year/model have and etc, or what else could it be? Should I get a the transmission fluid drianed or?
  2. Mar 6, 2010 at 1:14 PM
    Brunes
    Brunes abides.
    Rotorhead
    How many miles you have??
  3. Mar 6, 2010 at 1:23 PM
    bb609
    bb609 O.F.
    NH
    '09 TRD Sport Access Cab
    Icon Coilovers - Icon UCA's - TSB Rear w/Bilstein 5100's - Air Lift System - Leer 550 Bedcover - Ventshades - Yota Bed Mat - Sheepskins!!! - Weathertechs
    I'll jump and guess U joints. Check your drive shaft?
  4. Mar 6, 2010 at 5:13 PM
    JKD
    JKD Well-Known Member
  5. Mar 6, 2010 at 6:40 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    X2
    Any vibration ?
  6. Mar 7, 2010 at 5:39 AM
    Brunes
    Brunes abides.
    Rotorhead
    Still waiting on mileage- IIRC the Auto transmission is a 100K service interval?? So it might be that time. Old fluid can do bad things....U Joints would be guess #2
  7. Mar 7, 2010 at 9:16 AM
    kyrac1978
    Jeff
    Dunnellon, FL
    1. The truck has just under 87,000 miles.
    2. It does shake but I am planning on tomorrow getting my tires balanced and rotated with an oil change. Should I have them check the drive shaft/u-joint while they are doing the oil change and should I take it to the local Toyota dealer for this or?
    3. How much do you think it costs to change out the u-joints?
    Thanks again in advance for your help!
  8. Mar 7, 2010 at 9:27 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    The auto tranny fluid should be changed every 60,000
  9. Mar 7, 2010 at 5:05 PM
    bb609
    bb609 O.F.
    NH
    Definitely have them look.
    Shouldn't be more than an hour's labor to drop the shaft and press out a joint, $15 for a joint so...............$300.00 :D
  10. Mar 7, 2010 at 6:11 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
