please help UCA problem
Discussion in 'Suspension' started by TanSR5x4, Oct 8, 2010.
  1. Oct 9, 2010 at 4:29 PM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    You use the smaller one to back off the top collar. Then you use the bigger one to crank down on the bigger collar and that will push your coils down putting "preload" on them. Becareful of how much preload you throw down. That will make your ride more harsh. Also watch your CV angles. Then once you get to the desired height crank the smaller coller back down against the big one. Make sure you take all the weight off of the suspension first. Then get it aligned.
  2. Oct 9, 2010 at 7:00 PM
    Yota85
    Yota85 Member
    BRYAN
    Ottawa il
    08 dc super white
    icon co's, built right uca's, all pro 3" rears, gauge light swap, k&n cai, thrush exhaust
