Please help with ideas to take off shutter??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Clzay, Oct 15, 2011.
  1. Oct 15, 2011 at 12:55 PM
    Clzay
    Clzay [OP] Well-Known Member
    Clay
    Modesto, CA
    Cali Lean n mean... ha
    Hello everyone, I have an 2010 DC Prerunner an just installed Camburg spindles an All pro's 3" rear leafs... Im getting take off shutter till about 20mph. I've tried 2 1/2 degree shims an 4 degree shims, as well as dropping the carrier bearing from 1/4 inch to 1 1/2 inches with no change :( So my question is what else may be causing this to happen, so I can fix the take off shutter??
  2. Oct 15, 2011 at 2:12 PM
    Clzay
    Clay
    Modesto, CA
    Please any ideas people... tranny bearing/seal issues, something wore out causing this problem maybe?? There's got to be a solution... I just need ideas of where to go from here?
  3. Oct 15, 2011 at 2:20 PM
    joes06tacoma
    Joe
    Central Coast, CA
    You have an extremely common problem here. My stock truck does it too, but not up to 20MPH.
    Lots of people have tried shims, carrier bearing drops, etc with varied success. Each truck seems to be different.
    Then only thing that seems to be a guarenteed fix is to go to a one piece driveshaft. Search for one piece driveshaft on here and you should find what you need.
  4. Oct 15, 2011 at 9:27 PM
    Clzay
    Clay
    Modesto, CA
    I'm good with doing I one piece driveshaft if will fix my problem...? I just want to make sure it's not something else before I spend dollars on a driveline
  5. Oct 15, 2011 at 9:28 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    are the shims installed facing the correct way?
  6. Oct 15, 2011 at 11:25 PM
    Clzay
    Clay
    Modesto, CA
    Yes the thin side of the shim is facing toward the front. I just don't understand how there is not a straight forward fix to this so common Problem??
  7. Oct 16, 2011 at 3:45 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
  8. Oct 17, 2011 at 8:23 AM
    Clzay
    Clay
    Modesto, CA
    no thank-you... So you who have All Pro leafs in the rear what are you people doing to fix the issue??
  9. Oct 17, 2011 at 8:28 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    So far, a one-piece driveshaft is the best solution I've seen.
    Fink
  10. Oct 17, 2011 at 8:32 AM
    Wicked 2007
    Wicked 2007 Well-Known Member
    Bay Area, CA
    2007 Tacoma AT DC SB 4x4
    2007 Tacoma Double Cab SB 4WD - Auto -TRD Off Road - Icon Billet UCA - 8" ORI Front Struts - Bilstein 5100 11" RCD Shock - AllPro Expo Springs - Demello Sliders - Tom Woods 1 Piece Driveshaft - 16x8 Mojave Teflon Rims - Locker Mod - Locker Guard - 35" MT MTZ's - ARB Bumper - Warn 8000 winch w/synthetic line - All-Pro Front Skid/Transmission Skid/Rear Armor - ARB Front Locker - Nitro 4.56 gears - Marlin 4.7 crawl box - Twin Stick FJ t-case - ATO high clearance rear bumper
    X2
  11. Oct 17, 2011 at 12:29 PM
    Clzay
    Clay
    Modesto, CA
    Looks like thats what i'm going have to do, is running a one piece driveshaft going to be ok on a prerunner?
  12. Oct 17, 2011 at 12:36 PM
    Fink
    Orlando, FL
    It will be fine, but from what I have read, it will need to be custom-made.
    Go get yourself a nice cup of coffee and do a search for "solid driveshaft" or "one-piece driveshaft". You'll have plenty of reading to do. :D
    Fink
  13. Oct 17, 2011 at 12:48 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's not simple because it's a complex system with lots of variables.
    So you can't just try things at random. You need to understand the nature of the problem, take measurements, and apply a measured fix. Even if you go one-piece, you have to shim your pinion angle correctly to minimize vibration.
    Read this: http://www.4crawler.com/4x4/CheapTricks/Driveline-101.shtml
    Now, as far as shims direction goes: "Correct" is an interesting term.
    Toytec will tell you to put the shims in "fat back" which points the pinion towards the transfer case.
    Thing is, we're not using CV (double cardan) driveshafts, we're using single cardan driveshafts. And for a single cardan shaft, you want the flanges to be exactly parallel. How do you get them parallel? Measure, calculate, and shim to correct. But to bring them to parallel, after a 3" lift, you'll almost inevitably end up shimming "fat forward."
    I ended up using 2 degree shims, "fat forward" to get my minimal amount of driveline vibration. Am I telling you to use 2 degree shims? I am not. I'm telling you to measure. Check the link to my OME suspension install thread to see how I measured and calculated the 2 degree shims I used. But the best info is on the 4crawler page I linked above.
  14. Oct 17, 2011 at 12:49 PM
    Fink
    Orlando, FL
  15. Oct 17, 2011 at 12:50 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    It's the drive shaft. Get it repaired by a good drive shaft company or rebuilt. Simply out of balance and it's magnified with lift
  16. Oct 17, 2011 at 12:57 PM
    Clzay
    Clay
    Modesto, CA
    Wow thanks that's a lot of interesting info, I'm not sure i can find a tool to measure the angles or do i have the correct knowledge to get it right. I can not believe you ran your shims backwards to get the right angle, that just makes no sense to me?
  17. Oct 17, 2011 at 1:14 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    What you call "backwards" is the angle that made the driveline flanges parallel.
    At this point, perhaps the best advice is to go to a driveline shop and have them diagnose and correct the problem.
  18. Oct 17, 2011 at 1:16 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I'm not trying to put you down, but a driveline shop has angle measurement tools, a shaft balancer, and expertise to use them.
  19. Oct 17, 2011 at 1:26 PM
    Fink
    Orlando, FL
    FWIW, this is what I would do if I were in this situation.
    Fink
  20. Oct 17, 2011 at 1:26 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    make sure with the Prerunner how much pull your putting on your carrier bearing as our driveshafts have no slip yoke so too much lift will pull the carrier bearing apart
    had the same setup for a couple of years and didnt have bad vibes at takeoff, but after adding some 1.5" lift blocks i yanked my carrier bearing apart and talk about vibes, haha
    check my build towards the end to check out what i did to my driveshaft
