Please Help with rear brake adjustment
Discussion in '2nd Gen. Tacomas (2005-2015)' started by blazze2005, Mar 22, 2016.
  1. Mar 23, 2016 at 4:30 PM
    Tacoma Mike
    Southern Maine
    I've done it as soon as 10,000 miles. All depends on how the pedal feels to me when I drive it in. People don't realize the change because they drive it everyday and the change is very minimal.
    When they drive off they just about put themselves through the windshield. Lol. I bought my truck on a Wednesday and a week later on a
    Sat I had the truck half apart making upgrades, adjusting the brakes, pulling caliper pins and lubing,road force balancing tires, rear springs, alignment. I adjust my brakes every 6 months or 5000 miles at the latest. Anytime I pick up the truck I check and adj. if needed. If you think your pedal works at a lower point then it's time...
    Tatts521 likes this.
  2. Mar 23, 2016 at 5:09 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    Yeah...I think it's time after reading your experience above. I made an appointment for adjustment Monday at the dealer.
  3. Mar 23, 2016 at 8:43 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Your mileage may vary, but the rear drums have automatic adjusters on them. That is what that little star wheel and lever are for. My personal experience is that I have only had to adjust the drum brakes after a brake shoe replacement, the automatic adjusters work fine. I pump the brakes when I back up and always use the Parking Brake.
    Some may have a different experience.
  4. Mar 23, 2016 at 8:49 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    What happened to the old school method of backing up and slamming on the brakes?
  5. Mar 23, 2016 at 9:06 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I don't think that was ever recommended as a way to adjust the brakes...
    Just pumping them should do the trick along with using the parking brake.
  6. Mar 23, 2016 at 11:33 PM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    What the manual doesnt show is that there this little tang that makes it hard to rotate. It helps to have another tiny screw driver to hold it back while rotating. The manual says 15 clicks, but for me it took 25 clicks to not feel any drag. I just hope before you take it to the dealer that the wheel moves freely....
  7. Mar 24, 2016 at 3:23 AM
    Tacoma Mike
    Southern Maine
    This will be my last post on this subject.
    The star wheel auto adjust does a lousy job adjusting.
    25 clicks loose is so far out of adj. that brake bias is effected and accelerated front brake wear occurs.
    Low brake pedal and out of adj e-brake is a result also.
    Just remember anything you do to a brake system affects the stopping distance and reaction time of the system. If you don't know what your doing, which I see all the time here and in my bay, don't touch them. Peoples lives are at risk.
    Drainbung and Tatts521 like this.
  8. Mar 24, 2016 at 6:34 AM
    Taco Pete626
    Peter
    Southern California
    so you just adjust to 15 clicks and not double check it?
  9. Mar 24, 2016 at 6:27 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    There should be some drag.
  10. Jun 27, 2016 at 1:14 PM
    NM Lance
    NM Lance Well-Known Member
    This thread may have died, but here I go... I replaced my shoes recently and I adjusted them like I always have, a little bit of drag, but equivalent on both sides.
    My rear passenger side keeps tightening (by itself) to the point where it locks the wheel up. I have checked the brake cylinders and they seem to be free. I have also checked all my springs and hardware to ensure I installed everything correctly. Is it possible that there is an issue with my proportioning valve? I have never had to mess with one of these before, and I really do not see any way one of these could fail.
    This is only happening on one wheel. Any ideas?
    My brake fluid is 13 years old and has 210K miles on it and probably needs to be changed, but I really don't see how this could cause my issue.
  11. Jun 27, 2016 at 1:57 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    If assembled properly there is no way that the adjuster can tighten up the brakes more than normal. And certainly not to the point of locking up that wheel.
    Since your brake fluid is 13 years old and has 210 K miles on it I would suspect that the Brake Slave Cylinder is locking up due to moisture caused corrosion in the cylinder.
    Recommend you rebuild / replace the wheel cylinders in the rear ( both sides ).
    A good flush of the brake system and fluid replacement.
  12. Oct 10, 2023 at 11:52 AM
    TreeFortRichard
    TreeFortRichard Barcelona Red is the best red...
    Brian
    42.3115167,-71.6638516
    '23 SR5 DCSB 4x4 Barcelona Red
  13. Oct 10, 2023 at 12:45 PM
    TreeFortRichard
    Brian
  14. Oct 10, 2023 at 7:17 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
