Please help with SRS codes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by gdry06, Oct 3, 2013.
  1. Oct 3, 2013 at 8:46 PM
    gdry06
    gdry06 [OP] Well-Known Member
    Gary B
    PNW
    06 TRD SPORT
    3Link'd with trailgear rock assault housing, 295x75x18 Nitto m/t shackle flip kit w/ omd spring refurbs, roof rack, toyota toolbox
    im getting three codes after my sas 51, 14, and 43. i found out 2 of 3 codes might be.
    51 - spiral cable
    14 - front driver impact sensor.(wires were cut when installing steering box but was repaired) still got the code!! what do you guys think?
    43 - ?????
    thanks in advance.
    -Gary
  2. Oct 4, 2013 at 1:28 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Code 51 - B1800/51 Short in Driver Side Squib Circuit. 1. Instrument panel wire. 2. Spiral cable. 3. Steering pad (Driver side squib). 4. Center airbag sensor assembly.
    Code 14 - B1615/14 Front Airbag Sensor LH Circuit Malfunction. 1. Instrument panel wire. 2. Engine room main wire. 3. Front airbag sensor LH. 4. Center airbag sensor assembly.
    Code 43 - B1660/43 Passenger Airbag ON / OFF Indicator Circuit Malfunction. 1. Passenger Airbag ON/OFF Indicator (Passenger seat belt warning light assembly. 2. Instrument panel wire. 3. Center airbag sensor assembly.
    The dealer can reset these codes if you do not have the Techstream Software available.
    There is a jumper you can install in the DTC3 Connector pins # 04 ( CG ) and # 13 ( TC ) to clear the codes
    DTC CLEAR (USING SST CHECK WIRE) (a) Clear the DTCs.
    (1) When the ignition switch is turned off (turned to the lock position), the DTCs are cleared. HINT: Depending on the DTCs, the DTCs may not be cleared by turning off the ignition switch. In this case, proceed to the next procedure.
    (2) Using SST, connect terminals TC and CG of the DLC3, and then turn the ignition switch to the ON position. SST 09843-18040
    (3) Disconnect terminal TC of the DLC3 within 3 to 10 seconds after the DTCs being output, and check if the SRS warning light comes on within 3 seconds.
    (4) Within 2 to 4 seconds of the SRS warning light coming on, connect terminals TC and CG of the DLC3.
    (5) The SRS warning light should turn off within 2 to 4 seconds after connecting terminals TC and CG of the DLC3. Then, disconnect terminal TC within 2 to 4 seconds after the SRS warning light turning off.
    (6) The SRS warning light comes on again within 2 to 4 seconds after disconnecting terminal TC. Then, reconnect terminals TC and CG within 2 to 4 seconds after the SRS warning light coming on, connect terminals TC and CG of the DLC3.
    (7) Check if the SRS warning light turns off 2 to 4 seconds after connecting terminals TC and CG of the DLC3. Also check if the normal system indication is displayed within 1 second of the SRS warning light turning off. If DTCs are not cleared, repeat this procedure until the codes are cleared.
  3. Oct 4, 2013 at 1:34 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    I believe there is a recall for the Spiral Cable. You could get the recall done and codes reset for free:D
  4. Oct 4, 2013 at 5:54 AM
    gdry06
    Gary B
    PNW
    06 TRD SPORT
    I wish. Toyota says my vin # isn't part of the recall. Its bs..
    Thank you jimmy.. very helpful info. Ill give it a shot.
  5. Oct 4, 2013 at 10:12 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You are welcome! I hope it works out for you.
  6. Oct 7, 2013 at 8:13 PM
    gdry06
    Gary B
    PNW
    06 TRD SPORT
    air bag light is gone finally... thanks jimmy.
    on a side note, the dam horn is stuck on.
  7. Oct 8, 2013 at 4:52 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    Glad I could shed a little light for you! Best of luck for the horn. What happened? At least you can unplug the horn.
    I think the horn also goes through the spiral cable. Yep it sure does. IMO - Check the horn relay and if it isn't stuck it will have to be a short to ground on the steering wheel side of the relay. The switch in the steering wheel just applies ground to the relay coil through the spiral cable when pressed. Like in the simplified print below. When the Horn Switch is pressed it completes the circuit to ground for the Horn Relay Coil to Ground. This closes the Horn Relay Contact which provides 12 VDC to the Horn and on to Ground. The 12 VDC comes from a common source from the 10 Ampere Horn Fuse.
    From the Tacoma 2nd Gen Service Manuals.
    10 Amp Horn Fuse, 12 VDC > _________ > Horn Relay Coil > _______ > Spiral Cable > ___>Horn Switch > _____________ > Ground
    10 Amp Horn Fuse, 12 VDC > _________ >Horn Relay Contact > _____________________ > Horn > ___________________> Ground
  8. Jan 19, 2014 at 12:22 PM
    Rcc
    Rcc Member
    So was it the clock spring or something else??
  9. Jan 23, 2014 at 5:16 AM
    gdry06
    Gary B
    PNW
    06 TRD SPORT
    Im not sure. Air bag light is back on and still.no horn.. but the cruise.control works..
