Please help with understanding OBDII live scan results
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Jul 22, 2022.
  1. Jul 22, 2022 at 4:29 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    This is all while idling. I figured I'd show it getting up to operating temp, however if you want to skip ahead, I put it into drive at 4:40, then I struggle to get it into neutral at 5:45, reverse at 6:20 & then back to park at 6:50. Oh, & try & not let the phone distract you too much.
  2. Jul 22, 2022 at 5:50 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    What are you trying to figure out or having problems with?
  3. Jul 22, 2022 at 6:12 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Your idle seems a bit high to me, in both park/neutral and in gear.
    That might be why it’s a bit hard to get into and out of gear.
    MalinoisDad likes this.
  4. Jul 22, 2022 at 6:53 PM
    Kristi with a K
    Western MA
    Ha-ha! Sorry. I should have clarified. It was just the angle I was at what with trying to keep the camera on the phone while shifting.
    The high/rough idle is the main one. & I'm not sure why it doesn't show on the phone when I turn it sideways, however the scan states I am stuck in a closed loop. My understanding is it's supposed to go to open when I first start the truck & when I coast.... It does not.
  5. Jul 22, 2022 at 7:16 PM
    Smokestacks
    BayArea
    Closed loop is good. Open loop turns on when ther is errors and money light pops on.
  6. Jul 22, 2022 at 7:20 PM
    Smokestacks
    BayArea
    Rough like a misfire?
  7. Jul 22, 2022 at 7:37 PM
    Kristi with a K
    Western MA
    No. well, maybe? Go to around 6:40 in the vid. That's with me holding the cam, elbows on the arm rest. Then I switch to park & you can see the dif. The rough idle is in gear & i can kinda hear it at times through the exhaust? I did the manifold crossover gaskets & thought that took care of it. I pass the smog test on the scanner.
  8. Jul 22, 2022 at 7:42 PM
    Kristi with a K
    Western MA
    I see the timing is off, but isn't that adjusted for by the ECU? There's nothing I can do to fix that, correct? I mean short of doing the belt.
    One thing I have not done is valve clearance.
  9. Jul 22, 2022 at 7:50 PM
    Kristi with a K
    Western MA
    passed compression test. coils, plugs, wires, injectors, all done
  10. Jul 22, 2022 at 8:18 PM
    Smokestacks
    BayArea
    Timing belt on these engines skip around every cycle and You would probably be having more serious issues if that was off. You were having this problem before all this was done?
  11. Jul 22, 2022 at 8:24 PM
    Smokestacks
    BayArea
    Clean MAF sensor or Bad gas maybe? Any exhaust smoke?
  12. Jul 22, 2022 at 8:32 PM
    Kristi with a K
    Western MA
    I think loping is what it's called.
    I was actually having a low idle. Then I went down into the intake manifold & cleaned the crud out of everything. When I was done, the idle was high. That was last summer. Been chasing it off & on ever since. It was suggested by TW members that I get a live scan tool to help pinpoint the prob.
  13. Jul 22, 2022 at 8:37 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Possibly a vacuum leak. How are the lines looking going to the intake? Any micro cracks in the rubber?
  14. Jul 22, 2022 at 8:57 PM
    Kristi with a K
    Western MA
    This is where I started cuz I was hearing hissing. I had already replaced all the hoses. So I doublechecked everything & re-swapped out a few of the new silicon ones for fuel line, like at the brake booster. Then I found out I needed to do the manifold crossover gaskets. Thought that would take care of the idle issue & the hissing. It did help some with the idle, just not enough. I do swear I still hear a hissing though. Somewhere drivers side toward the firewall.... I did an engine vacuum test going through the booster coupler & passed. Thought it might be the booster since it got skipped in the test, however that's ok as well.
    Deathbysnusnu[QUOTED] likes this.
  15. Jul 22, 2022 at 9:03 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Track down the hissing. Get a spray bottle with a drop or two of dish soap and start spraying lines. You're looking for a change in idle.
    Replace any lines that fluctuate the idle when sprayed.
  16. Jul 22, 2022 at 9:24 PM
    Kristi with a K
    Western MA
    What's the point of the IACV then?
  17. Jul 22, 2022 at 9:31 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    To allow air around the throttle plate when it's closed at idle. And control rpms when loads are added like AC and power steering. Once they went to electronic throttle bodies the throttle motor controls it all
    I doubt you have an intake leak, the long term trim would be high positive, not negative.
    All the data looks pretty good, but i agree the idle is a little high.
    Since you mentioned the IACV have you checked it? Is it gummed up with carbon, can it close fully? Can you block it off with gasket paper or something. See if the idle comes down
    Is the throttle cable routed correctly? Is it taught against the throttle plate or is there some slack? Unhook it or loosen it up
    TnShooter likes this.
  18. Jul 22, 2022 at 9:37 PM
    Kristi with a K
    Western MA
    @Smokestacks stated, having a constant closed loop is best. Wouldn't this mean the IACV would be closed at all times?
  19. Jul 22, 2022 at 9:39 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    No closed loop means the computer is looking at the oxygen sensors for more precise fuel control.
    As apposed to open loop like when it's warming up or there's a problem so it goes into fuel enrich to protect the engine
    Idle air control valve doesn't affect fuel mixture. Just idle speed
    But he's right, closed loop means the computer is happy. Idle can be a touch high and the computer won't notice
  20. Jul 22, 2022 at 9:56 PM
    Kristi with a K
    Western MA
    My live scan states that I am stuck in a closed loop. I put this in a later post, so this is why it is part of the discussion. It is not open when warming up & I believe my high idle indicates there is a problem, yet I stay in a closed loop.... always....
    I got to reading a post on Toyotanation & I guess I must be misunderstanding it. I pulled this from the post.... maybe it's a different type of IACV?
    "Feedback (Closed Loop) Idle Air Control
    The ECM has a preprogrammed target idle speed that is maintained by the IACV based on feedback from the NE signal. Feedback idle air control occurs any time the throttle is closed and the engine is at normal operating temperature. The target idle speed is programmed in an ECM look up table and varies depending on inputs from the A/C and NSW signals. Any time actual speed varies by greater than 20 RPM from target idle speed, the ECM will adjust the IAC valve position to bring idle speed back on target. The ECM utilizes a feedback idle air control strategy. That is, when the actual engine speed is lower than the target idling speed, the ECM signals the IACV to open. Conversely, when the actual idle speed is higher than the target idle speed, the ECM signal the IACV to close."
