PLEASE HELP!!!
Discussion in 'Suspension' started by lodi781, Dec 26, 2012.
  1. Dec 26, 2012 at 12:07 PM
    lodi781
    lodi781 [OP] Alexander Supertramp
    shelton CT
    '16 4runner trail
    ARB by-51’s, dobinson springs, Gobi Rack, Black Oak single row LED roof bar
    Lifted my truck almost a month ago...Yesterday I noticed a slight vibration..but not huge. I almost thought it was the tires being stiffer. Then I noticed that under braking from about 40 mph and down, if i shifted into neutrual ( 6 spd) there would be a shudder just before I came to a stop, and it sounded like the drive shaft was still spinning when the other gears were'nt..it was weird. It's still doing it today....any ideas?????:(
  2. Dec 26, 2012 at 3:30 PM
    lodi781
    shelton CT
    '16 4runner trail
    I'm the first one with this shit....craptacular. I'll let you all know how it works out.......
  3. Dec 26, 2012 at 3:36 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    I can't really help you out. But free bump for you. Did you install the cb drop and no shims? Try to use some kind of straight edge, maybe a string pulled tight beneath your driveshaft to judge how straight it is.
  4. Dec 26, 2012 at 3:50 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '22 Cummins
    What lift?? And as evan said did you shim it up?
  5. Dec 26, 2012 at 3:55 PM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    The driveshat is spinning if the truck is moving.
    Low speed vibrations are usuall due to drive line angles being out of wack, not equal.
    Some lifts change the angle enough to cause tis vibration, possible correction can be shimming the rear end leaf spring to change the diffs angle.
  6. Dec 26, 2012 at 3:58 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  7. Dec 26, 2012 at 4:18 PM
    lodi781
    shelton CT
    '16 4runner trail
    Hey guys, back on.....My buddy and I think we have it. It could be my flywheel. This only happens when im decelerating. If i'm driving and just let off the gas, I get a small vibration. As my speed drops below 40 MPH, the vibe gets more intense.
    Now, Say i'm pulling up to a light, and pop it in neutral and coast up to the light, as I brake, i get a vibe, then when I stop it sounds like even tho the rest of the truck has stopped, something is still spinning. I checked the drive shaft at the transfer case, there is no movement. All my wheel weights are on. And the length mid axle to axle is spot on. Could be the fly wheel ( or other clutch issue) as i've had the fly wheel replaced once already on this truck.
  8. Dec 26, 2012 at 4:26 PM
    lodi781
    shelton CT
    '16 4runner trail
    ...and my friend just grabbed me...someone either on here or TN had the exact same problem as me, he replaced all 3 u joints. He checked them first, they were tight, but as soon as he took them off all the signs of needing new ones were there. Fixed his problem 100%. I'll try that and see what happens.
  9. Dec 26, 2012 at 4:29 PM
    Oowen
    Owen
    Reno, NV
    '22 Cummins
    Wait... So when you are decelerating it only does it at around 40?
    Mine does it too, not exactly sure what it is.
  10. Dec 26, 2012 at 4:36 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    Check your pinion angle
  11. Dec 26, 2012 at 4:50 PM
    lodi781
    shelton CT
    '16 4runner trail
    yep...and when I went bacvk under my rig and checked the shaft again, theres like 1\2 an inch of play....
  12. Dec 27, 2012 at 12:05 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I'm still stuck on why a flywheel change was needed......:confused:
  13. Dec 27, 2012 at 4:20 AM
    lodi781
    shelton CT
    '16 4runner trail
    when I was slowing to a stop, the sound that was being made was like a propeller coming to a stop. I knew that the fly wheel had been replaced twice under warranty, and with the sound it was making ( hard to describe online) We thought it could have been a fly wheel issue. And it still might be. I may have two things going on right now. But the Auto parts store had 3 u-joints left:)cool:) so I scooped them up and will try to put them in today....
  14. Dec 27, 2012 at 7:54 PM
    lodi781
    shelton CT
    '16 4runner trail
    Well, I got them in. Out of the three, the one connected to the rear diff had the problem. It was completely locked in one direction of travel (? don't know if I'm saying that right)... North\south was fine, east\west locked straight, wouldn't budge. I pulled it out, only one of the posts was rusted dust, but i guess it was enough to cause havoc. The others were well lubed, but worn. Took it for a quick ride up the street, and she didn't make any noise and felt solid again. It's amazing what a little 18 dollar part can do to a 30k truck..lol.
  15. Dec 27, 2012 at 7:56 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  16. Dec 27, 2012 at 8:01 PM
    lodi781
    shelton CT
    '16 4runner trail
    Hey evan...you ever get your lift in?
