Please help!
Discussion in 'Technical Chat' started by Kylesyota675, Mar 10, 2013.
  1. Mar 10, 2013 at 9:52 AM
    Kylesyota675
    Kylesyota675 [OP] New Member
    07 taco
    33's 6'fabtech with coilovers
    So about a week ago I did a rear diff seal on my 07 taco 4x4 with e-locker. Everything worked out great other than when I put the truck into 4lo the locker won't engage and the abs light turns on. I have no clue what to do but I really dont want to take it to the dealership. Any advice?
  2. Mar 10, 2013 at 4:48 PM
    BamaToy1997
    Bill
    Navarre, FL
    Go back through what you did during the service. Check and make sure that you did not accidentally forget something. Then check the fuse for the E-locker. Lets go from there..
  3. Mar 10, 2013 at 4:54 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    What is a rear diff seal exactly?
    3rd member to housing? pinion seal? What did you unplug and or remove?
    I'd check your e-locker motor connectors.
    In 4 low the ABS light should come on anyway, no? As 4 low disengages ABS.
  4. Mar 11, 2013 at 7:35 AM
    Kylesyota675
    07 taco
    3rd member to housing seal..I removed the third member and unpluggged and removed locker. Ive checked to make sure everything was back the way I took it off and 95% sure it is. I'll check the fuse and I'll triple check everything that I did. Should I try cleaning the locker plugs with electrical cleaner?
  5. Mar 12, 2013 at 11:34 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Since you can not remove third with out having locker in locked position. did you remove locker itself from third member? if yes, did you put back into locked position?
