Please Help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jso223, Dec 15, 2014.
  1. Dec 15, 2014 at 12:53 AM
    jso223
    jso223 [OP] Active Member
    I had just recently used Penzoil Pure Plus on my Tacoma 4.0 and when I went to change the oil i seen this in the filler cap. I don't think I will ever use penzoil again since they changed there formula. Can someone please let me know if you think my Truck will be ok. I have swithced back to amsoil. I have always done 5,000 mile oil changes with only going over to 7,500 miles while changing the filter at 4,000 one time.
  2. Dec 15, 2014 at 1:35 AM
    DPC08
    DPC08 Well-Known Member
    FL
    09 DCSB
    Getting there...
    I believe that's a sign of water in your oil. Do you drive short distances? Not enough time for the engine to warm up and burn off the condensation will do that.
  3. Dec 15, 2014 at 2:04 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Pretty common when short trips and lower temps occur. Its normal for this time of year.
  4. Dec 15, 2014 at 2:15 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    yep
  5. Dec 15, 2014 at 2:33 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What everyone else said. Normal due to the extended filler neck also.
  6. Dec 15, 2014 at 3:45 AM
    gazingwa
    gazingwa Well-Known Member
    Slower Lower Delaware
    15 PreRunner Doublecab 2.7
    OEM: Backup Camera, Bed Mat, Wiper Switch. Aftermarket: Fog Lights, Pop and Lock, Truxport, MS2's Debadged
    Not Pennzoil's fault, as others have said it's condensation and your engine isn't getting warmed up enough. I personally use Pennzoil Platinum whenever I can(used to use Ultra but I can't find 0w20 in that).
    Look around here about it, it's one of the top rated oils.
    http://www.bobistheoilguy.com/
  7. Dec 15, 2014 at 4:00 AM
    Clearwater Bill
    Billy
    Largo Florida
    As others have stated, there's nothing wrong with your truck or Pennzoil.
    While Amsoil is ok, its a boutique oil that really doesn't deserve all the hype it's given by it's secret vendor supply chain.
    Modern oils with the SN API are almost as good as synthetics, well documented by independent oil testing.
    Running a full synthetic, unless you have some abusive use of the vehicle, you should easily get 10k (or more) between changes.
    To make yourself feel better, get a sample kit from Blackstone Labs and have them test it for you at your next 5k change.
  8. Dec 15, 2014 at 7:23 AM
    jso223
    I usually drive about 87 miles a day it's around 40 miles one way to work.
  9. Dec 15, 2014 at 7:27 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    i think it might have something to do with what how long the engine ran before you opened the cap. And how humid it's been etc. it's not an uncommon occurrence IIRC.
  10. Dec 15, 2014 at 7:37 AM
    jso223
    I use to use penzoil ultra platinum but the last time I bought it they had changed the formula using a natural gas base stock and I believe the aditives sepeprate from the base stock. I usually drive around 87 miles or more day while not driving under 40 miles one way. It has been a little cold though around 25 to 35 degrees. I don't doubt penzoil I have always liked there products. My dad has run it in his Dodge Avenger and it has over 300,000 miles on it.
  11. Dec 15, 2014 at 7:41 AM
    TacOffRoad11
    TacOffRoad11 Well-Known Member
    Josh
    Georgetown, KY
    '18 F150 XLT
    Its already been said but everythings good. Ive used nothing but Mobil 1 in all my vehicles and I have seen the exact same thing a time or two.
  12. Dec 15, 2014 at 8:43 AM
    jso223
    Thanks everyone for your help. For some reason I thought something was wrong because I had never seen it do that before.
