Please help!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by Boyhowdy, May 6, 2017.
  1. May 6, 2017 at 9:00 AM
    Boyhowdy
    Boyhowdy [OP] New Member
    2004 Tacoma quad cab
    Hello! My 2004 Tacoma with 6 " fabtech lift keeps overheated drivers side bearings... pretty much considered unsafe and unusable. After the fact I just had replaced bearings 500 miles ago. Any advice sure would help.
  2. May 6, 2017 at 9:04 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    whats your cv joint angle look like? Maybe need a differential drop. Did you replace the bearings yourself or a shop?
  3. May 6, 2017 at 9:09 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Please change the name of your thread. Calls for "help" are reserved for times where a member needs actual and immediate help. Examples are being stranded off road with an immobile truck. Miles from food or water or shelter.
    A good alternative would be "help with overheating bearings"
    Also, starting two threads on the matter will not get you answers any faster.
  4. May 6, 2017 at 1:52 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Well are you talking front or rear bearings hard to tell ??
  5. May 7, 2017 at 4:30 PM
    wht95scort
    wht95scort Well-Known Member
    NJ
    2001 3.4 gas guzzler
    Are you properly torquing the axle nut or just zipping it on full blast with a gun?
