Please Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rocket86, Jan 30, 2025.
  1. Jan 30, 2025 at 5:21 PM
    Rocket86
    Rocket86 [OP] Well-Known Member
    2002 all electric. Changed drivers door handle. Auto Windows work perfectly.
    The lock on passenger is 100% When using fob Driver unlocks/locks 100%. I get locked in because drivers side try’s strong 100% every time and I have to turn the truck on off, keep trying to unlock it until for reasons I don’t understand it finally opens I have door cover off trying to see where it might be catching.
    Key will unlock but not lock the door.
  2. Jan 30, 2025 at 5:31 PM
    MGMDesertTaco
    check your fuses, relays and any connections you took apart in the door ; is there a metal rod in the inner door that connects the door handle/lock?
  3. Jan 30, 2025 at 5:43 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I’m having a hard time understanding what you wrote.
    But a parts diagram is where I’d start.
    Check the link in my signature.
  4. Jan 30, 2025 at 6:03 PM
    Rocket86
    Yes there is. Hold on I blew the 30 amp power fuse under the dash and replaced it, must of shorted it out in the process. Now Plenty of power to the locks?
  5. Jan 30, 2025 at 6:04 PM
    Rocket86
  6. Jan 30, 2025 at 8:09 PM
    MGMDesertTaco
    Did you fix it?
    T4R_hereforbearings likes this.
  7. Jan 31, 2025 at 7:21 AM
    Glamisman
    Glamisman Well-Known Member
    If I understand your description of the problem correctly the D/S lock-unlock is intermittant. I have found that there is a guide clip on the door that comes from the interior door pull to the door latch mechanism. If the rod from the interior door pull is not supported by this clip there is so much slop and flop in the rod that the door will intermittantly not lock/unlock, the interior door lock/unlock knob only goes part way up or down and when you pull the exterior handle it will pull the latch into the lock position.
  8. Jan 31, 2025 at 7:22 AM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Also not sure if I understand whats happening, but agree it sounds like a rod problem
  9. Jan 31, 2025 at 11:06 AM
    Rocket86
    Thank you
  10. Jan 31, 2025 at 11:07 AM
    Rocket86
    Thank you
