Please list your model, year, and any major repairs or fixes you have done
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paczowski123, Aug 22, 2011.
  1. Aug 22, 2011 at 9:01 AM
    Paczowski123
    Paczowski123 [OP] Well-Known Member
    David
    Kennesaw
    05 prerunner trd off road
    OME 3" Lift, Kennesaw Mountain Off Road Wincher Front Bumper w/ 5" Integrated off road lights, Kennesaw Mountain Off Road Multi Carrier Rear Bumper w/ swingout tire carrier, Jerry can, and hi-lift mount, Sof-topper rear cargo cover. Galaxy DX44V CB Radio W/ 4' FireStikII, Rock Sliders
    Ok, well I am new to Tacomas and have always owned jeeps. I was a member of a jeep forum and this topic came up and became very popular and helpful.
    So lets give it a shot, I have not found anything like this so hopefully im not repeating anything!
    mine is a 05 prerunner TRD off road, 86K only owned it three weeks and have done diff fluid, and oil change, cleaned air filter and about to do plugs and trans flush.
  2. Aug 22, 2011 at 9:04 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    2006 TRD Sport, haven't done anything major in the 6 mos I've had it, but the rear spring TSB was never done, so I would imagine I'll need to get some Dakars before I haul anything bigger than my 300 lb boat.
  3. Aug 22, 2011 at 9:27 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Those are major repairs :confused:
    In my book those are maintenance items :)
  4. Aug 22, 2011 at 9:29 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    just did a passenger side ball joint on my 97 toyota tacoma 4wd 4cyl. owned it for about a year and a half
  5. Aug 22, 2011 at 9:33 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    2007 DCSB SR5 4x4 (Non-TRD)
    I'll list all repairs other than maintenance (it's a short list :))
    -Blower motor chirp fix
    -TSB to replace the rear leaf pack and new bilstein shocks all around
    -Replaced the leaf pack again because the TSB ones flattened out
    -I've had heat shields come loose on 3 occassions and cause a racket (different heat shield each time).
    Aside from the suspension, it's been a pretty solid truck.
  6. Aug 22, 2011 at 9:34 AM
    Fightnfire
    Fightnfire Recklessly tired
    Marysville, WA
    09 Access Cab V6 4X4
    Softopper, Bilstein 5100's @ 1.75 in the front, TSB Rear, 17x8.5 Lvl 8 Guardians, 265/70-17 Goodyear Wrangler Duratracs, Scooped, Anytime fog mod, Osram Nightbreakers, LED Interior lights, Debadged, Painted valance, Removed rear head rests, De-flapped, Hidden Hitch installed, Weather Techs, Flyzeye'd A/W/A, Cover Kings,... oh and the hot wife mod.
    2009 Access Cab w/ 20k miles SR5 V6 AT
    No Major Repairs
    -Did get the TSB Rear done
  7. Aug 22, 2011 at 9:35 AM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    2009 Double cab off road 4x4.
    Diff Seal went bad, replaced under warranty.
    That's it!
  8. Aug 22, 2011 at 9:37 AM
    2.7bluetaco
    2.7bluetaco Well-Known Member
    jacob
    middlesex,nc
    06 SR5 tacoma 2.7
    trd door stickers k&n cold air intake projector head lights 40 series flowmaster exhaust system nitto terra grappelers 265/70/16 billet grille
    2006 toyota tacoma sr5 4x4
    109xxx miles(i bought it in 09 w/ 32xxx)
    3 inch procomp lift(stupid spacers)
    285/75/16 firestone mts
    k&n cold air intake
    bhlm
    blacked out billet
    changed sparks
    but no major repairs yet
  9. Aug 22, 2011 at 9:39 AM
    BenWA
    BenWA Well-Known Member
    Seattle @ 0.9 Mach
    '06 Double Cab TRD Off Road 4X4
    I'm confused about the intent of the OP: When you say "you have done" do you mean personally done, as in DIY work or do you mean in general what work has been done whether by you or by a professional?
    Assuming the latter:
    - torn cv boot from driving over a piece of wire that wrapped around the boot and sliced it
    - overhead compass replaced under warranty twice before I found the DIY fix on TW.
    Repairs that I will need to make soon:
    - bad front diff bearing that needs replacing
    - at least one LCA bushing that is probably seized that needs to be replaced.
    Note that both of these are directly related to lifting the truck and would not have been issues at stock ride height.
  10. Aug 22, 2011 at 9:48 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    I purchased my 2004 4x4 last Dec with 66,000 on it. Now has 77,000 and so far I have not done any repairs just upgrade mods. My work truck is a 2007 4x4 with 50,000 on it and has not had any repairs and the only mod was an add a leaf.
  11. Aug 22, 2011 at 10:30 AM
    Paczowski123
    David
    Kennesaw
    ANything that would be considered a repair..i dont care about mods just service/repairs?
    also, i dont care whether you have done em or a dealer...just what has been done to the truck as far as repairs/maint. looking for commonalities in repairs, or common problems to look out for if any with these trucks..they seem bulletproof...
  12. Aug 22, 2011 at 10:32 AM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.03CUPID
    1.03. Kbro2s. ICONS.
    2006, DCSB, 2WD, 44,600 miles. No major service. Just new tires / regular oil changes.
  13. Aug 22, 2011 at 11:03 AM
    TMW
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    I do notice something odd on my 2007 work truck. The air has never blown hard from the vents. I have a 2004 GMC and my 2004 Tacoma and they both blow really hard. The 2007 feels like the other trucks when on a 2 or 3 setting. It's never been a problem of not cooling or heating the cab so I usually forget about it. I keep thinking I'd have the dealer look at it but never have. Curious if anyone else has had this problem?
  14. Aug 22, 2011 at 4:19 PM
    07TaCo07
    07TaCo07 Well-Known Member
    oregon
    07 double cab 6" lift
    6" fab tech lift, 35" toyo m/t, 17" teflon wheels
    Front wheel bearing, blower motor, and engine head leaking oil. Oil leak fixed tsb
  15. Aug 22, 2011 at 4:27 PM
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 Mid-Travel 4x4 DCSB 6spd
    Kings Mid Travel, BAMF bed rack, RTT, dual battery, OBA, ARB locker, 4.56 gears
    2007 - clutch TSB, front driver wheel bearing, replaced clutch + some other misc stuff.
    Honestly, coming from a Jeep, you'll find less things that'll break on you.
  16. Aug 22, 2011 at 4:34 PM
    urbancaveman
    urbancaveman Member
    John-Michael
    Watkins Glen NY
    97 Tacoma
    Due to recall on the frame and ever dealerships ignorance i replaced my frame and everything under the box myself
    1997 Tacoma 3.4 6cyl.
    replaced my frame,gas tank, sending unit, rear shots,
  17. Aug 22, 2011 at 4:50 PM
    Koby
    Koby Well-Known Member
    Vancouver
    06 access trd
    2in OME suspension lift ARB bull bar 8000lb WARN 32`duratracs on 17 procomp 7033`s
    2006 trd access cab. I've had to replace both wheel bearings, ball joints, noisy heater fan, tsb leaf springs, tsb on the squeaky leafs, and now I'm about to put in a new front diff. I believe the roller bearing in the diff are shot and have caused a great deal of vibe post lift. Replacing the diff is cheaper than ripping it apart to replace the bearings. Oh, I have 152,000 km on her....and a one piece drive shaft to fix the takeoff shudder because of the lift.
  18. Aug 22, 2011 at 4:55 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SP... CaL
    11 TRD sPort
    5100's@1.75 Horns (Andres) Satoshi TRD cat back BHLM
    2011 dbcab sport 15k
    Purchased 9/10
    Rear tsb
    No problems
  19. Aug 22, 2011 at 5:01 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    98 4wd 215,xxx miles replaced cv axle and just broke timing belt. Replaced waterpump and belt.
    06 x-runner replaced synchronizers in transmission and 1st gear. The gear was my fault. And tires lol. Too much powa!
  20. Aug 22, 2011 at 5:02 PM
    98_Mud_bug
    lucedale Ms.
