Please respond if this has happened to you .......
Discussion in '3rd Gen. Tacomas (2016-2023)' started by T059736, Sep 17, 2023.
  1. Sep 17, 2023 at 5:13 AM
    T059736
    T059736 [OP] Member
    2020 Tacoma TRD
    Setting the scene - two lane highway; speed limit 60mph; following a vehicle with approx. 2 sec interval; speed control engaged with lowest space setting engaged, highway widens to account for a left turning lane, leading vehicle identifies "turning left" into that lane, as vehicle enters turning lane it slows down for the left turn and my vehicle goes into "automatic emergency braking". My vehicle speed is rapidly reduced from 60 mph to 30 mph. If there would have been a vehicle behind me; I'm sure I would have been rear-ended. The car turning left was in the "left turning" lane when this happened and I had a clear lane in front of me.
    Other than not using the speed control feature; is there some other feature with the auto braking system that will prevent this from happening?
  2. Sep 17, 2023 at 5:17 AM
    Greg-tacoma
    Greg-tacoma Well-Known Member
    Greg
    2016 Black 4cyl 4wd
    Bed cover, soon bug deflector, halo interior lights and backup
    Yes this happens in multiple vehicles. Very annoying. I have set my distance with the most spacing and it still happens.
    Gunshot-6A and batmanis243 like this.
  3. Sep 17, 2023 at 5:18 AM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    You’re following the vehicle to close while using the radar on cruise control or the vehicle enters your radar to close and the truck thinks there’s going to be a collision.
    if you hold down the cruise control button you can turn off the radar and use it like normal cruise control.
    That’s what I do. I can’t stand the how it slows down my truck when someone in front of my isn’t going the speed limit and I want to pass.
  4. Sep 17, 2023 at 5:21 AM
    GBourne
    GBourne Just a regular guy
    Grant
    Surprise, AZ.
    23 Ram 1500 Classic
    Dumped the Tacoma, that's all it needed.
    That’s why I have all that crap turned off or to it’s least sensitive setting.
    Has happened to me multiple times in multiple Toyotas and various situations.
    Gunshot-6A and zoo truck like this.
  5. Sep 17, 2023 at 5:30 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I don't think you can turn off the TSS system, can you?
    Junkhead likes this.
  6. Sep 17, 2023 at 5:33 AM
    Xero
    TSS can be turned off and adjusted but the pre-collision can’t be turned off.
    StayinStock and Gunshot-6A like this.
  7. Sep 17, 2023 at 5:35 AM
    RedWings44
    Michigan
    That's what I was referring to since this is usually caused by that. Is there anything you can turn off aside from radar cruise, lane keep assist, etc?
  8. Sep 17, 2023 at 5:45 AM
    Xero
    You can adjust sensitivity.
    Only time my warning and auto braking turn on is at low speeds and I’m actually about to rear end someone. Got distracted by my kids and it almost happened.
    RedWings44[QUOTED] likes this.
  9. Sep 17, 2023 at 5:46 AM
    nucl3ar
    nucl3ar 2021 White Tacoma Limited 4x4
    Raleigh, NC
    OVTune Meso Total Tail Stage 1 tail lights BAKFlip MX4 Tonneau Cover
    Happens to me occasionally. I only use the radar cruise control whenever the roads are more open for this reason. If they get busy, I just drive normally.
    One weird issue I've ran into is this corner near my house, if a car is headed towards me at the right spot, the pre-collision kicks in. This started after I had the windshield replaced, so I am guessing the 'calibration' safelite did wasn't good.
    Gunshot-6A likes this.
  10. Sep 17, 2023 at 5:48 AM
    TartanEagle
    TartanEagle Well-Known Member
    '17 ACLB 4x4 MT
    Too close.
    Rule of thumb is one second for every ten miles per hour. Should have had a 6 sec spacing (at 60 mph).
    Junkhead, Chew and Tallgrass05 like this.
  11. Sep 17, 2023 at 6:06 AM
    RedWings44
    Michigan
    I remember being taught this in driver's Ed. Then I began driving on the freeway and realized that someone else will just slide into that space if you leave it open. You just have to drive defensively and pay attention.
  12. Sep 17, 2023 at 6:08 AM
    TartanEagle
    '17 ACLB 4x4 MT
    Yep, that is the way it is taught. Works too.
    He wasn't on the interstate.
  13. Sep 17, 2023 at 6:12 AM
    RedWings44
    Michigan
    I didn't say OP was, I just meant in general. 7 seconds at 70 MPH is over 2 football fields (721 feet). 6 seconds at 60 MPH is nearly 2 football fields (528 feet).
    Far more practical at slower speeds though.
  14. Sep 17, 2023 at 6:17 AM
    TartanEagle
    '17 ACLB 4x4 MT
    Yep. And then you're supposed to increase that distance in poor conditions (rain, snow, fog, sleet, etc.) Obviously don't drive fast at all in icing conditions.
  15. Sep 17, 2023 at 6:23 AM
    RedWings44
    Michigan
    Generally, yes. I'm just saying, good luck if you absolutely live by that rule at higher speeds. It's a good rule of thumb for learning to drive until you become more comfortable with your vehicle's abilities, your own reaction times, etc. No matter your good intentions, someone else will be around to throw a wrench into that. One football field is over 10 car lengths. People aren't going to allow you to keep that much gap (let alone larger) on any interstate unless no one else is around. You just have to keep your head up is all. Around here most people are lucky to have 2 car lengths before initiating a pass.
  16. Sep 17, 2023 at 6:27 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    Some of y'all insist on using cruise under conditions that shouldn't in any way involve cruise.
    - if you are on a road with perpendicular intersections, maybe you shouldn't turn on cruise.
    Junkhead, Chew, OZ TRD and 3 others like this.
  17. Sep 17, 2023 at 6:30 AM
    Hogleg918
    Hogleg918 Well-Known Member
    Oklahoma
    Ranger Raptor, sorry TW
    When I see a vehicle slowing for a turn I just turn off the cruise and once they’ve turned, re-engage.
    Toyko Joe likes this.
  18. Sep 17, 2023 at 6:40 AM
    M1crazy
    M1crazy Active Member
    Barry
    Hillsboro MO
    2023 Access CabL TRD OR 4x4 AT Ice Cap
    I have had this happen in my three tacoma's 2021-2223 one 2022 4runner three 2022 silverado's 1 challenger (the challenger only warn's you). I was not following to closely actually not following at all there is a left turn lane ten minutes from my house on a highway. If there is a vehicle in the lane waiting to turn seventy five percent of the time this will happen. So needless to say when I a coming up to this turn lane I turn off cruise control drive through manually and the turn on the cruise control again.
    FYI I drive a commercial vehicle for 28 years I deliver fuel so camera reviews all the time and signals sent for following to closely.
  19. Sep 17, 2023 at 6:58 AM
    Dutch216
    Dutch216 Well-Known Member
    Dutch
    Cleveland Ohio
    2023 Tacoma TRD OffRoad Premium
    I think that cruise thing happened once to me in my first 300 miles. I turned off the cruise and said "Well I guess Ill have to read the manual" Ive realized recently that I constantly drive like I am driving a Semi with trailer. I keep that distance when some jackass goes between me and the truck I have plenty of time to slow down. Ive gotten REALLY used to it. I also went on a road trip with a friend of mine who owns a Ford Transit van. He drives like a lot of people describe in this thread. 1-2 car lengths away and aggressively constantly passing. all for 5 more mph. I 100% refuse to drive like that. Do the math.. you arent saving a significant amount time. Even when you are driving 14 hours.
    TartanEagle likes this.
  20. Sep 17, 2023 at 7:04 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    I'd be very surprised if you can't turn off the pre collision system; check the manual and all of the menu options on the dash display.
    In every Lexus and Toyota I've driven with these features, they are fairly straightforward to turn off. (The 4R is very easy to turn off, I'd assume the Taco is pretty similar).
    Oh, and to answer the question: this has happened with the auto braking in an Acura, but none of my Toyotas have braked at an inappropriate time. I've only had the 4R beep at me once (no braking), and I was driving pretty aggressively at that time.
    The bottom line is, they're imperfect systems thrown in as a selling point. They're going to make mistakes.
