Please respond if this has happened to you .......
Discussion in '3rd Gen. Tacomas (2016-2023)' started by T059736, Sep 17, 2023.
  1. Sep 17, 2023 at 8:07 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Same here.
  2. Sep 17, 2023 at 8:14 AM
    4runnerToTacoma
    4runnerToTacoma Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    This is reason why self driving cars still are not a thing.. its a computer, it sees yes or no, there is no maybe. So this causes stupid things like this to happen. Just drive it as a true truck should be driven! without help of fancy computers.
    LeakyAC and OZ TRD like this.
  3. Sep 17, 2023 at 8:17 AM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    1. In my early days of using the radar cruise system, I learned that if the car in front is decreasing speed quickly while changing lanes or turning, I need to cancel cruise. The system does not determine your lane is "clear" until the car in front of you is COMPLETELY gone. Sounds like this was a case where you were safe, but the system still thought a car was in front. Just take over driving real quick, then resume cruise when clear.
    2. The slightest input on throttle will cancel automatic braking applications when in radar cruise. Helps alot when you want to lane change. Let off the pedal, and the system takes back over.
    3. PCS can be disabled in the settings menu. It will turn back on when the truck is shut off and restarted. There's a TSB you can have applied to remember the setting after vehicle shutoff.
    RyanDCLB likes this.
  4. Sep 17, 2023 at 8:21 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Thank God I have a 17 without this crap but my wife’s 22 Prius has all that crap and it has done what you described several times. The Prius manual says that you can turn it off but it automatically resets when you restart your vehicle.
  5. Sep 17, 2023 at 8:21 AM
    Watacoola
    Watacoola Active Member
    Jordan
    2019 Tacoma TRD-Offroad
    Has happened to me before, that's why I drive with the traditional cruise control (Hold cruise control on for 5sec). I can't stand adaptive cruise control, especially in a built vehicle when momentum is crucial.
  6. Sep 17, 2023 at 9:37 AM
    terryhutchinson
    terryhutchinson Well-Known Member
    Terry
    2023 Tacoma TRD Off Road
    I've never used cruise control. I must be in a small minority; but I like feeling in control.
    OZ TRD likes this.
  7. Sep 17, 2023 at 9:39 AM
    Xero
    Xero Well-Known Member
    18 Tacoma TRD Off Road, 22 4R, 08 4R
    18 Tacoma TRD off road OME BP51 front Fox 2.0 Resi rear OME Dakar Meduim Yoko G006 325/75r16 Black Rhino stadium wheels Cali raised ditch light brackets Baja Designs S1 pods Baja Designs Squadron SAE fogs Prinsu Cab rack TRD Pro grille AVS rain guards Backwoods adventure mods hi-lite bumper BL Apex 12k winch Dobinsons 4x4 snorkel Sy-clone prefilter ARB rear diff breather relocation RRW rock sliders RCI full skids At the helm bed stiffeners lil b LCA skids Warfab Phantom rear bumper Warfab tie rod sleeves C4 fender liners Dirt king UCA Duro bump stops
    I used it all the time. It helps me from speeding :rofl:
    Helps on long trips when I drive from state to state.
  8. Sep 17, 2023 at 9:43 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Yes this has happened to me as well in my Tacoma.
    I never use the adaptive cruise control for this reason exactly. It’s extremely dangerous and could lead to a terrible crash because the truck automatically applies the brakes (heavily) without any warning. It’s honestly so dangerous I can’t believe they can have a feature like that in a vehicle.
    There’s been at least one time that it has almost gotten me rear ended at highway speeds when a vehicle in front of me was changing lanes (and there was no danger of a collision). Fortunately I reacted quickly enough and was able to turn off the cruise control.
    I only use the constant speed cruise control now. I’m shocked that Toyota or another automaker hasn’t been sued because of a crash resulting from a feature like this one. Maybe they have and I just never heard about it.
  9. Sep 17, 2023 at 9:47 AM
    andthen
    andthen Well-Known Member
    Fred
    22DCLB Lunar Rock
    Yep, happens more often than it should.
    1. Steer away from the lead vehicle so the sensor no longer sees it.
    2. Hover right foot over the gas pedal to overpower the automatic braking system.
    3. Turn off ACC until the car is gone, then restart it.
    I do it relatively seamlessly now. I use ACC more than I use the gas and brake pedals. The Volvo system is much better.
    RyanDCLB and Road_Warrior like this.
  10. Sep 17, 2023 at 9:51 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Also OP, if it wasn’t already mentioned…
    When you’re turning on the cruise control, hold the button down for a few seconds and it will select “constant speed cruise” control instead of the adaptive cruise control. This is the traditional cruise control that maintains one speed and won’t react to vehicles in front of you. That’s all I use in the Taco.
  11. Sep 17, 2023 at 9:57 AM
    T059736
    T059736 [OP] Member
    2020 Tacoma TRD
    Thank you all for the responses. Not wanting to insult or discourage answers; my thoughts are that any system that endangers life or may create accidents is not "smart". In fact; if systems are installed in devices that are to replace human thought or response; they should be smarter than humans or not be installed. My question is; "If you know that your vehicle "emergency brakes needlessly - as in my case and I and/or the dealership knows that this auto braking happens needlessly and we do nothing about it - Who is responsible IF my vehicle causes an accident where there is a death or heaven forbid a crippling?"
    I'm far from being legal counsel but I believe I know the answer.......
    Road_Warrior likes this.
  12. Sep 17, 2023 at 10:00 AM
    T059736
    T059736 [OP] Member
    2020 Tacoma TRD
    Thank you Road_Warrior. I will use your suggestion as a "drive around" until there's a better solution offered.
  13. Sep 17, 2023 at 10:15 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    :hattip:
  14. Sep 17, 2023 at 10:18 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    this happens to me all the time. incredibly annoying. i learned to disable cruise control in this scenario then re-enable after i pass the turning car
  15. Sep 17, 2023 at 10:39 AM
    #35
    perterra
    perterra Well-Known Member
    Tejas
    If Toyota drivers bodies were stacking up at the morgue, something would have been done already. It's more a perceived problem than real.
    Chew likes this.
  16. Sep 17, 2023 at 11:01 AM
    #36
    andthen
    Fred
    22DCLB Lunar Rock
    The system isn’t autopilot, you can’t forget about driving and have a coffee. You are still driving. And yes, you are still responsible. If your emergency braking system activates, and the moron behind you is too close, that’s their problem and they’re responsible for the accident.
    if we were to not partake in anything that could hurt us or someone else, we wouldn’t be driving cars or bathing or cooking because these and many other activities have killed and will continue to kill people. Maybe we should all have on padded suits with helmets?
    You tried the ACC and don’t like it, don’t use it. Write to Toyota and tell them that it needs significant improvement before your comfortable with using it.
    perterra and Chew like this.
  17. Sep 17, 2023 at 1:51 PM
    #37
    HBear47
    HBear47 Active Member
    H
    Oregon
    2023 Celestial Silver TRD OR
    TRD Lift Kit, Rock Sliders
    Yes, happens in our Honda Passport quite a bit. However, I can turn of adaptive cruise control and all is good. I have not had my Taco do this to me.
  18. Sep 17, 2023 at 1:55 PM
    #38
    Kwikvette
    Fresno County
    4 run, 2 don't
    Can confirm it happened in a Jeep Grand Cherokee SRT8 for the week I had it as well as a few other vehicles I borrowed from time to time
