please school me on this lawn mower
Discussion in 'Off-Topic Discussion' started by anotherreject, Apr 27, 2014.
  1. Apr 27, 2014 at 11:22 AM
    anotherreject
    anotherreject [OP] Well-Known Member
    Ive lived in apartments my whole life and for the time ive had my house ive been paying my neighbors to cut my grass.
    I found this craftsman mower at a yard sale for $40, i recognized the name brand and it started on the first pull so i bought it.
    Can anybody tell me what kind of gas oil etc to put in this? And what kind of maintenance if any. The guy didnt have the owners book
  2. Apr 27, 2014 at 11:27 AM
    wannabetrd
    wannabetrd Well-Known Member
    Zach
    Michigan
    SR5
    3inch front 2inch rear lift with add a leaf and extended brake lines trd exhaust
    I would have to say regular gas and probably some nd 30 weight oil the nd stands for non detergerant or straight 30 weight at least that's what I think
  3. Apr 27, 2014 at 11:32 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Yeah regular gas, not sure on the oil though.
  4. Apr 27, 2014 at 11:33 AM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    2020 t4r orp
    Bone f’n stock for now
    Regular gas and 2 stroke oil. I buy mine at wal mart it's in a little bottle about half the size of normal oil. It will say lawn mower on it. You should also get an extra spark plug for it. Just take yours out and go to autozone or advance and tell them to match it.
  5. Apr 27, 2014 at 11:33 AM
    CorrosiveTendency
    CorrosiveTendency When up to your nose in shit, keep your mouth shut
    Nathan S.
    Schuylkill Co, Pa
    05' DblCab SB Speedway Blue
    OME 885's, Locker Mod. Bilstein 5100's on 4 corners
    Run strait premium gas with ethenol stabilizer. And like Zach said, probably a strait weight small engine oil. Pick up a fresh spark plug and air filter while you are at it too.
  6. Apr 27, 2014 at 11:34 AM
    CorrosiveTendency
    Nathan S.
    Schuylkill Co, Pa
    That mower is not a 2stroke.
  7. Apr 27, 2014 at 11:38 AM
    Agent Smith
    Agent Smith Always outnumbered, never outgunned
    05 TRD Offroad Ivan Stewart Edition
    Toytec lift,FJ Anthracite wheels wrapped in BFG A/T 265/75/16's,WAAG Brush Guard, IPF 868's,sleeved fog lights
    Who makes the motor, Briggs and Stratton or Tecumseh? There also should be a sticker on the body of the mower with the Craftsman model and serial numbers. You can use straight 30w oil like wannabetrd suggested or 5w-30 synthetic for a wider range of operating temps. I'd pull the spark plug and air filter and bring those with you to Walmart or Home Depot to match to new ones. Take the blade off to get sharpened and your GTG for the season
  8. Apr 27, 2014 at 11:39 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Sometimes the oil cap says what to use.
  9. Apr 27, 2014 at 11:48 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    On the tag right near the rubber flap you should be able to find model # of it. Post that up and it should help me.
    Generally speaking, I bet you have a Briggs and Stratton engine. I have a Craftsman mower similar (6.75 hp about 10 yrs old) and that's what mine is. EDIT: Never mind, I blew up the pic a little and it does say B and S on it.
    Home Depot usually has all you need for that. I'd do air filter, plug, oil for sure.
    Fuel..I use super unleaded with Stabil or Startron additive. Just put the additive in the can before buying fuel. Runs a little better and won't junk up the carb that way.
  10. Apr 27, 2014 at 11:56 AM
    anotherreject
    Yea the motor says briggs and straton, thanks for the fast replies
  11. Apr 27, 2014 at 12:07 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    SAE 30 for the oil, should be sold for small engines.
    Also, you may want to replace the blade, wouldn't hurt.
  12. Apr 27, 2014 at 12:21 PM
    rkd1119
    rkd1119 Well-Known Member
    Robert
    L.A. (lower Alabama)
    ‘23 Trail Edition Ice Cap
    Look on pure-gas.org and see if there are any ethanol free gas stations in your area. If you buy ethanol free gas you won't have to mess with a stabilizer (which you MUST use if you can't find a pure gas outlet) and there won't be the chance of fuel separation or the ethanol eating the fuel lines from the inside out.
    The other suggestions about a new plug, air filter, and fuel filter (if it has one, if not you can buy a universal one and cut the fuel line and put it in, cheap insurance) are spot on. Also look at the blade and if it's dull on the leading edge, buy a new one and sharpen that one on a bench grinder or with a Dremel tool if you have a vise. A sharp blade takes a LOT of the load off the mower and will make it cut MUCH nicer.
    Another newbie common mistake is cutting too low. Depends on the type of grass in your yard, but most grass should be cut 2.5 to 3" high. Lots of people shave it as low as they can, then wonder why they're fighting weeds and poor grass growth.
  13. Apr 27, 2014 at 12:24 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Run premium ethanol free if possible. Straight weight 30 oil. Also change spark plug and air filter. You might want to take a look at the blade as well, unless you want to beat your grass into submission. :rolleyes:
  14. Apr 27, 2014 at 2:07 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    Have you tried googling the brand/model, anymore you can find just about any manual on line.
  15. Apr 27, 2014 at 10:21 PM
    lawless
    lawless the rent is too damn high
    Lawson
    San Jose, CA
    2012 dcsb mgm sc
    13 replies and finally a sensible answer. Get the manual and take it straight from the manufacturer.
