Please share your spacer lift experiences
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redtaco777, Jun 11, 2025.
  1. Jun 12, 2025 at 3:35 PM
    #41
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I ran the 2” Rough Country spacer lift for about a year while I saved up money for Bilstein 5100’s. They were perfectly fine for light off roading and on-road driving. If I remember correctly, I put about 25,000 miles on the truck before I switched to the Bilsteins.
    TacoTime55 likes this.
  2. Jun 12, 2025 at 6:25 PM
    #42
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    You're good RW!
    I waited 47 months to do my upgrade...but I don't off-road AT ALL so it wasn't a priority to lift my truck.
    Now, I'm riding at the same height (just about) as the Tacoma Limited I had as a loaner.
    I think the TRD Lift Kit is the best for my needs.
    Road_Warrior[QUOTED] likes this.
  3. Jun 13, 2025 at 10:56 AM
    #43
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Just found this, bigger UCAs aren't recommended unless a Lift is more than 2".
    https://www.youtube.com/watch?v=huMztKaHsUE
    winkel likes this.
  4. Jun 17, 2025 at 2:13 PM
    #44
    Redtaco777
    Redtaco777 [OP] Well-Known Member
    NC
    Uni-filter Mod
    Which hight setting did you have your 5100 set too and what UCA did u have
  5. Jun 17, 2025 at 2:58 PM
    #45
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Stock UCAs and my bilsteins are on the 4th notch currently.
  6. Jun 19, 2025 at 10:33 AM
    #46
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You may need a sway bar drop kit with aftermarket coils. I installed 5100’s on lowest setting with OME coils and got a little bit of rubbing. It was fine when I initially had 5100’s on highest setting with OEM coils, but the OMEs are a little thicker. I never installed a diff drop kit and I didn't replace the needle bearing until around 200K. I’ve had the 5100s since about 60K, or whenever the powertrain warranty expired. And my needle bearing was not in too bad condition - my driver-side CV has some extra play but I never had vibration issues.
