Please tell me how I screwed up!!!!!
Discussion in 'Audio & Video' started by hoyta, Sep 24, 2010.
  1. Sep 24, 2010 at 5:51 AM
    hoyta
    hoyta [OP] Well-Known Member
    Adam
    Camden,NC
    08 Rugged Trail DC
    I spent the day installing my audio, and am running into some problems!
    First, its an 08 access cab. Well, the amp willnot turn on. I checked the remote, and it is fine. I'm getting sound from my speakers, but not amplified sound....lol. Its a 4 channel amp, and I am running the front two channels to my components in the front. I haven't hooked up the rear two channels yet, which I am bridging to my sub. I can't find a correct ground. I tried the back seat bracket, but that didn't work. When I move the ground around to metal in the truck, the amp lights up, but it reads protection mode.
    The other thing I'm running into is road noise from the right speaker?? I am runnning the rcas on the passenger side down the door sill. What do I need to look for to stop this?
    Thanks a ton for any help!
    -Adam
  2. Sep 24, 2010 at 5:56 AM
    hookedontronics
    hookedontronics Well-Known Member
    Jake
    Glenville, NY
    2010 DC Off Road 4x4
    Icon extended travel 3.5" front coilovers, DSM UCAs, TSB leaf pack w/ wheelers AAL, All Pro U-bolt flip kit, Walker Evans 2.0 rear shocks, 18" XD Monster rims, Nitto trail grappler 285/65R18 Tires, Color matched grill, Grillcraft, Kragen HIDs, Carling switches, my bed light mod, diff drop, Alpine IVA-W505, JL Audio C5 componets and coaxials, JL 300/4 and 250/1 amps and JL stealthbox, wheathertechs, avs vent visors, toyota bed x-tender, alcantara center console cover and door pocket covers, console vault, color matched mirrors, heated mirrors, etc etc etc
    A couple things to check...
    Sand off the paint when you connect your ground.
    Check that your remote is hooked up to ignition (12v power when the truck is on only)
    Run your power wires on the opposite side from your rca wires
    adjust the setting on your amp
  3. Sep 24, 2010 at 5:58 AM
    KodiakToyTRD
    KodiakToyTRD Well-Known Member
    CO
    2013 Scion FR-S Whiteout
    Where is your amp power wire?
    Do you have a fuse in the power wire?
    So your remote turn on wire is working but you get no sound from the amp...i really don't know what could be wrong there so hopefully one of the sound guys wil be able to help.
    Did you get a capacitor also for your system?
  4. Sep 24, 2010 at 6:03 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    If you can't get rid of the noise, they sell inline noise filters that run in the rca's.
    Protection mode is normally because the power lines to the amp are hooked up backwards, or there is no ground. Best bet is to run power and ground directly to and from the battery.
  5. Sep 24, 2010 at 6:03 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    What he said :cool:
  6. Sep 24, 2010 at 6:22 AM
    bendbolden
    bendbolden Come and take them.
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    When you say you are getting sound do you mean music is playing or just noise?
  7. Sep 24, 2010 at 6:23 AM
    hoyta
    Adam
    Camden,NC
    08 Rugged Trail DC
    The remote is hooked to the wiring harness, the blue/white wire (Kenwood stereo). When I touch the ground to metal, the amp actually lights up, but says protection. Maybe I will run it to my battery!
    When you say ignition wire, its the blue one, right? I know the red wire is power as well
  8. Sep 24, 2010 at 6:26 AM
    bendbolden
    Ben
    Moscow, TN
    07 FJ Cruiser
    None but soon......
    Someone correct me if I'm wrong but I thought on most amps if the remote wire is not attached correctly the amp won't even show going into protection. As if it is not even trying to turn on.
  9. Sep 24, 2010 at 8:38 AM
    hoyta
    Adam
    Camden,NC
    08 Rugged Trail DC
    You are right- The remote wire is hooked up correctly!
  10. Sep 24, 2010 at 8:45 AM
    Shack
    Shack Well-Known Member
    Lane
    Chester, VA
    2010 TRD Off Road 4x4
    Bilstein 5100-Front (1.75"), Pop N' Lock Tailgate, Rear Leaf TSB MR. Marv custom box and amp rack, JL 13TW-5, Memphis Audio Amps and Door Speaker, JVC DVD DD HU, Wet Okole, Weathertech Mats, Bed Mat
    Sounds like you may have a problem with the amp iteself. Have you tested it?
  11. Sep 24, 2010 at 8:46 AM
    Trog2233
    Trog2233 Well-Known Member
    PA
    2013 Barcelona Red Double Cab TRD sport 4x4
    Bak Flip VP tonneau cover
    Ok i'm really confused here. Your getting sound out of the speakers but not amplified? Are you getting sound out of the speakers without the amp light turned on? Either turn ur amp gain up and it should get louder or you have something installed incorrectly. As far as the ground wire a sanded down seatbelt bolt always works great. Also not sure what kind of amp you have but sometimes when the protect light comes on the amp is fried. Not saying thats your problem but it could be.
  12. Sep 24, 2010 at 9:04 AM
    Daudio
    Daudio Well-Known Member
    North Jersey
    '02 SR5
    avic-d1 sirius tuner Ipod adapter
    You don't need to run the ground to the battery. A seat bolt, or seat belt bolt are good spots to ground, if not find some metal and sand the paint off and use a self tapper and a star washer. The RCA's need to run at least 18"s from the power wire and if you crossing any other power in the car you need to cross it at a 90 degree angle. As someone else said you can get in line filters that will help with the alternator whine, but that depends on what kind of signal wire you are using... You may need to upgrade that instead.
    I would pull the amp out and bench test it. Hook up some 8 gauge from a battery charger and just jump the 12+ to the remote and ground the other side. If it goes into protection and there is no load on the amp it is 99% probably fried. Good luck.
  13. Sep 24, 2010 at 10:11 AM
    hoyta
    Adam
    Camden,NC
    08 Rugged Trail DC
    I haven't tested the amp yet.... I think it may be the ground. I'm going to try the seatbelt bolt, and see if that works.
    Thanks for the help!
  14. Sep 24, 2010 at 2:36 PM
    hoyta
    Adam
    Camden,NC
    08 Rugged Trail DC
    I took it by an audio shop- They grounded the amp, did tests, and the F*&^%^& amp is fried! Damn Ebay
  15. Sep 24, 2010 at 2:38 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
  16. Sep 25, 2010 at 12:48 PM
    Daudio
    North Jersey
    '02 SR5
    That sucks man, sorry to hear that. Hope everything works out for you.
  17. Sep 25, 2010 at 1:07 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    File a complaint with paypal if the auction was for a working amp.
  18. Sep 25, 2010 at 6:45 PM
    Shack
    Lane
    Chester, VA
    Told ya. Sorry to hear about it though.
  19. Sep 25, 2010 at 6:48 PM
    AvsFanTRD
    AvsFanTRD Oh gravity, thou art a heartless bitch!
    Brandon
    Wyoming
    2008 TRD Off Road Black
    rear suspension TSB, sockmonkey bed decals, weathertech floor liners, TRD seat covers, tailgate pop n lock, rear diff breather relocation, center console lock, Viper Alarm, extra D-rings in bed, 5100's on all 4 corners
    word of advice for next time. I wouldn't power my components and sub off the same amp.
  20. Oct 5, 2010 at 1:05 PM
    hoyta
    Adam
    Camden,NC
    08 Rugged Trail DC
    I decided to just amp the woofer, and keep the comps stock off the head unit for now. The alternator noise is still there, but I'll figire that out.
    Thanks to all~
